AGPS with SUPL with MQTT_Simple example
I use MQTT_Simple example with AGPS feature;
I add 3 functions, one for init GPS, one for start GPS, and the last for A_GPS request.
static void gps_control_init(void)
    int err;
    gps_dev = device_get_binding(CONFIG_NRF9160_GPS_DEV_NAME);
    if (gps_dev == NULL) {
            LOG_ERR("Could not get %s device",
                    log_strdup(CONFIG_NRF9160_GPS_DEV_NAME));
            return -ENODEV;
    err = gps_init(gps_dev, gps_handler);
    if (err) {
            LOG_ERR("Could not initialize GPS, error: %d", err);
            return err;
static void start(void)
    int err;
    struct gps_config gps_cfg = {
            .nav_mode = GPS_NAV_MODE_PERIODIC,
            .power_mode = GPS_POWER_MODE_DISABLED,
            .timeout = 360,
            .interval = 360 +
                    30,
            .priority = true,
            LOG_ERR("GPS controller is not initialized properly");
            return;
    LOG_INF("Enabling PSM");
    err = lte_lc_psm_req(true);
    if (err) {
            LOG_ERR("PSM request failed, error: %d", err);
    } else {
            LOG_INF("PSM enabled");
    err = gps_start(gps_dev, &gps_cfg);
    if (err) {
            LOG_ERR("Failed to enable GPS, error: %d", err);
            return;
static void on_agps_needed(struct gps_agps_request request)
	int err;
	err = gps_agps_request(request, GPS_SOCKET_NOT_PROVIDED);
	if (err) {
		LOG_ERR("Failed to request A-GPS data, error: %d", err);
		return;
I call Init after "MQTT client connected", and start GPS by button_handler.
When it runs, an error occurs:
I used  nRF9160 GPS driver [experimental], Ubuntu, ncs v1.5.1
  • This is my log file. I manually start AGPS by button, when seeing RRC Idle Event. I achieve 2 successes.2021-06-02T14_24_18.010Z-log.txt
    The Default AGPS example and GPS example work well. I combine AGPS to MQTT_Simple base on the AGPS example.
    I've discussed the issue with some of my colleagues. First of all, the error -13 is not permission denied, it is from the SUPL library (nrf\ext\lib\bin\supl\include\supl_session.h)
    #define LIBSUPL_TIMEOUT                     (-13)
    In the the GPS struct gps_cfg, please try to remove priority = true, or set to false:
                .timeout = 360,
                .interval = 360 +
                        30,
                .priority = true,
    And please increase the MQTT keepalive, which is default to 60 seconds in the MQTT library. This value depends on the MQTT broker you are using, i.e. AWS IoT allows a keepalive of maximum 1200 seconds. You could try e.g. 180 seconds:
    CONFIG_MQTT_KEEPALIVE=180
    Øyvind
    I've followed your guide. I also set my mqtt alive time to 300s, but the same problem. I do the first start AGPS right after mqtt client connected Event and got -13 error; then I try start in RRC Idle event, also -13
    2021-06-04T10:01:55.590Z INFO Application data folder: C:\Users\Admin\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2021-06-04T10:01:55.823Z DEBUG App pc-nrfconnect-linkmonitor v1.1.10 official
    2021-06-04T10:01:55.828Z DEBUG App path: C:\Users\Admin\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2021-06-04T10:01:55.829Z DEBUG nRFConnect 3.6.1 is supported by the app (^3.6.0)
    2021-06-04T10:01:55.829Z DEBUG nRFConnect path: C:\Users\Admin\AppData\Local\Programs\nrfconnect\resources\app.asar
    2021-06-04T10:01:55.831Z DEBUG HomeDir: C:\Users\Admin
    2021-06-04T10:01:55.834Z DEBUG TmpDir: C:\Users\Admin\AppData\Local\Temp
    2021-06-04T10:02:09.093Z INFO Modem port is opened
    2021-06-04T10:02:09.102Z DEBUG modem >> AT+CFUN?
    2021-06-04T10:02:09.149Z DEBUG modem << +CFUN: 0
    2021-06-04T10:02:09.153Z DEBUG modem << OK
    2021-06-04T10:02:11.511Z DEBUG modem << [00:00:05.235,168] [0m<inf> mqtt_simple: The MQTT simple sample started[0m
    2021-06-04T10:02:11.514Z DEBUG modem << [00:00:05.235,198] [0m<inf> mqtt_simple: Disabling PSM and eDRX[0m
    2021-06-04T10:02:11.517Z DEBUG modem << [00:00:05.251,098] [0m<inf> mqtt_simple: LTE Link Connecting...[0m
    2021-06-04T10:02:20.781Z DEBUG modem >> AT+CFUN?
    2021-06-04T10:02:20.789Z DEBUG modem << +CFUN: 1
    2021-06-04T10:02:20.802Z DEBUG modem << OK
    2021-06-04T10:02:20.809Z DEBUG modem >> AT+CGSN=1
    2021-06-04T10:02:20.820Z DEBUG modem << +CGSN: "352656101397258"
    2021-06-04T10:02:20.822Z DEBUG modem << OK
    2021-06-04T10:02:20.828Z DEBUG modem >> AT+CGMI
    2021-06-04T10:02:20.840Z DEBUG modem << Nordic Semiconductor ASA
    2021-06-04T10:02:20.844Z DEBUG modem << OK
    2021-06-04T10:02:20.854Z DEBUG modem >> AT+CGMM
    2021-06-04T10:02:20.869Z DEBUG modem << nRF9160-SICA
    2021-06-04T10:02:20.873Z DEBUG modem << OK
    2021-06-04T10:02:20.888Z DEBUG modem >> AT+CGMR
    2021-06-04T10:02:20.920Z DEBUG modem << mfw_nrf9160_1.2.3
    2021-06-04T10:02:20.925Z DEBUG modem << OK
    2021-06-04T10:02:20.929Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.2.3] SerNr: 352656101397258
    2021-06-04T10:02:20.931Z DEBUG modem >> AT+CEMODE?
    2021-06-04T10:02:20.941Z DEBUG modem << +CEMODE: 0
    2021-06-04T10:02:20.946Z DEBUG modem << OK
    2021-06-04T10:02:20.971Z DEBUG modem >> AT%XCBAND=?
    2021-06-04T10:02:20.986Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2021-06-04T10:02:20.995Z DEBUG modem << OK
    2021-06-04T10:02:21.019Z DEBUG modem >> AT+CMEE?
    2021-06-04T10:02:21.040Z DEBUG modem << +CMEE: 0
    2021-06-04T10:02:21.042Z DEBUG modem << OK
    2021-06-04T10:02:21.047Z DEBUG modem >> AT+CMEE=1
    2021-06-04T10:02:21.071Z DEBUG modem << OK
    2021-06-04T10:02:21.077Z DEBUG modem >> AT+CNEC?
    2021-06-04T10:02:21.107Z DEBUG modem << +CNEC: 0
    2021-06-04T10:02:21.109Z DEBUG modem << OK
    2021-06-04T10:02:21.114Z DEBUG modem >> AT+CNEC=24
    2021-06-04T10:02:21.134Z DEBUG modem << OK
    2021-06-04T10:02:21.138Z DEBUG modem >> AT+CGEREP?
    2021-06-04T10:02:21.161Z DEBUG modem << +CGEREP: 0,0
    2021-06-04T10:02:21.167Z DEBUG modem << OK
    2021-06-04T10:02:21.176Z DEBUG modem >> AT+CGDCONT?
    2021-06-04T10:02:21.206Z DEBUG modem << OK
    2021-06-04T10:02:21.211Z DEBUG modem >> AT+CGACT?
    2021-06-04T10:02:21.227Z DEBUG modem << OK
    2021-06-04T10:02:21.242Z DEBUG modem >> AT+CGEREP=1
    2021-06-04T10:02:21.260Z DEBUG modem << OK
    2021-06-04T10:02:21.264Z DEBUG modem >> AT+CIND=1,1,1
    2021-06-04T10:02:21.282Z DEBUG modem << OK
    2021-06-04T10:02:21.289Z DEBUG modem >> AT+CEREG=5
    2021-06-04T10:02:21.307Z DEBUG modem << OK
    2021-06-04T10:02:21.313Z DEBUG modem >> AT+CEREG?
    2021-06-04T10:02:21.336Z DEBUG modem << +CEREG: 5,4,"FFFE","FFFFFFFF",9,0,0,"00000000","00000000"
    2021-06-04T10:02:21.339Z DEBUG modem << OK
    2021-06-04T10:02:21.358Z DEBUG modem >> AT%CESQ=1
    2021-06-04T10:02:21.373Z DEBUG modem << OK
    2021-06-04T10:02:21.375Z DEBUG modem >> AT+CESQ
    2021-06-04T10:02:21.389Z DEBUG modem << +CESQ: 99,99,255,255,255,255
    2021-06-04T10:02:21.393Z DEBUG modem << OK
    2021-06-04T10:02:21.417Z DEBUG modem >> AT%XSIM=1
    2021-06-04T10:02:21.440Z DEBUG modem << OK
    2021-06-04T10:02:21.446Z DEBUG modem >> AT%XSIM?
    2021-06-04T10:02:21.460Z DEBUG modem << %XSIM: 1
    2021-06-04T10:02:21.463Z DEBUG modem << OK
    2021-06-04T10:02:21.488Z DEBUG modem >> AT+CPIN?
    2021-06-04T10:02:21.501Z DEBUG modem << +CPIN: READY
    2021-06-04T10:02:21.504Z DEBUG modem << OK
    2021-06-04T10:02:21.514Z DEBUG modem >> AT+CPINR="SIM PIN"
    2021-06-04T10:02:21.534Z DEBUG modem << +CPINR: "SIM PIN",3
    2021-06-04T10:02:21.537Z DEBUG modem << OK
    2021-06-04T10:02:21.547Z DEBUG modem >> AT+CIMI
    2021-06-04T10:02:21.557Z DEBUG modem << 452040325353031
    2021-06-04T10:02:21.560Z DEBUG modem << OK
    2021-06-04T10:02:21.562Z INFO IMSIdentity: 452040325353031
    2021-06-04T10:02:29.905Z DEBUG modem << %CESQ: 30,1,0,0
    2021-06-04T10:02:29.914Z DEBUG modem << +CEREG: 2,"61B6","090BF716",9,0,0,"11100000","11100000"
    2021-06-04T10:02:30.914Z DEBUG modem << [00:00:24.649,383] [0m<inf> mqtt_simple: LTE cell changed: Cell ID: 151779094, Tracking area: 25014[0m
    2021-06-04T10:03:02.291Z DEBUG modem << %CESQ: 34,1,6,0
    2021-06-04T10:03:08.298Z DEBUG modem << %CESQ: 31,1,0,0
    2021-06-04T10:03:08.306Z DEBUG modem << +CEREG: 2,"FFFE","FFFFFFFF",9,0,0,"11100000","11100000"
    2021-06-04T10:03:09.307Z DEBUG modem << [00:01:03.043,731] [0m<inf> mqtt_simple: LTE cell changed: Cell ID: -1, Tracking area: 65534[0m
    2021-06-04T10:03:09.434Z DEBUG modem << %CESQ: 37,1,11,1
    2021-06-04T10:03:09.443Z DEBUG modem << +CEREG: 2,"61B6","090BE517",9,0,0,"11100000","11100000"
    2021-06-04T10:03:10.445Z DEBUG modem << [00:01:04.179,199] [0m<inf> mqtt_simple: LTE cell changed: Cell ID: 151774487, Tracking area: 25014[0m
    2021-06-04T10:03:38.988Z DEBUG modem << +CSCON: 1
    2021-06-04T10:03:39.993Z DEBUG modem << [00:01:33.733,917] [0m<inf> mqtt_simple: RRC mode: Connected[0m
    2021-06-04T10:03:41.333Z DEBUG modem << +CGEV: ME PDN ACT 0,0
    2021-06-04T10:03:41.343Z DEBUG modem << +CNEC_ESM: 50,0
    2021-06-04T10:03:41.351Z DEBUG modem << +CEREG: 1,"61B6","090BE517",9,,,"11100000","11100000"
    2021-06-04T10:03:41.359Z DEBUG modem << +CIND: "service",1
    2021-06-04T10:03:41.372Z DEBUG modem >> AT+CGDCONT?
    2021-06-04T10:03:41.387Z DEBUG modem << +CGDCONT: 0,"IP","nbiot","9.253.108.208",0,0
    2021-06-04T10:03:41.389Z DEBUG modem << OK
    2021-06-04T10:03:41.403Z DEBUG modem >> AT+COPS=3,2
    2021-06-04T10:03:41.413Z DEBUG modem << OK
    2021-06-04T10:03:41.430Z DEBUG modem >> AT+CGACT?
    2021-06-04T10:03:41.450Z DEBUG modem << +CGACT: 0,1
    2021-06-04T10:03:41.457Z DEBUG modem << OK
    2021-06-04T10:03:41.483Z DEBUG modem >> AT+COPS?
    2021-06-04T10:03:41.506Z DEBUG modem << +COPS: 0,2,"45204",9
    2021-06-04T10:03:41.511Z DEBUG modem << OK
    2021-06-04T10:03:41.534Z DEBUG modem >> AT%XCBAND
    2021-06-04T10:03:41.542Z DEBUG modem << %XCBAND: 3
    2021-06-04T10:03:41.544Z DEBUG modem << OK
    2021-06-04T10:03:41.563Z DEBUG modem >> AT+CGDCONT?
    2021-06-04T10:03:41.578Z DEBUG modem << +CGDCONT: 0,"IP","nbiot","9.253.108.208",0,0
    2021-06-04T10:03:41.580Z DEBUG modem << OK
    2021-06-04T10:03:41.598Z DEBUG modem >> AT+CGACT?
    2021-06-04T10:03:41.612Z DEBUG modem << +CGACT: 0,1
    2021-06-04T10:03:41.617Z DEBUG modem << OK
    2021-06-04T10:03:42.369Z DEBUG modem << [00:01:36.077,423] [0m<inf> mqtt_simple: LTE Link Connected![0m
    2021-06-04T10:03:42.370Z DEBUG modem << [00:01:36.077,545] [0m<inf> mqtt_simple: Network registration status: Connected - home network[0m
    2021-06-04T10:03:42.372Z DEBUG modem << [00:01:36.077,545] [0m<inf> mqtt_simple: PSM parameter update: TAU: -1, Active time: -1[0m
    2021-06-04T10:03:42.373Z DEBUG modem << [00:01:37.003,601] [0m<inf> mqtt_simple: IPv4 Address found 34.199.33.81[0m
    2021-06-04T10:03:42.396Z DEBUG modem << [00:01:37.004,302] [0m<dbg> nrf9160_gps.configure_antenna: MAGPIO set: AT%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200,3,824,894,4,880,960,5,791,849,7,1565,1586[0m
    2021-06-04T10:03:42.397Z DEBUG modem << [00:01:37.004,791] [0m<dbg> nrf9160_gps.configure_antenna: COEX0 set: AT%XCOEX0[0m
    2021-06-04T10:03:42.399Z DEBUG modem << [00:01:37.004,852] [0m<dbg> nrf9160_gps.open_socket: GPS socket created, fd: 1232491587[0m
    2021-06-04T10:03:42.400Z DEBUG modem << [00:01:37.004,974] [0m<inf> mqtt_simple: Start interval[0m
    2021-06-04T10:03:45.117Z DEBUG modem << [00:01:38.844,635] [0m<inf> mqtt_simple: MQTT client connected[0m
    2021-06-04T10:03:45.120Z DEBUG modem << [00:01:38.844,665] [0m<inf> mqtt_simple: Resend 0[0m
    2021-06-04T10:03:45.122Z DEBUG modem << [00:01:38.844,665] [0m<inf> mqtt_simple: Subscribing to: my/subscribe/topic len 18[0m
    2021-06-04T10:03:46.441Z DEBUG modem << [00:01:40.180,664] [0m<inf> mqtt_simple: SUBACK packet id: 1234[0m
    2021-06-04T10:03:50.591Z DEBUG modem << %CESQ: 38,1,5,0
    2021-06-04T10:03:53.446Z DEBUG modem << %CESQ: 38,1,10,1
    2021-06-04T10:04:17.004Z DEBUG modem << +CSCON: 0
    2021-06-04T10:04:18.010Z DEBUG modem << [00:02:11.752,563] [0m<inf> mqtt_simple: RRC mode: Idle[0m
    2021-06-04T10:04:23.563Z DEBUG modem << [00:02:17.255,859] [0m<inf> mqtt_simple: Enter start[0m
    2021-06-04T10:04:23.564Z DEBUG modem << [00:02:17.255,889] [0m<inf> mqtt_simple: START GPS[0m
    2021-06-04T10:04:23.566Z DEBUG modem << [00:02:17.256,652] [0m<dbg> nrf9160_gps.enable_gps: GPS mode is enabled[0m
    2021-06-04T10:04:23.567Z DEBUG modem << [00:02:17.262,542] [0m<dbg> nrf9160_gps.gps_priority_set: GPS priority disabled[0m
    2021-06-04T10:04:23.571Z DEBUG modem << [00:02:17.262,847] [0m<dbg> nrf9160_gps.start: GPS operational[0m
    2021-06-04T10:04:23.572Z DEBUG modem << [00:02:17.262,939] [0m<inf> mqtt_simple: GPS_EVT_SEARCH_STARTED[0m
    2021-06-04T10:04:23.573Z DEBUG modem << [00:02:17.263,092] [0m<dbg> nrf9160_gps.gps_thread: A-GPS data update needed[0m
    2021-06-04T10:04:23.575Z DEBUG modem << [00:02:17.263,092] [0m<inf> mqtt_simple: GPS_EVT_AGPS_DATA_NEEDED[0m
    2021-06-04T10:04:23.577Z DEBUG modem << [00:02:17.263,122] [0m<inf> agps: SUPL is initialized[0m
    2021-06-04T10:04:52.765Z DEBUG modem >> AT
    2021-06-04T10:04:53.766Z ERROR Error: 'AT
    ' timed out
    2021-06-04T10:05:06.909Z INFO Modem port is opened
    2021-06-04T10:05:06.915Z DEBUG modem >> AT+CFUN?
    2021-06-04T10:05:06.936Z DEBUG modem << +CFUN: 0
    2021-06-04T10:05:06.939Z DEBUG modem << OK
    2021-06-04T10:05:09.219Z DEBUG modem << [00:00:05.235,137] [0m<inf> mqtt_simple: The MQTT simple sample started[0m
    2021-06-04T10:05:09.222Z DEBUG modem << [00:00:05.235,168] [0m<inf> mqtt_simple: Disabling PSM and eDRX[0m
    2021-06-04T10:05:09.224Z DEBUG modem << [00:00:05.251,037] [0m<inf> mqtt_simple: LTE Link Connecting...[0m
    2021-06-04T10:05:10.150Z DEBUG modem << +CEREG: 2,"61B6","090BE517",9,0,0,"11100000","11100000"
    2021-06-04T10:05:11.160Z DEBUG modem << [00:00:07.185,882] [0m<inf> mqtt_simple: LTE cell changed: Cell ID: 151774487, Tracking area: 25014[0m
    2021-06-04T10:05:48.592Z DEBUG modem << +CEREG: 2,"FFFE","FFFFFFFF",9,0,0,"11100000","11100000"
    2021-06-04T10:05:49.601Z DEBUG modem << [00:00:45.628,784] [0m<inf> mqtt_simple: LTE cell changed: Cell ID: -1, Tracking area: 65534[0m
    2021-06-04T10:07:24.473Z DEBUG modem << +CEREG: 2,"61E6","090A8C16",9,0,0,"11100000","11100000"
    2021-06-04T10:07:25.484Z DEBUG modem << [00:02:21.513,488] [0m<inf> mqtt_simple: LTE cell changed: Cell ID: 151686166, Tracking area: 25062[0m
    2021-06-04T10:07:41.209Z DEBUG modem << +CSCON: 1
    2021-06-04T10:07:42.215Z DEBUG modem << [00:02:38.250,549] [0m<inf> mqtt_simple: RRC mode: Connected[0m
    2021-06-04T10:07:43.423Z DEBUG modem << +CEREG: 1,"61E6","090A8C16",9,,,"11100000","11100000"
    2021-06-04T10:07:43.433Z DEBUG modem >> AT+COPS=3,2
    2021-06-04T10:07:43.448Z DEBUG modem << OK
    2021-06-04T10:07:43.452Z DEBUG modem >> AT+COPS?
    2021-06-04T10:07:43.461Z DEBUG modem << +COPS: 0,2,"45204",9
    2021-06-04T10:07:43.465Z DEBUG modem << OK
    2021-06-04T10:07:43.484Z DEBUG modem >> AT%XCBAND
    2021-06-04T10:07:43.496Z DEBUG modem << %XCBAND: 3
    2021-06-04T10:07:43.500Z DEBUG modem << OK
    2021-06-04T10:07:43.516Z DEBUG modem >> AT+CGDCONT?
    2021-06-04T10:07:43.530Z DEBUG modem << +CGDCONT: 0,"IP","nbiot","11.145.69.15",0,0
    2021-06-04T10:07:43.533Z DEBUG modem << OK
    2021-06-04T10:07:43.553Z DEBUG modem >> AT+CGACT?
    2021-06-04T10:07:43.564Z DEBUG modem << +CGACT: 0,1
    2021-06-04T10:07:43.568Z DEBUG modem << OK
    2021-06-04T10:07:44.490Z DEBUG modem << [00:02:40.464,630] [0m<inf> mqtt_simple: LTE Link Connected![0m
    2021-06-04T10:07:44.492Z DEBUG modem << [00:02:40.464,721] [0m<inf> mqtt_simple: Network registration status: Connected - home network[0m
    2021-06-04T10:07:44.494Z DEBUG modem << [00:02:40.464,721] [0m<inf> mqtt_simple: PSM parameter update: TAU: -1, Active time: -1[0m
    2021-06-04T10:07:44.495Z DEBUG modem << [00:02:40.958,251] [0m<inf> mqtt_simple: IPv4 Address found 34.199.33.81[0m
    2021-06-04T10:07:44.496Z DEBUG modem << [00:02:40.958,953] [0m<dbg> nrf9160_gps.configure_antenna: MAGPIO set: AT%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200,3,824,894,4,880,960,5,791,849,7,1565,1586[0m
    2021-06-04T10:07:44.497Z DEBUG modem << [00:02:40.959,442] [0m<dbg> nrf9160_gps.configure_antenna: COEX0 set: AT%XCOEX0[0m
    2021-06-04T10:07:44.499Z DEBUG modem << [00:02:40.959,503] [0m<dbg> nrf9160_gps.open_socket: GPS socket created, fd: 1232491587[0m
    2021-06-04T10:07:44.500Z DEBUG modem << [00:02:40.959,625] [0m<inf> mqtt_simple: Start interval[0m
    2021-06-04T10:07:46.181Z DEBUG modem << [00:02:42.198,272] [0m<inf> mqtt_simple: MQTT client connected[0m
    2021-06-04T10:07:46.183Z DEBUG modem << [00:02:42.198,272] [0m<inf> mqtt_simple: Resend 0[0m
    2021-06-04T10:07:46.185Z DEBUG modem << [00:02:42.198,303] [0m<inf> mqtt_simple: Subscribing to: my/subscribe/topic len 18[0m
    2021-06-04T10:07:46.189Z DEBUG modem << [00:02:42.875,274] [0m<inf> mqtt_simple: SUBACK packet id: 1234[0m
    2021-06-04T10:07:50.627Z DEBUG modem << +CEREG: 1,"61E6","090A8C16",9,,,"00000100","00011011"
    2021-06-04T10:07:50.634Z DEBUG modem << [00:02:47.064,575] [0m<inf> mqtt_simple: Enter start[0m
    2021-06-04T10:07:50.635Z DEBUG modem << [00:02:47.064,575] [0m<inf> mqtt_simple: START GPS[0m
    2021-06-04T10:07:50.636Z DEBUG modem << [00:02:47.065,460] [0m<dbg> nrf9160_gps.enable_gps: GPS mode is enabled[0m
    2021-06-04T10:07:50.638Z DEBUG modem << [00:02:47.071,960] [0m<dbg> nrf9160_gps.gps_priority_set: GPS priority disabled[0m
    2021-06-04T10:07:50.639Z DEBUG modem << [00:02:47.072,204] [0m<dbg> nrf9160_gps.start: GPS operational[0m
    2021-06-04T10:07:50.640Z DEBUG modem << [00:02:47.072,296] [0m<inf> mqtt_simple: GPS_EVT_SEARCH_STARTED[0m
    2021-06-04T10:07:50.641Z DEBUG modem << [00:02:47.072,448] [0m<dbg> nrf9160_gps.gps_thread: A-GPS data update needed[0m
    2021-06-04T10:07:50.644Z DEBUG modem << [00:02:47.072,448] [0m<inf> mqtt_simple: GPS_EVT_AGPS_DATA_NEEDED[0m
    2021-06-04T10:07:50.646Z DEBUG modem << [00:02:47.072,479] [0m<inf> agps: SUPL is initialized[0m
    2021-06-04T10:07:50.647Z DEBUG modem << [00:02:47.604,919] [0m<inf> mqtt_simple: PSM parameter update: TAU: 16200, Active time: 8[0m
    2021-06-04T10:07:50.670Z DEBUG modem >> AT+COPS=3,2
    2021-06-04T10:07:50.678Z DEBUG modem << OK
    2021-06-04T10:07:50.690Z DEBUG modem >> AT+COPS?
    2021-06-04T10:07:50.710Z DEBUG modem << +COPS: 0,2,"45204",9
    2021-06-04T10:07:50.713Z DEBUG modem << OK
    2021-06-04T10:07:50.737Z DEBUG modem >> AT%XCBAND
    2021-06-04T10:07:50.757Z DEBUG modem << %XCBAND: 3
    2021-06-04T10:07:50.760Z DEBUG modem << OK
    2021-06-04T10:07:50.779Z DEBUG modem >> AT+CGDCONT?
    2021-06-04T10:07:50.793Z DEBUG modem << +CGDCONT: 0,"IP","nbiot","11.145.69.15",0,0
    2021-06-04T10:07:50.794Z DEBUG modem << OK
    2021-06-04T10:07:50.820Z DEBUG modem >> AT+CGACT?
    2021-06-04T10:07:50.840Z DEBUG modem << +CGACT: 0,1
    2021-06-04T10:07:50.842Z DEBUG modem << OK
    2021-06-04T10:07:52.697Z DEBUG modem << [00:02:48.733,276] [0m<inf> agps: Starting SUPL session[0m
    2021-06-04T10:08:04.547Z DEBUG modem << [00:03:00.553,649] [1;31m<err> agps: SUPL session failed, error: -13[0m
    2021-06-04T10:08:04.549Z DEBUG modem << [00:03:00.553,649] [1;31m<err> agps: SUPL request failed, error: -13[0m
    2021-06-04T10:08:04.550Z DEBUG modem << [00:03:00.553,680] [1;31m<err> mqtt_simple: Failed to request A-GPS data, error: -13[0m
    2021-06-04T10:08:04.552Z DEBUG modem << [00:03:00.553,833] [0m<dbg> nrf9160_gps.gps_thread: Waiting for time window to operate[0m
    2021-06-04T10:08:04.554Z DEBUG modem << [00:03:00.553,833] [0m<inf> mqtt_simple: GPS_EVT_OPERATION_BLOCKED[0m
    2021-06-04T10:08:28.097Z DEBUG modem << [00:03:24.133,697] [0m<inf> mqtt_simple: GPS_EVT_SEARCH_TIMEOUT[0m
    2021-06-04T10:13:04.764Z DEBUG modem >> AT
    2021-06-04T10:13:05.770Z ERROR Error: 'AT
    ' timed out
    2021-06-04T10:13:24.596Z INFO Modem port is opened
    2021-06-04T10:13:24.600Z DEBUG modem >> AT+CFUN?
    2021-06-04T10:13:24.619Z DEBUG modem << +CFUN: 0
    2021-06-04T10:13:24.622Z DEBUG modem << OK
    2021-06-04T10:13:26.926Z DEBUG modem << [00:00:05.235,168] [0m<inf> mqtt_simple: The MQTT simple sample started[0m
    2021-06-04T10:13:26.928Z DEBUG modem << [00:00:05.235,198] [0m<inf> mqtt_simple: Disabling PSM and eDRX[0m
    2021-06-04T10:13:26.929Z DEBUG modem << [00:00:05.251,098] [0m<inf> mqtt_simple: LTE Link Connecting...[0m
    2021-06-04T10:13:38.225Z DEBUG modem << +CEREG: 2,"61E6","090A8C16",9,0,0,"11100000","11100000"
    2021-06-04T10:13:38.622Z DEBUG modem << +CSCON: 1
    2021-06-04T10:13:39.241Z DEBUG modem << [00:00:17.554,443] [0m<inf> mqtt_simple: LTE cell changed: Cell ID: 151686166, Tracking area: 25062[0m
    2021-06-04T10:13:39.242Z DEBUG modem << [00:00:17.951,141] [0m<inf> mqtt_simple: RRC mode: Connected[0m
    2021-06-04T10:13:40.666Z DEBUG modem << +CEREG: 1,"61E6","090A8C16",9,,,"11100000","11100000"
    2021-06-04T10:13:40.676Z DEBUG modem >> AT+COPS=3,2
    2021-06-04T10:13:40.688Z DEBUG modem << OK
    2021-06-04T10:13:40.691Z DEBUG modem >> AT+COPS?
    2021-06-04T10:13:40.705Z DEBUG modem << +COPS: 0,2,"45204",9
    2021-06-04T10:13:40.709Z DEBUG modem << OK
    2021-06-04T10:13:40.737Z DEBUG modem >> AT%XCBAND
    2021-06-04T10:13:40.761Z DEBUG modem << %XCBAND: 3
    2021-06-04T10:13:40.763Z DEBUG modem << OK
    2021-06-04T10:13:40.771Z DEBUG modem >> AT+CGDCONT?
    2021-06-04T10:13:40.795Z DEBUG modem << +CGDCONT: 0,"IP","nbiot","9.44.235.102",0,0
    2021-06-04T10:13:40.797Z DEBUG modem << OK
    2021-06-04T10:13:40.803Z DEBUG modem >> AT+CGACT?
    2021-06-04T10:13:40.810Z DEBUG modem << +CGACT: 0,1
    2021-06-04T10:13:40.812Z DEBUG modem << OK
    2021-06-04T10:13:41.733Z DEBUG modem << [00:00:19.995,178] [0m<inf> mqtt_simple: LTE Link Connected![0m
    2021-06-04T10:13:41.735Z DEBUG modem << [00:00:19.995,300] [0m<inf> mqtt_simple: Network registration status: Connected - home network[0m
    2021-06-04T10:13:41.738Z DEBUG modem << [00:00:19.995,300] [0m<inf> mqtt_simple: PSM parameter update: TAU: -1, Active time: -1[0m
    2021-06-04T10:13:41.741Z DEBUG modem << [00:00:20.795,867] [0m<inf> mqtt_simple: IPv4 Address found 34.199.33.81[0m
    2021-06-04T10:13:41.742Z DEBUG modem << [00:00:20.796,569] [0m<dbg> nrf9160_gps.configure_antenna: MAGPIO set: AT%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200,3,824,894,4,880,960,5,791,849,7,1565,1586[0m
    2021-06-04T10:13:41.743Z DEBUG modem << [00:00:20.797,058] [0m<dbg> nrf9160_gps.configure_antenna: COEX0 set: AT%XCOEX0[0m
    2021-06-04T10:13:41.745Z DEBUG modem << [00:00:20.797,119] [0m<dbg> nrf9160_gps.open_socket: GPS socket created, fd: 1232491587[0m
    2021-06-04T10:13:41.746Z DEBUG modem << [00:00:20.797,241] [0m<inf> mqtt_simple: Start interval[0m
    2021-06-04T10:14:09.085Z DEBUG modem << [00:00:47.395,477] [0m<inf> mqtt_simple: MQTT client connected[0m
    2021-06-04T10:14:09.086Z DEBUG modem << [00:00:47.395,507] [0m<inf> mqtt_simple: Resend 0[0m
    2021-06-04T10:14:09.089Z DEBUG modem << [00:00:47.395,507] [0m<inf> mqtt_simple: Subscribing to: my/subscribe/topic len 18[0m
    2021-06-04T10:14:10.197Z DEBUG modem << [00:00:48.520,507] [0m<inf> mqtt_simple: SUBACK packet id: 1234[0m
    2021-06-04T10:14:40.538Z DEBUG modem << +CSCON: 0
    2021-06-04T10:14:41.544Z DEBUG modem << [00:01:19.869,354] [0m<inf> mqtt_simple: RRC mode: Idle[0m
    2021-06-04T10:15:01.545Z DEBUG modem << +CSCON: 1
    2021-06-04T10:15:01.547Z DEBUG modem << [00:01:40.328,277] [0m<inf> mqtt_simple: Enter start[0m
    2021-06-04T10:15:01.548Z DEBUG modem << [00:01:40.328,308] [0m<inf> mqtt_simple: START GPS[0m
    2021-06-04T10:15:01.549Z DEBUG modem << [00:01:40.329,071] [0m<dbg> nrf9160_gps.enable_gps: GPS mode is enabled[0m
    2021-06-04T10:15:01.550Z DEBUG modem << [00:01:40.334,960] [0m<dbg> nrf9160_gps.gps_priority_set: GPS priority disabled[0m
    2021-06-04T10:15:01.583Z DEBUG modem << [00:01:40.335,266] [0m<dbg> nrf9160_gps.start: GPS operational[0m
    2021-06-04T10:15:01.585Z DEBUG modem << [00:01:40.335,357] [0m<inf> mqtt_simple: GPS_EVT_SEARCH_STARTED[0m
    2021-06-04T10:15:01.587Z DEBUG modem << [00:01:40.335,510] [0m<dbg> nrf9160_gps.gps_thread: A-GPS data update needed[0m
    2021-06-04T10:15:01.590Z DEBUG modem << [00:01:40.335,510] [0m<inf> mqtt_simple: GPS_EVT_AGPS_DATA_NEEDED[0m
    2021-06-04T10:15:01.591Z DEBUG modem << [00:01:40.335,540] [0m<inf> agps: SUPL is initialized[0m
    2021-06-04T10:15:01.592Z DEBUG modem << [00:01:40.853,271] [0m<inf> mqtt_simple: RRC mode: Connected[0m
    2021-06-04T10:15:01.814Z DEBUG modem << +CEREG: 1,"61E6","090A8C16",9,,,"00000100","00011001"
    2021-06-04T10:15:01.830Z DEBUG modem >> AT+COPS=3,2
    2021-06-04T10:15:01.836Z DEBUG modem << OK
    2021-06-04T10:15:01.839Z DEBUG modem >> AT+COPS?
    2021-06-04T10:15:01.846Z DEBUG modem << +COPS: 0,2,"45204",9
    2021-06-04T10:15:01.848Z DEBUG modem << OK
    2021-06-04T10:15:01.866Z DEBUG modem >> AT%XCBAND
    2021-06-04T10:15:01.876Z DEBUG modem << %XCBAND: 3
    2021-06-04T10:15:01.879Z DEBUG modem << OK
    2021-06-04T10:15:01.897Z DEBUG modem >> AT+CGDCONT?
    2021-06-04T10:15:01.910Z DEBUG modem << +CGDCONT: 0,"IP","nbiot","9.44.235.102",0,0
    2021-06-04T10:15:01.912Z DEBUG modem << OK
    2021-06-04T10:15:01.931Z DEBUG modem >> AT+CGACT?
    2021-06-04T10:15:01.949Z DEBUG modem << +CGACT: 0,1
    2021-06-04T10:15:01.953Z DEBUG modem << OK
    2021-06-04T10:15:02.214Z DEBUG modem << +CSCON: 0
    2021-06-04T10:15:02.828Z DEBUG modem << [00:01:41.146,179] [0m<inf> mqtt_simple: PSM parameter update: TAU: 15000, Active time: 8[0m
    2021-06-04T10:15:02.829Z DEBUG modem << [00:01:41.545,898] [0m<inf> mqtt_simple: RRC mode: Idle[0m
    2021-06-04T10:15:03.474Z DEBUG modem << +CSCON: 1
    2021-06-04T10:15:04.486Z DEBUG modem << [00:01:42.806,335] [0m<inf> mqtt_simple: RRC mode: Connected[0m
    2021-06-04T10:15:04.488Z DEBUG modem << [00:01:43.766,693] [0m<inf> agps: Starting SUPL session[0m
    2021-06-04T10:15:16.475Z DEBUG modem << [00:01:54.772,155] [1;31m<err> agps: SUPL session failed, error: -13[0m
    2021-06-04T10:15:16.477Z DEBUG modem << [00:01:54.772,186] [1;31m<err> agps: SUPL request failed, error: -13[0m
    2021-06-04T10:15:16.478Z DEBUG modem << [00:01:54.772,186] [1;31m<err> mqtt_simple: Failed to request A-GPS data, error: -13[0m
    2021-06-04T10:15:16.480Z DEBUG modem << [00:01:54.772,369] [0m<dbg> nrf9160_gps.gps_thread: Waiting for time window to operate[0m
    2021-06-04T10:15:16.481Z DEBUG modem << [00:01:54.772,369] [0m<inf> mqtt_simple: GPS_EVT_OPERATION_BLOCKED[0m
    2021-06-04T10:17:07.304Z DEBUG modem << [00:03:45.635,467] [0m<inf> mqtt_simple: GPS_EVT_SEARCH_TIMEOUT[0m
    2021-06-04T10:17:31.770Z DEBUG modem >> AT+CSCON?
    2021-06-04T10:17:31.782Z DEBUG modem << +CSCON: 1,1
    2021-06-04T10:17:31.784Z DEBUG modem << OK
    2021-06-04T10:18:57.387Z DEBUG modem << +CSCON: 0
    2021-06-04T10:18:58.392Z DEBUG modem << [00:05:36.729,400] [0m<inf> mqtt_simple: RRC mode: Idle[0m
    2021-06-04T10:19:17.094Z DEBUG modem << +CEREG: 1,"61B6","090BE517",9,,,"00000100","00011001"
    2021-06-04T10:19:17.722Z DEBUG modem >> AT+COPS=3,2
    2021-06-04T10:19:17.729Z DEBUG modem << OK
    2021-06-04T10:19:18.105Z DEBUG modem << [00:05:56.438,049] [0m<inf> mqtt_simple: LTE cell changed: Cell ID: 151774487, Tracking area: 25014[0m
    2021-06-04T10:19:18.724Z DEBUG modem >> AT+COPS?
    2021-06-04T10:19:18.733Z DEBUG modem << +COPS: 0,2,"45204",9
    2021-06-04T10:19:18.734Z DEBUG modem << OK
    2021-06-04T10:19:19.096Z DEBUG modem << +CSCON: 1
    I'm trying to find a solution to this issue, and am currently working with our developers.
    The initial question is: Have you tried implementing MQTT to the AGPS sample? If this sample works as intended, then maybe that would be an easier work-around.
     Our SUPL expert had a look at you case, and says:
    It seems that device gets some A-GPS data and writes that to the modem. It seems as if it couldn't read all of the data or something like that.
    It takes a long time, so it can't be executed for example in the button handler directly. It should be ran in a separate thread. And the proper way to do it would be to fetch A-GPS data when GNSS asks for it. GPS driver sends event GPS_EVT_AGPS_DATA_NEEDED when it needs A-GPS data. That event contains a structure of type gps_agps_request which indicates what kind of A-GPS data GNSS needs. They should check the AGPS sample, it triggers the fetching of A-GPS data when GPS_EVT_AGPS_DATA_NEEDED is received by the event handler.
    Øyvind
    If I use a config like the AGPS example, then I can use mqtt_simple with AGPS feature on mqtt_simple example base.
