BLE demo with UART not working
Hi there,
I was able to successfully compile and run the "BLE HIDS keyboard" example on my nRF52832 using Segger SES 5.44
My Nordic chip is connected via UART Rx/Tx to another MSP430 and I like to send some data bytes from the MSP to the Nordic chip. So I checked the various UART examples in the nRF5 SDK 17.0.2 (which we want to use) and added some Uart code to the HIDS keyboard example. My hardware is similar to pca10040, but its not identical. I also have a Led connected to Port P0.17 so I can see the blinking code while BLE advertising is active etc
Withoutn Uart code , the Nordic chip starts, I can see the Led blinking and then the device is advertising and I can connect my smartphone - for diagnostics I'm using the "nRF connect" app which works well.
With Uart, my main() routine includes a call to a uart_init() routine which basically calls APP_UART_FIFO_INIT() - without this call, the Nordic chip works well as explained above, when calling this APP_UART_FIFO_INIT(), the Led goes solid on and I'm not able to connect to the device in any way.
Comm Params are like this
static void uart_init(void)
    uint32_t  err_code;
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .rts_pin_no   = RTS_PIN_NUMBER,
        .cts_pin_no   = CTS_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_57600
    if (1)
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_event_handle,
                         APP_IRQ_PRIORITY_HIGH,
                         err_code);
I checked, as good as possible, the settings in sdk_config.h but I can't find out why the device is not working with Uart.
Any idea what might be missing ?
thanks, Matthias
