How to get a timestamp when I receive an advertisement from another nRF51822 device?
Hi.
I am using Central's  ble_app_uart_c_pca10028_s130 which is a sample of nRF51822.
I would like to see the timestamp of the advertisement acquisition I receive from the other machine, or the time elapsed since the first packet was received.
I would eventually like to display RSSI and timestamps at the same time.
For now, I've added BLE_GAP_EVT_ADV_REPORT to the sample to display Mac Address and RSSI.
I'm new to these programs, so I'd appreciate it if you could show me the code.
I would appreciate your help.
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "boards.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "softdevice_handler.h"
#include "ble_advdata.h"
#include "ble_nus_c.h"
#define CENTRAL_LINK_COUNT      1                               /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
#define PERIPHERAL_LINK_COUNT   0                               /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
#if (NRF_SD_BLE_API_VERSION == 3)
#define NRF_BLE_MAX_MTU_SIZE    GATT_MTU_SIZE_DEFAULT           /**< MTU size used in the softdevice enabling and to reply to a BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST event. */
#define UART_TX_BUF_SIZE        256                             /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE        256                             /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN      /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_TIMER_PRESCALER     0                               /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_OP_QUEUE_SIZE 2                               /**< Size of timer operation queues. */
#define SCAN_INTERVAL           0x00A0                          /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW             0x0050                          /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_ACTIVE             1                               /**< If 1, performe active scanning (scan requests). */
#define SCAN_SELECTIVE          0                               /**< If 1, ignore unknown devices (non whitelisted). */
#define SCAN_TIMEOUT            0x0000                          /**< Timout when scanning. 0x0000 disables timeout. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Determines minimum connection interval in millisecond. */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Determines maximum connection interval in millisecond. */
#define SLAVE_LATENCY           0                               /**< Determines slave latency in counts of connection events. */
#define SUPERVISION_TIMEOUT     MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 millisecond. */
#define UUID16_SIZE             2                               /**< Size of 16 bit UUID */
#define UUID32_SIZE             4                               /**< Size of 32 bit UUID */
#define UUID128_SIZE            16                              /**< Size of 128 bit UUID */
static ble_nus_c_t              m_ble_nus_c;                    /**< Instance of NUS service. Must be passed to all NUS_C API calls. */
static ble_db_discovery_t       m_ble_db_discovery;             /**< Instance of database discovery module. Must be passed to all db_discovert API calls */
 * @brief Connection parameters requested for connection.
static const ble_gap_conn_params_t m_connection_param =
    (uint16_t)MIN_CONNECTION_INTERVAL,  // Minimum connection
    (uint16_t)MAX_CONNECTION_INTERVAL,  // Maximum connection
    (uint16_t)SLAVE_LATENCY,            // Slave latency
    (uint16_t)SUPERVISION_TIMEOUT       // Supervision time-out
 * @brief Parameters used when scanning.
static const ble_gap_scan_params_t m_scan_params =
    .active   = 1,
    .interval = SCAN_INTERVAL,
    .window   = SCAN_WINDOW,
    .timeout  = SCAN_TIMEOUT,
    #if (NRF_SD_BLE_API_VERSION == 2)
        .selective   = 0,
        .p_whitelist = NULL,
        .use_whitelist = 0,
 * @brief NUS uuid
static const ble_uuid_t m_nus_uuid =
    .uuid = BLE_UUID_NUS_SERVICE,
    .type = NUS_SERVICE_UUID_TYPE
/**@brief Function for asserts in the SoftDevice.
 * @param[in] line_num     Line number of the failing ASSERT call.
 * @param[in] p_file_name  File name of the failing ASSERT call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function to start scanning.
static void scan_start(void)
    ret_code_t ret;
    ret = sd_ble_gap_scan_start(&m_scan_params);
    APP_ERROR_CHECK(ret);
    ret = bsp_indication_set(BSP_INDICATE_SCANNING);
/**@brief Function for handling database discovery events.
 * @details This function is callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function should forward the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' i.e '\r\n' (hex 0x0D) or if the string has reached a length of
 *          @ref NUS_MAX_DATA_LENGTH.
    static uint8_t index = 0;
    switch (p_event->evt_type)
        /**@snippet [Handling data from UART] */
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (BLE_NUS_MAX_DATA_LEN)))
                while (ble_nus_c_string_send(&m_ble_nus_c, data_array, index) != NRF_SUCCESS)
                    // repeat until sent.
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief Callback handling NUS Client events.
 * @details This function is called to notify the application of NUS client events.
 * @param[in]   p_ble_nus_c   NUS Client Handle. This identifies the NUS client
 * @param[in]   p_ble_nus_evt Pointer to the NUS Client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, const ble_nus_c_evt_t * p_ble_nus_evt)
    uint32_t err_code;
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            err_code = ble_nus_c_rx_notif_enable(p_ble_nus_c);
            printf("The device has the Nordic UART Service\r\n");
        case BLE_NUS_C_EVT_NUS_RX_EVT:
            for (uint32_t i = 0; i < p_ble_nus_evt->data_len; i++)
                while (app_uart_put( p_ble_nus_evt->p_data[i]) != NRF_SUCCESS);
        case BLE_NUS_C_EVT_DISCONNECTED:
            printf("Disconnected\r\n");
            scan_start();
    // Prepare wakeup buttons.
/**@brief Reads an advertising report and checks if a uuid is present in the service list.
 * @details The function is able to search for 16-bit, 32-bit and 128-bit service uuids.
 *          To see the format of a advertisement packet, see
 *          https://www.bluetooth.org/Technical/AssignedNumbers/generic_access_profile.htm
 * @param[in]   p_target_uuid The uuid to search fir
 * @param[in]   p_adv_report  Pointer to the advertisement report.
 * @retval      true if the UUID is present in the advertisement report. Otherwise false
static bool is_uuid_present(const ble_uuid_t *p_target_uuid,
                            const ble_gap_evt_adv_report_t *p_adv_report)
    uint32_t err_code;
    uint32_t index = 0;
    uint8_t *p_data = (uint8_t *)p_adv_report->data;
    ble_uuid_t extracted_uuid;
    while (index < p_adv_report->dlen)
        uint8_t field_length = p_data[index];
        uint8_t field_type   = p_data[index + 1];
        if ( (field_type == BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_MORE_AVAILABLE)
           || (field_type == BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_COMPLETE)
            for (uint32_t u_index = 0; u_index < (field_length / UUID16_SIZE); u_index++)
                err_code = sd_ble_uuid_decode(  UUID16_SIZE,
                                                &p_data[u_index * UUID16_SIZE + index + 2],
                                                &extracted_uuid);
                if (err_code == NRF_SUCCESS)
                    if ((extracted_uuid.uuid == p_target_uuid->uuid)
                        && (extracted_uuid.type == p_target_uuid->type))
                        return true;
        else if ( (field_type == BLE_GAP_AD_TYPE_32BIT_SERVICE_UUID_MORE_AVAILABLE)
                || (field_type == BLE_GAP_AD_TYPE_32BIT_SERVICE_UUID_COMPLETE)
            for (uint32_t u_index = 0; u_index < (field_length / UUID32_SIZE); u_index++)
                err_code = sd_ble_uuid_decode(UUID16_SIZE,
                &p_data[u_index * UUID32_SIZE + index + 2],
                &extracted_uuid);
                        return true;
        else if ( (field_type == BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_MORE_AVAILABLE)
                || (field_type == BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_COMPLETE)
            err_code = sd_ble_uuid_decode(UUID128_SIZE,
                                          &p_data[index + 2],
                                          &extracted_uuid);
                    return true;
        index += field_length + 1;
    return false;
/**@brief Function for handling the Application's BLE Stack events.
 * @param[in] p_ble_evt  Bluetooth stack event.
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t              err_code;
    const ble_gap_evt_t * p_gap_evt = &p_ble_evt->evt.gap_evt;
																						const ble_gap_evt_adv_report_t *p_adv_report;					// Pointer to advertising report
																						char txt[20];
        case BLE_GAP_EVT_ADV_REPORT:
																					ble_gap_addr_t pa = p_gap_evt->params.adv_report.peer_addr;
																					int8_t rssi = p_gap_evt->params.adv_report.rssi;
																					printf("Mac Address: %02x:%02x:%02x:%02x:%02x:%02x \r\n", pa.addr[5], pa.addr[4], pa.addr[3], pa.addr[2], pa.addr[1], pa.addr[0]);
																					printf("RSSI %d \r\n", rssi);
            const ble_gap_evt_adv_report_t * p_adv_report = &p_gap_evt->params.adv_report;
            if (is_uuid_present(&m_nus_uuid, p_adv_report))
                err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
                                              &m_scan_params,
                                              &m_connection_param);
                    // scan is automatically stopped by the connect
                    printf("Connecting to target %02x%02x%02x%02x%02x%02x\r\n",
                             p_adv_report->peer_addr.addr[0],
                             p_adv_report->peer_addr.addr[1],
                             p_adv_report->peer_addr.addr[2],
                             p_adv_report->peer_addr.addr[3],
                             p_adv_report->peer_addr.addr[4],
                             p_adv_report->peer_addr.addr[5]
        }break; // BLE_GAP_EVT_ADV_REPORT
        case BLE_GAP_EVT_CONNECTED:
            //NRF_LOG_DEBUG("Connected to target\r\n");
            // start discovery of services. The NUS Client waits for a discovery result
            err_code = ble_db_discovery_start(&m_ble_db_discovery, p_ble_evt->evt.gap_evt.conn_handle);
            break; // BLE_GAP_EVT_CONNECTED
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
                //NRF_LOG_DEBUG("Scan timed out.\r\n");
                scan_start();
            else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                printf("Connection Request timed out.\r\n");
            break; // BLE_GAP_EVT_TIMEOUT
            // Pairing not supported
            err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
            break; // BLE_GAP_EVT_SEC_PARAMS_REQUEST
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
            break; // BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST
        case BLE_GATTC_EVT_TIMEOUT:
            //NRF_LOG_DEBUG("GATT Client Timeout.\r\n");
            break; // BLE_GATTC_EVT_TIMEOUT
        case BLE_GATTS_EVT_TIMEOUT:
            //NRF_LOG_DEBUG("GATT Server Timeout.\r\n");
            break; // BLE_GATTS_EVT_TIMEOUT
        case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
            err_code = sd_ble_gatts_exchange_mtu_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                       NRF_BLE_MAX_MTU_SIZE);
            break; // BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST
/**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler.
 * @details This function is called from the scheduler in the main loop after a BLE stack event has
 *          been received.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    on_ble_evt(p_ble_evt);
    bsp_btn_ble_on_ble_evt(p_ble_evt);
    ble_db_discovery_on_ble_evt(&m_ble_db_discovery, p_ble_evt);
    ble_nus_c_on_ble_evt(&m_ble_nus_c,p_ble_evt);
    uint32_t err_code;
    nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
    // Initialize the SoftDevice handler module.
    SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
    ble_enable_params_t ble_enable_params;
    err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                    PERIPHERAL_LINK_COUNT,
                                                    &ble_enable_params);
    //Check the ram settings against the used number of links
    CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
    // Enable BLE stack.
    ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE;
    err_code = softdevice_enable(&ble_enable_params);
    // Register with the SoftDevice handler module for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
 * @param[in] event  Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
/**@brief Function for initializing the UART.
static void uart_init(void)
    uint32_t err_code;
    const app_uart_comm_params_t comm_params =
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .flow_control = APP_UART_FLOW_CONTROL_ENABLED,
        .use_parity   = false,
        .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                        UART_RX_BUF_SIZE,
                        UART_TX_BUF_SIZE,
                        uart_event_handle,
                        APP_IRQ_PRIORITY_LOWEST,
                        err_code);
/**@brief Function for initializing the NUS Client.
static void nus_c_init(void)
    uint32_t         err_code;
    ble_nus_c_init_t nus_c_init_t;
    nus_c_init_t.evt_handler = ble_nus_c_evt_handler;
    err_code = ble_nus_c_init(&m_ble_nus_c, &nus_c_init_t);
																														//	uint32_t sd_ble_gap_rssi_start	(	uint16_t 	conn_handle, uint8_t 	threshold_dbm, uint8_t 	skip_count);
																														//	uint32_t sd_ble_gap_rssi_stop	(	uint16_t 	conn_handle	);
static void buttons_leds_init(void)
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LED,
                                 APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                 bsp_event_handler);
/** @brief Function for initializing the Database Discovery Module.
static void db_discovery_init(void)
    uint32_t err_code = ble_db_discovery_init(db_disc_handler);
/** @brief Function for the Power manager.
static void power_manage(void)
    uint32_t err_code = sd_app_evt_wait();
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, NULL);
		uart_init();
    buttons_leds_init();
    db_discovery_init();
    ble_stack_init();
    nus_c_init();
    // Start scanning for peripherals and initiate connection
    // with devices that advertise NUS UUID.
    printf("Uart_c Scan started\r\n");
    scan_start();
    for (;;)
			power_manage();
  • Thanks.
    >>Why do you want to add sensorsim.c ?
    This is because I used the default battery_level_meas_timeout_handler of "ble_app_hrs".
    I would like to observe the time variability of RSSI, is there anything I should set in the timeout handler?
    I quoted "repeated_timer_handler" as timeout handler() from your link.
    The code looks like the following. This is only part of the code. The rest of the code is the same as "ble_app_uart_c" in central.
    I would like to display the timer as the packet arrives from peripheral, what should I printf()?
    APP_TIMER_DEF(my_timer_id1);
    #define BATTERY_LEVEL_MEAS_INTERVAL      APP_TIMER_TICKS(2000, APP_TIMER_PRESCALER)  /**< Battery level measurement interval (ticks). */
    static void repeated_timer_handler(void * p_context)
    nrf_drv_gpiote_out_toggle(LED_1);
        uint32_t              err_code;
    //get RSSI and MAC address
    // Create timers.
    err_code = app_timer_create(&my_timer_id1,APP_TIMER_MODE_REPEATED, repeated_timer_handler);
    // Start application timers.
    err_code = app_timer_start(my_timer_id1, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
  • Do you see the LED toggle every 2 seconds ?
    If you do see the LED toggle, you can start to count time. You just increase the counter (a uint variable that you define) +1 inside repeated_timer_handler(). This way you can start counting time.
    When you receive an advertising packet, you can print this counter variable out.
    If 2 seconds is too long, you can change the counter to 10ms for example.
  • Thanks.
    There are no program compilation errors, but there are some problems.
    There were a few things I would like to ask about in your answer.
    Please forgive my questions.
    No, The central terminal has an LED blinking irregularly.
    When I checked the packets with teraterm, there were some garbled characters.
    Is it because I am receiving packets at intervals shorter than 2 seconds?
    This means that the value of the counter is (1,2.... .n) and I can calculate n×2[s] or n×10[ms]?
    Does that carry the risk of not being able to figure out the time when the packet is missing from the acquisition?
    P.S.
    What's wrong with my program?
    	float cnt;
    #include "nrf_drv_clock.h"
    uint32_t 	nrf_drv_gpiote_out_toggle();
    cnt++;
        uint32_t              err_code;
            				 // Create timers.
            				printf("%f \r\n", cnt);
  • Hi Tadanohito,
    Please try to study how the app_timer works. You would need to make a program that be able to perform a task periodically for example turning off and on a LED or do other task.
    Have you tried to follow the app_timer tutorial ?
    I don't understand why you define the counter cnt as float. Why don't you just define it as uint ? for example uint32_t
    Note that the counter is only to count the time, it doesn't matter if the packet is missing or not, it just count the time.
    You don't have to use 2 seconds period, you can change it to shorter, for example 1ms.
  • Thank you for all the advice.
    I've solved this problem.
    #include <stdio.h>
    #include <stdint.h>
    #include "bsp.h"
    #include "boards.h"
    #include "ble.h"
        .active   = 1,
            .selective   = 0,
            .use_whitelist = 0,
     * @brief NUS uuid
        ret_code_t ret;
                index++;
                    index = 0;
        uint32_t err_code;
                scan_start();
        uint32_t err_code;
        uint32_t index = 0;
                                                    &extracted_uuid);
                            return true;
                    &extracted_uuid);
                            return true;
                                              &p_data[index + 2],
                                              &extracted_uuid);
                        return true;
        return false;
    //uint32_t cnt;
    #define BATTERY_LEVEL_MEAS_INTERVAL      APP_TIMER_TICKS(10, APP_TIMER_PRESCALER)  /**< Battery level measurement interval (ticks). */
    #include "nrf.h"
    #include "nrf_delay.h"
    #define NRF_LOG_MODULE_NAME "APP"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define 	APP_TIMER_CLOCK_FREQ   32768
    //nrf_drv_gpiote_out_toggle(LED_1);
    //cnt++;
    static void timers_init(void)
    uint32_t              err_code;
    // Create timers.
        uint32_t              err_code;
    double timenow = app_timer_cnt_get()/APP_TIMER_CLOCK_FREQ ;
    printf("time now: %f\r\n", (double) timenow);
                                                  &m_scan_params,
                    scan_start();
     *          been received.
        uint32_t err_code;
        uint32_t err_code;
        switch (event)
                sleep_mode_enter();
        uint32_t err_code;
                            UART_RX_BUF_SIZE,
                            UART_TX_BUF_SIZE,
                            uart_event_handle,
                            err_code);
        uint32_t         err_code;
                                     bsp_event_handler);
    		uart_init();
        ble_stack_init();
        nus_c_init();
        scan_start();
        for (;;)
    			power_manage();
