nRF9160 behavior when changing mode and switching SIM
We are currently trying to create a small test code to test multiple operator with different modes:
- lte-m1 or lte-nb1
- edrx 0s, 5.12s, 10.24s
- with and without psm
Our board has multiple SIM slot, with a SIM switch rerouting the SIM_xxx signals from the nRF9160.
After an initial lte_lc_init(), we setup the link control to use the configuration for the test.
Then we wait for a connection, turn the modem off, reconfigure the modem etc...
for (int i = 0; i < ARRAY_SIZE(test); i++) {
	const struct test_data *data = &test[i];
	LOG_WRN("====Starting test %d in 3 seconds=====", i);
	k_sleep(K_SECONDS(3));
	lte_lc_system_mode_set(data->mode, 0);
	lte_lc_psm_req(false);
	if (!data->use_edrx) {
		lte_lc_edrx_req(false);
	else {
		lte_lc_edrx_param_set(LTE_LC_LTE_MODE_LTEM,
			data->ltem_edrx_value);
		lte_lc_edrx_param_set(LTE_LC_LTE_MODE_NBIOT,
			data->nbiot_edrx_value);
		lte_lc_edrx_req(true);
	err = lte_lc_connect();
	if (err) {
		LOG_ERR("Test %d fails: no connection", i);
	else {
		LOG_WRN("Connected ! Checking eDRX value");
		at_cmd_write("AT+CEDRXRDP", NULL, 0, NULL);
		k_sleep(K_SECONDS(2));
	LOG_WRN("====Test %d done. "
		"Starting next one in 10 seconds====", i);
	lte_lc_power_off();
	k_sleep(K_SECONDS(10));
Once we are done with a SIM card, we turn off the modem, switch sim card and we go again.
The main issue that we have is that the modem is not reliable at all in that configuration.
Sometimes, a SIM card can connect when we start the test with it, but if it's the second SIM card to be tested, the connection is stuck at +CEREG=2 forever (literally)
With CONFIG_LTE_NETWORK_TIMEOUT=90, I would expect the connection to return an error once the timeout is reached, but not stuck forever.
What is the correct workflow to set the modem in multiple configuration in a short amount of time without the firmware being unreliable ?
Regards
Giuliano
  • Here is the newest log.
    Same thing, test stopped after 10 min without any more logs
    [00:00:00.222,534] <dbg> at_cmd.at_cmd_driver_init: Common AT socket created
    [00:00:00.222,961] <dbg> at_cmd.at_cmd_driver_init: Common AT socket processing thread created
    [00:00:00.223,419] <dbg> at_cmd.at_cmd_set_notification_handler: Setting notification handler to 0x156a5
    [00:00:00.223,937] <wrn> app: Starting test in 10 seconds
    [00:00:00.224,304] <dbg> at_cmd.socket_thread_fn: AT socket thread started
    [00:00:00.224,700] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:00.225,097] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:10.224,334] <inf> pwr_mngr: Pin 14 set to 0
    [00:00:10.224,700] <wrn> app: ====Calling lte_lc_init()====
    [00:00:10.225,067] <dbg> at_cmd.at_write: Sending command AT%XSYSTEMMODE?
    [00:00:10.231,750] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%XSYSTEMMODE?
    [00:00:10.234,649] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 28 bytes, %XSYSTEMMODE: 1,0,0,0
    OK
    [00:00:10.235,137] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:10.235,778] <dbg> lte_lc.init_and_config: System mode (1) and preference (0) are already configured
    [00:00:10.236,328] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%XMODEMTRACE=1,2
    [00:00:10.236,785] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:10.237,213] <dbg> at_cmd.at_write: Sending command AT%XMODEMTRACE=1,2
    [00:00:10.240,844] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:10.243,957] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:10.244,384] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:10.244,842] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CEREG=5
    [00:00:10.245,269] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:10.251,312] <dbg> at_cmd.at_write: Sending command AT+CEREG=5
    [00:00:10.257,995] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:10.260,131] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:10.260,559] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:10.261,016] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CSCON=1
    [00:00:10.261,474] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:10.261,871] <dbg> at_cmd.at_write: Sending command AT+CSCON=1
    [00:00:10.266,357] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:10.268,524] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:10.279,510] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:10.279,968] <wrn> app: ====Using SIM 0====
    [00:00:10.280,303] <wrn> app: ====Starting test 0 in 3 seconds=====
    [00:00:10.280,700] <wrn> app: Mode: 1, edrx: 1, ltem: 0001, nbiot: 0001
    [00:00:10.281,127] <wrn> app: ====Registering %XSIM urc====
    [00:00:10.281,494] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%XSIM=1
    [00:00:10.281,951] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:10.282,348] <dbg> at_cmd.at_write: Sending command AT%XSIM=1
    [00:00:10.289,031] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:10.291,168] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:10.291,595] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:10.302,612] <wrn> app: ====Registering %CESQ urc====
    [00:00:10.303,009] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%CESQ=1
    [00:00:10.303,436] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:10.303,833] <dbg> at_cmd.at_write: Sending command AT%CESQ=1
    [00:00:10.310,516] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:10.312,652] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:10.313,079] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:10.313,507] <wrn> app: ====Registering %MDEV urc====
    [00:00:10.313,903] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%MDEV=1
    [00:00:10.314,331] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:10.314,758] <dbg> at_cmd.at_write: Sending command AT%MDEV=1
    [00:00:10.318,847] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:10.320,831] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 8 bytes, ERROR
    [00:00:10.331,848] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:10.332,275] <wrn> app: ====Registering +CMEE urc====
    [00:00:10.332,641] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CMEE=1
    [00:00:10.333,099] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:10.333,496] <dbg> at_cmd.at_write: Sending command AT+CMEE=1
    [00:00:10.340,148] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:10.342,285] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:10.342,712] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:10.343,170] <wrn> app: ====Registering +CNEC urc====
    [00:00:10.343,536] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CNEC=24
    [00:00:10.343,963] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:10.344,390] <dbg> at_cmd.at_write: Sending command AT+CNEC=24
    [00:00:10.366,577] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:10.368,713] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:10.369,140] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:10.369,628] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:10.370,025] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:13.369,689] <dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=1,0,0,0
    [00:00:13.370,239] <dbg> at_cmd.at_write: Sending command AT%XSYSTEMMODE=1,0,0,0
    [00:00:13.376,953] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%XSYSTEMMODE=1,0,0,0
    [00:00:13.382,385] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:13.382,812] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:13.383,270] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CPSMS=
    [00:00:13.383,697] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:13.384,124] <dbg> at_cmd.at_write: Sending command AT+CPSMS=
    [00:00:13.388,580] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:13.391,021] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:13.391,448] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:13.391,906] <dbg> lte_lc.lte_lc_edrx_param_set: eDRX set to 0001 for LTE-M
    [00:00:13.392,333] <dbg> lte_lc.lte_lc_edrx_param_set: eDRX set to 0001 for NB-IoT
    [00:00:13.392,822] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CEDRXS=2,4,"0001"
    [00:00:13.393,310] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:13.393,707] <dbg> at_cmd.at_write: Sending command AT+CEDRXS=2,4,"0001"
    [00:00:13.397,247] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:13.399,810] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:13.400,238] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:13.400,756] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CEDRXS=2,5,"0001"
    [00:00:13.406,829] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:13.407,257] <dbg> at_cmd.at_write: Sending command AT+CEDRXS=2,5,"0001"
    [00:00:13.413,940] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:13.416,198] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:13.416,625] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:13.417,114] <dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=1,0,0,0
    [00:00:13.417,663] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%XSYSTEMMODE=1,0,0,0
    [00:00:13.418,121] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:13.434,143] <dbg> at_cmd.at_write: Sending command AT%XSYSTEMMODE=1,0,0,0
    [00:00:13.440,826] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:13.446,228] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:13.446,655] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:13.447,113] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CEREG=5
    [00:00:13.447,540] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:13.447,967] <dbg> at_cmd.at_write: Sending command AT+CEREG=5
    [00:00:13.452,423] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:13.454,589] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:13.455,017] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:13.455,474] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CSCON=1
    [00:00:13.455,902] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:13.461,944] <dbg> at_cmd.at_write: Sending command AT+CSCON=1
    [00:00:13.468,627] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:13.470,794] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:13.471,191] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:13.471,679] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CFUN=1
    [00:00:13.472,137] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:13.472,534] <dbg> at_cmd.at_write: Sending command AT+CFUN=1
    [00:00:13.476,989] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:13.535,522] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:13.535,949] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:13.536,407] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:13.536,834] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:14.555,664] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 11 bytes, %XSIM: 1
    [00:00:14.557,403] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:14.558,410] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:14.559,448] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 18 bytes, %CESQ: 64,3,9,1
    [00:00:14.561,401] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:14.561,828] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:14.562,286] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 58 bytes, +CEREG: 2,"767C","07F0E208",7,0,0,"11100000","11100000"
    [00:00:14.562,866] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 2,"767C","07F0E208",7,0,0,"11100000","11100000"
    [00:00:14.563,690] <dbg> lte_lc_helpers.parse_cereg: Network registration status: 2
    [00:00:14.564,147] <dbg> lte_lc_helpers.parse_cereg: LTE mode: 7
    [00:00:14.564,636] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:14.593,017] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:14.593,475] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 19 bytes, %CESQ: 65,3,19,2
    [00:00:14.593,963] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:14.594,390] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:14.594,818] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 12 bytes, +CSCON: 1
    [00:00:14.595,275] <dbg> lte_lc.at_handler: +CSCON notification
    [00:00:14.595,794] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:14.596,191] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:15.173,065] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 19 bytes, %CESQ: 65,3,24,3
    [00:00:15.173,553] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:15.173,980] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:16.501,312] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 18 bytes, +CNEC_ESM: 50,0
    [00:00:16.501,800] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:16.502,227] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:16.502,655] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 56 bytes, +CEREG: 5,"767C","07F0E208",7,,,"11100000","11100000"
    [00:00:16.503,265] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 5,"767C","07F0E208",7,,,"11100000","11100000"
    [00:00:16.504,028] <dbg> lte_lc_helpers.parse_cereg: Network registration status: 5
    [00:00:16.504,486] <dbg> lte_lc_helpers.parse_cereg: LTE mode: 7
    [00:00:16.504,882] <dbg> lte_lc_helpers.parse_psm: TAU: -1 sec, active time: -1 sec
    [00:00:16.505,432] <wrn> app: Connected ! Checking eDRX value
    [00:00:16.505,828] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:16.506,256] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:16.521,575] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 16 bytes, +CNEC_EMM: 13
    [00:00:16.522,064] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:16.522,491] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:17.907,073] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 12 bytes, +CSCON: 0
    [00:00:17.908,203] <dbg> lte_lc.at_handler: +CSCON notification
    [00:00:17.908,691] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:17.909,118] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:17.937,713] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 21 bytes, %CESQ: 255,0,255,0
    [00:00:17.968,414] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:17.968,841] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:17.969,299] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 59 bytes, +CEREG: 2,"FFFE","FFFFFFFF",7,0,13,"11100000","11100000"
    [00:00:17.970,550] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 2,"FFFE","FFFFFFFF",7,0,13,"11100000","11100000"
    [00:00:17.971,374] <dbg> lte_lc_helpers.parse_cereg: Network registration status: 2
    [00:00:17.971,832] <dbg> lte_lc_helpers.parse_cereg: LTE mode: 7
    [00:00:17.972,290] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:17.972,717] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:18.506,835] <dbg> at_cmd.at_write: Sending command AT+CEDRXRDP
    [00:00:18.507,415] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CEDRXRDP
    [00:00:18.509,796] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 32 bytes, +CEDRXRDP: 4,"0001","",""
    OK
    [00:00:18.510,620] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:18.511,108] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:18.511,535] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:20.511,138] <dbg> at_cmd.at_write: Sending command AT+CEDRXRDP
    [00:00:20.511,718] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CEDRXRDP
    [00:00:20.518,432] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 32 bytes, +CEDRXRDP: 4,"0001","",""
    OK
    [00:00:20.518,920] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:20.519,378] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:20.519,805] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:22.519,439] <dbg> at_cmd.at_write: Sending command AT+CEDRXRDP
    [00:00:22.526,153] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CEDRXRDP
    [00:00:22.529,174] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 32 bytes, +CEDRXRDP: 4,"0001","",""
    OK
    [00:00:22.529,663] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:22.530,120] <wrn> app: ====Test 0 done. Starting next one in 10 seconds====
    [00:00:22.530,609] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CFUN=0
    [00:00:22.531,036] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:22.531,463] <dbg> at_cmd.at_write: Sending command AT+CFUN=0
    [00:00:22.535,369] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:22.564,544] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 59 bytes, +CEREG: 0,"FFFE","FFFFFFFF",7,0,13,"11100000","11100000"
    [00:00:22.565,795] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 0,"FFFE","FFFFFFFF",7,0,13,"11100000","11100000"
    [00:00:22.566,619] <dbg> lte_lc_helpers.parse_cereg: Network registration status: 0
    [00:00:22.567,077] <dbg> lte_lc_helpers.parse_cereg: LTE mode: 7
    [00:00:22.567,535] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:22.567,962] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:22.653,198] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 11 bytes, %XSIM: 0
    [00:00:22.653,656] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:22.654,083] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:22.716,918] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:22.717,346] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:22.717,834] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:22.718,231] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:32.717,834] <wrn> app: ====Starting test 1 in 3 seconds=====
    [00:00:32.718,261] <wrn> app: Mode: 2, edrx: 1, ltem: 0001, nbiot: 0001
    [00:00:32.718,688] <wrn> app: ====Registering %XSIM urc====
    [00:00:32.719,055] <dbg> at_cmd.at_write: Sending command AT%XSIM=1
    [00:00:32.725,738] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%XSIM=1
    [00:00:32.729,614] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:32.730,010] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:32.730,468] <wrn> app: ====Registering %CESQ urc====
    [00:00:32.730,834] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%CESQ=1
    [00:00:32.731,292] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:32.731,689] <dbg> at_cmd.at_write: Sending command AT%CESQ=1
    [00:00:32.735,809] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:32.737,976] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:32.738,372] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:32.738,830] <wrn> app: ====Registering %MDEV urc====
    [00:00:32.739,196] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%MDEV=1
    [00:00:32.739,654] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:32.750,671] <dbg> at_cmd.at_write: Sending command AT%MDEV=1
    [00:00:32.757,324] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:32.759,307] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 8 bytes, ERROR
    [00:00:32.759,735] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:32.760,192] <wrn> app: ====Registering +CMEE urc====
    [00:00:32.760,559] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CMEE=1
    [00:00:32.760,986] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:32.761,413] <dbg> at_cmd.at_write: Sending command AT+CMEE=1
    [00:00:32.765,502] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:32.767,669] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:32.768,066] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:32.768,524] <wrn> app: ====Registering +CNEC urc====
    [00:00:32.774,536] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CNEC=24
    [00:00:32.774,963] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:32.775,390] <dbg> at_cmd.at_write: Sending command AT+CNEC=24
    [00:00:32.782,073] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:32.784,240] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:32.784,667] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:32.785,125] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:32.785,552] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:35.785,186] <dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=0,1,0,0
    [00:00:35.785,736] <dbg> at_cmd.at_write: Sending command AT%XSYSTEMMODE=0,1,0,0
    [00:00:35.792,419] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%XSYSTEMMODE=0,1,0,0
    [00:00:35.797,851] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:35.798,248] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:35.798,736] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CPSMS=
    [00:00:35.799,163] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:35.799,560] <dbg> at_cmd.at_write: Sending command AT+CPSMS=
    [00:00:35.804,046] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:35.806,488] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:35.806,915] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:35.807,373] <dbg> lte_lc.lte_lc_edrx_param_set: eDRX set to 0001 for LTE-M
    [00:00:35.807,800] <dbg> lte_lc.lte_lc_edrx_param_set: eDRX set to 0001 for NB-IoT
    [00:00:35.808,288] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CEDRXS=2,4,"0001"
    [00:00:35.814,392] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:35.814,819] <dbg> at_cmd.at_write: Sending command AT+CEDRXS=2,4,"0001"
    [00:00:35.821,502] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:35.823,760] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:35.824,188] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:35.824,707] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CEDRXS=2,5,"0001"
    [00:00:35.830,780] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:35.831,207] <dbg> at_cmd.at_write: Sending command AT+CEDRXS=2,5,"0001"
    [00:00:35.837,890] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:35.840,454] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:35.840,881] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:35.841,369] <dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=0,1,0,0
    [00:00:35.841,918] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%XSYSTEMMODE=0,1,0,0
    [00:00:35.842,376] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:35.842,803] <dbg> at_cmd.at_write: Sending command AT%XSYSTEMMODE=0,1,0,0
    [00:00:35.846,649] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:35.852,081] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:35.852,508] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:35.852,966] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CEREG=5
    [00:00:35.853,393] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:35.859,436] <dbg> at_cmd.at_write: Sending command AT+CEREG=5
    [00:00:35.866,119] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:35.868,286] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:35.868,682] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:35.869,171] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CSCON=1
    [00:00:35.869,598] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:35.870,025] <dbg> at_cmd.at_write: Sending command AT+CSCON=1
    [00:00:35.874,481] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:35.876,647] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:35.887,664] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:35.888,153] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CFUN=1
    [00:00:35.888,580] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:35.889,007] <dbg> at_cmd.at_write: Sending command AT+CFUN=1
    [00:00:35.895,660] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:35.955,535] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:00:35.955,963] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:00:35.956,420] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:35.956,848] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:00:36.895,690] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 11 bytes, %XSIM: 1
    [00:00:36.896,179] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:00:36.896,575] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:05.956,451] <inf> lte_lc: Network connection attempt timed out
    [00:02:05.956,848] <err> app: Test 1 fails: no connection
    [00:02:05.957,214] <wrn> app: ====Test 1 done. Starting next one in 10 seconds====
    [00:02:05.957,672] <dbg> at_cmd.at_write: Sending command AT+CFUN=0
    [00:02:05.958,251] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CFUN=0
    [00:02:06.020,172] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 58 bytes, +CEREG: 0,"FFFE","FFFFFFFF",9,0,0,"11100000","11100000"
    [00:02:06.020,751] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 0,"FFFE","FFFFFFFF",9,0,0,"11100000","11100000"
    [00:02:06.021,545] <dbg> lte_lc_helpers.parse_cereg: Network registration status: 0
    [00:02:06.022,003] <dbg> lte_lc_helpers.parse_cereg: LTE mode: 9
    [00:02:06.022,491] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:06.022,918] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:06.023,345] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 11 bytes, %XSIM: 0
    [00:02:06.023,834] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:06.024,230] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:07.282,104] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:02:07.282,531] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:02:07.282,989] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:07.283,416] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:17.283,020] <wrn> app: ====Using SIM 1====
    [00:02:17.283,386] <wrn> app: ====Starting test 0 in 3 seconds=====
    [00:02:17.283,782] <wrn> app: Mode: 1, edrx: 1, ltem: 0001, nbiot: 0001
    [00:02:17.284,210] <wrn> app: ====Registering %XSIM urc====
    [00:02:17.284,576] <dbg> at_cmd.at_write: Sending command AT%XSIM=1
    [00:02:17.291,259] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%XSIM=1
    [00:02:17.293,853] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:02:17.294,281] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:02:17.294,708] <wrn> app: ====Registering %CESQ urc====
    [00:02:17.295,104] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%CESQ=1
    [00:02:17.295,532] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:17.295,959] <dbg> at_cmd.at_write: Sending command AT%CESQ=1
    [00:02:17.300,048] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:17.302,215] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:02:17.302,612] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:02:17.303,070] <wrn> app: ====Registering %MDEV urc====
    [00:02:17.303,466] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%MDEV=1
    [00:02:17.303,894] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:17.314,910] <dbg> at_cmd.at_write: Sending command AT%MDEV=1
    [00:02:17.321,563] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:17.323,547] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 8 bytes, ERROR
    [00:02:17.323,974] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:02:17.324,401] <wrn> app: ====Registering +CMEE urc====
    [00:02:17.324,798] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CMEE=1
    [00:02:17.325,225] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:17.325,653] <dbg> at_cmd.at_write: Sending command AT+CMEE=1
    [00:02:17.329,742] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:17.331,909] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:02:17.332,336] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:02:17.332,763] <wrn> app: ====Registering +CNEC urc====
    [00:02:17.343,750] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CNEC=24
    [00:02:17.344,177] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:17.344,604] <dbg> at_cmd.at_write: Sending command AT+CNEC=24
    [00:02:17.351,257] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:17.353,424] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:02:17.353,820] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:02:17.354,309] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:17.354,736] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:20.354,370] <dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=1,0,0,0
    [00:02:20.354,919] <dbg> at_cmd.at_write: Sending command AT%XSYSTEMMODE=1,0,0,0
    [00:02:20.361,602] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%XSYSTEMMODE=1,0,0,0
    [00:02:20.367,034] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:02:20.367,431] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:02:20.367,889] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CPSMS=
    [00:02:20.368,347] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:20.368,743] <dbg> at_cmd.at_write: Sending command AT+CPSMS=
    [00:02:20.373,229] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:20.375,671] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:02:20.376,098] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:02:20.376,556] <dbg> lte_lc.lte_lc_edrx_param_set: eDRX set to 0001 for LTE-M
    [00:02:20.376,983] <dbg> lte_lc.lte_lc_edrx_param_set: eDRX set to 0001 for NB-IoT
    [00:02:20.377,502] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CEDRXS=2,4,"0001"
    [00:02:20.377,960] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:20.378,387] <dbg> at_cmd.at_write: Sending command AT+CEDRXS=2,4,"0001"
    [00:02:20.381,896] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:20.384,460] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:02:20.384,887] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:02:20.385,406] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CEDRXS=2,5,"0001"
    [00:02:20.391,479] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:20.391,906] <dbg> at_cmd.at_write: Sending command AT+CEDRXS=2,5,"0001"
    [00:02:20.398,590] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:20.400,848] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:02:20.401,275] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:02:20.401,763] <dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=1,0,0,0
    [00:02:20.402,313] <dbg> at_cmd.at_cmd_write: Awaiting response for AT%XSYSTEMMODE=1,0,0,0
    [00:02:20.402,801] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:20.408,843] <dbg> at_cmd.at_write: Sending command AT%XSYSTEMMODE=1,0,0,0
    [00:02:20.415,527] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:20.420,989] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:02:20.421,417] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:02:20.421,875] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CEREG=5
    [00:02:20.422,332] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:20.422,729] <dbg> at_cmd.at_write: Sending command AT+CEREG=5
    [00:02:20.427,215] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:20.429,382] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:02:20.429,809] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:02:20.430,267] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CSCON=1
    [00:02:20.430,694] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:20.431,121] <dbg> at_cmd.at_write: Sending command AT+CSCON=1
    [00:02:20.435,577] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:20.437,744] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:02:20.438,171] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:02:20.438,659] <dbg> at_cmd.at_cmd_write: Awaiting response for AT+CFUN=1
    [00:02:20.439,086] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:20.439,514] <dbg> at_cmd.at_write: Sending command AT+CFUN=1
    [00:02:20.443,939] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:20.502,044] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK
    [00:02:20.502,471] <dbg> at_cmd.socket_thread_fn: Enqueueing response for sync call
    [00:02:20.502,929] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:20.503,356] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:23.268,188] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 11 bytes, %XSIM: 1
    [00:02:23.268,676] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:23.269,104] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:52.697,113] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 19 bytes, %CESQ: 54,2,14,2
    [00:02:52.721,343] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:52.721,771] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:52.722,198] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 58 bytes, +CEREG: 2,"07A1","00A12301",7,0,0,"11100000","11100000"
    [00:02:52.722,808] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 2,"07A1","00A12301",7,0,0,"11100000","11100000"
    [00:02:52.723,602] <dbg> lte_lc_helpers.parse_cereg: Network registration status: 2
    [00:02:52.724,090] <dbg> lte_lc_helpers.parse_cereg: LTE mode: 7
    [00:02:52.724,548] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:52.724,975] <dbg> at_cmd.socket_thread_fn: Listening on socket
    [00:02:52.905,639] <dbg> at_cmd.socket_thread_fn: at_cmd_rx 12 bytes, +CSCON: 1
    [00:02:52.906,097] <dbg> lte_lc.at_handler: +CSCON notification
    [00:02:52.906,585] <dbg> at_cmd.socket_thread_fn: Writing any pending command
    [00:02:52.907,012] <dbg> at_cmd.socket_thread_fn: Listening on socket
  • Hi Didrik,
    I've tried to add RTT as trace output. Here is the result of my test.
    Please tell me if the traces are correctly formatted and understandable.
    If so, I'll do a pull request on sdk-nrf to add that functionality to the tree
    Regards
    Giuliano
    nrf9160_modem.zip
  • I will look more at the trace tomorrow, but yes, it seems to be valid.
    The error rate was a bit higher than normal, but I don't know how much of a problem that really is. From my quick look, it seemed like most of the information was there.
    How long did you trace? Looking at the timestamps in the trace, there is ~2 minutes of traces in the file. Is that correct?
    On a different note, that trace is from mfw 1.2.3, not mfw 1.3.0.
  • The program ran for something like 10 to 15 minutes. As said earlier, it really seems that the program freezes.
    As for the modem version, our program crashes at startup with the latest version. Maybe it has some incompatibility between our NCS version and/or our nRF9160 chip version (which is quite old right now)
  • Hi Didrik,
    Did you had time to analyze the logs to find the cause of the nrf9160 lock?
    Are they correctly formatted ?
    Regards
    Giuliano
