The nRF52 bonded device is automatically unbonded when the Android phone is rebooted.
Hello!
I am developing an application which is connecting to an nRF52 board using the Android-BLE-Library implemented by Nordic
The application is doing the following:
  1. Perform an LE scan using Google's recommended Android stock class, which is BluetoothLeScanner, to scan for the board -> as a result the nRF52 board is found by the BluetoothLeScanner
  2. The app is sending a connect request to the nRF52 board -> as a result it successfully connects
  3. Then the application performs a write with response request to a characterisc which require bonding - in my case I am performing a write request to enable the indications on a secure characteristic
  4. Since it is a secure writing, and the board is requesting bonding, the Android framework will automaticaly initiate the bonding - no code required on the Android app side to perform the bond -> as a result the bond succedes and then I get the write response back that the write completed successfully
  5. I check the bonded devices list in the Android Bluetooth setting screen and the nRF52 board is listed
  6. I reboot the phone. When the phone is rebooted I check again the Bluetooth settings screen and the nRF board is still listed
The FW team did the following changes in one monolithic commit, on the FW side:
  • in prj.conf file the following line was added: CONFIG_BT_PRIVACY=y
  • for the secure characteristics, in the BT_GATT_CHARACTERISTIC(...) the 3rd parameter was changed from BT_GATT_PERM_WRITE_AUTHEN into BT_GATT_PERM_WRITE_ENCRYPT for writing and from BT_GATT_PERM_READ_AUTHEN into BT_GATT_PERM_READ_ENCRYPT for reading
  • the initial two steps bonding with numerical confirmation was changed into one step just-works bonding
  • and some othere changes which I couldn't figure out what those means
Now it comes the problem. After these changes all the steps above where successfull except step 6 - after rebooting, the device was not listed anymore in the bonded devices list in Bluetooth settings screen. So before rebooting the device was listed, after rebooting the device was automatically unbonded.
Is it possible that any of the changes the FW team did could lead to this behaviour?
Is it possible that I am doing something wrong on the app side?
Thank you!
  • I could only find one log file here?
    Unfortunately you likely forgot to select the device you wanted to sniff from the device list:
    https://infocenter.nordicsemi.com/topic/ug_sniffer_ble/UG/sniffer_ble/action_advertisement.html
    Please do that.
    Tip: In the filter text box you can add the following: "btle.data_header.llid > 0 && btle.length > 0" Then you should see in specific when connected when there is data between the central and peripheral, if you can't see anything with this filter, then it means you have not been able to pick up the communication.
    Kenneth
  • Yeah, I noticed after posting.
    Here are the correct files:
    The file named triggered is when the bug happened, notTriggered is the same procedure (except maybe not with step 5 above) but the bug did not happen, peripheral remained after reboot of the phone
    Edit: looking at the logs it seems the setup of encryption fails for some reason, it is worth noting that I did not see a disconnect on the peripheral side before pulling power.
    NOTtriggered.pcapng triggered.pcapng
  • Here is a third log where encryption seemingly succeed, but the bug was still triggered. Unfortunately it seems that the sniffer failed to capture the encryption keys. And despite several more runs the sniffer failed each time
    I've also added a fourth log, it is an bt snoop log from android from a run where the bug was triggered. If I'm reading it correctly, then encryption succeed in that case.
    Please let me know if there is anything else you need in order to be able to help us solve this bug.
    firstTriggeredButEncrypted.pcapng
    btsnoop�� ?u��� ?u�� ?u��� ?u�<� ?u��3��
    � ?u�!3� ?u�{� ?u��		�� ?u�
    � ?u�
    	�DnFP�� ?u��GG� ?vD�������������?���a���� ��������� ?v�� ?v������?[�� ?v�V� ?v
    �V� ?v�m� ?v
    �m� ?v�� ?v?� ?vN� ?v�U� ?v�S�� ?v�S�( a � ?v{z� ?v]z� ?v� � ?v � �� ?v"'
    � ?v$- �� ?v$� � ?v&� ������ ?v'1 � ?v)� �}� ?v*W* � ?v,f*  � ?v-�/ � ?v/�/ ��B��B� ?v1�# � ?v4e# H� ?v5�: 		� ?v7�: r� ?v9; � ?v;C; � ?v;� � ?v>� � ?v@��������=� ?vCr� ?vC�� ?vFl� ?vI) � ?vL�) � ?vM. �� ?vO. � ?vO^E� ?vQ_E� ?vQ�G� ?vSwG� ?vS�C� ?vVC� ?vVW$Z� ?vX$� ?vXs � ?vZ� ?vZ\� ?v^�� ?v_5S�� ?va�S�( a � ?vbg��� ?vhN���� ?vj��wbt� ?vre��� ?vr�R�	wbt�� ?vx�R� ?vx� � ?v{4 �mw����� ?v{iR�	wbt�� ?v��R
    � ?v�) E���m� ?v�j � ?{�&`� ?{�&��� ?{}R�	wbt�� ?{�R��� ?{�R�	wbt�� ?{"SR��� ?{r�R�	wbt	�� ?{x�R��� ?{y�R�	wbt
    �� ?{IR��� ?{�R�	wbt
    �� ?{��R� ?{��:3��� ?{�E:� ?{��� ?{��� ?{�� ?{�+� ?{�`� ?{��� ?{�G� ?{�1� ?{��� ?{��� ?{��� ?{�a��� ?{��R�	wbt
    �� ?{��R��� ?{��R�	wbt
    �� ?{��R��� ?{�R�	wbt
    �� ?{�:R��� ?{��R�	wbt
    �� ?{�oR��� ?{�/R�	wbt
    2�� ?{�NR� ?{��� ?{�� ?{�X� ?|�� ?|E� ?|
    2��� ?|
    pR�	wbt
    /2�� ?|R��� ?|%�R�	wbt
    -/2�� ?|-R��� ?|-�R�	wbt
    -/2�� ?|2�R� B���W�		� B���W�''� B�]W�#�eZ֤ɭ�H��{�V����������������
    � B��W�� B��W����'
    � B�
    *W�� B��A � B�A
    � B��B � B��B
    � B�OB � B�J�B � B�K�A ��� B�NeA � B�N�A ��� B�P�A
    � B�QB � B�S\B 00� B�H��-Vf�����	bcdef�eZ֤ɭ�H��{�V� B��\W�
    � B�ʅW�
    � B��_B � B��B � B�%A ��� B��A � B�7zC f���`0(�� B�?�C ""� B��>
    f���$�� B�� � B�M � B�U�>%A� B�WO� B�o�� B��>HH		� B��>� B���>HH� B�FMY7� B���	&� B��r� B��� 	&� B��-� B��� �� B��� � B��� B��� 	� B��� � B�� C.�%��� B��� � B�� �wg�F�� B��i � B�ý >s���� B��� � B��+ ����|d�PJJ� B��EA���ܚM��~!��☪!$��f~��`yg����t6������������l��_q�HF
    �c� Cd�  � C Aa�'͔��9�����Y���1  � C$`�;�u�%����b3�9m훒\�B���M� C
    �^������[��cz� C< vɟ�@��ոS�5��� C D � C#$ z�&�gzFL� C#� � C&M ��4��� C'>z�&�gzFL��4��� C��� Cq� .YЛ�I���2Q�t�$�� Cv�
    3�Mu�<��SRش� C
    � C�>
    �� Cּ
    �(=�>n�]%5�E  � C�f ��9ת!@��`��� C� � C�Q� Cc@�o(}��-�b�r�� Cg	�DnFP�� C:�� C	�iW�		� C	�?W�
    � C	�vW�	,�,�
    � C	��W�� C	�VW�@�
    � C	�-W�� C	��A ��� C	�'A
    � C	ņB � C	��B
    � C	�(B � C	�QB � C	͙A ��� C	��A � C	�A ��� C	�A
    � C	ӏB � C	�rB ++� C
    �3' 'f���c@�o(}��-�b�r�� C
    �6	&� C
    �8' � C
    ��N f���� C
    �-N
    � C
    ��B � C
    ”� C
    ÈB � C
    �A ��� C
    �A � C
    ǎ- � C
    �d-
    � C
    ��B � C
    �B
    � C
    �w � C
    �U��*� C
    ��� C�
    		bcdef� C)��(� C7�� CU� 	� CXV��(� Cr�� C�� ?f8�����Iꐀ�� C����(� C�?� C�'  ';� C̵(��(� C�� Co (0
    1346� C�7��(� C"F� C@u 7=צ�N�ơLW��c�� CC�>��(� C\�� Cz� >A��`tR����L��S�� C|B��(� C�T� C�� 	B
    � C�h(� C��� C�c
    � C��(� C�� C*o 	 *
    )+� C,Z(� CF�� Ce�
    		*+� Cg(� C��� C�k
    � C�D	� C�v� C٦
    )� C�	(� C�H� C2�
    � C59	(� CPk� Cl�
    *� Cn-
    (� C��� C��
    		*� C��(� C��� C��
    � C��(� C��� C
    � C!�(� C;y  � CXi 	%q�˿J��K&_��� CY�(� Ct�  � C� 	v�� �r��O��j�I � C��(� C�T� CӁ
    � CՇ	� C�I� CI
    )� C	� C%.� CB�
    )� CE�(� C]�� C��
    � C�c(� C�1� C��
    		*� C��(� Cӥ� C�
    � C�y	� C@� C-A
    )� C/�(� CI�� Ce�
    � Cj�(� C�P� C�� 	�*�*� C�](� C��� C�w
    � C� '(� C�/� C3O
    � C6� '(� CPZ� Cn� 	!"++$"%,+� Cs[%'(� C��� C� 	%
    � C�/	##� C�� C��
    #)� C�	&'� C�� C:�
    &)')� C=3(0(� CW�� Cu� 	(
    � Cx(0(� C�*� C�� 	)*$*+,)*� C��,0(� C�� C%� 	-.&*/0'*� C'V00(� CD\� C_� 	0
    � Cb[13(� C|�� C�	 	1
    � C��13(� C�� Cԡ
    		2
    3*� C��33(� C��� C� 	3
    � C+46(� C,k� CJ� 	4
    � CL?46(� C��� C�P
    		56*� C�-66(� C�~� C�f 	6
    � C޾7=(� C��� C� 	7
    � C{7=(� C3�  � CR� 	89�ڦ�N�ơLW��c�� CT�9=(� Cny  � C�� 	;<&�mgi��H�#��
    � C��<=(� C�R� C�p 	<
    � C�0	::� C�� C�
    :)� C	==� CT� C;�
    =)� C<�>A(� CY~� Cvj 	>
    � Cx[>A(� C�  � C�� 	?@H|�t&��N��(x.�� C��@A(� C�%� C� 	@
    � C�F	AA� C	�� C&W
    A)� C*� $$�� C+�	� C-� � C`�
    � C~� � C�
    � C�I� C�
    bcdef� C�
    � Cժ� C�� D
    � C�x>
    $�� CA<5 (*� CAE�
    � CAKC (*� CAN � CBK�
    � CG��>
    $*� Ce�oW�
    � Ce�W�
    � Ce�/B � Ce��B � Ce�A ��� CfRA � CfbW�		� Cf�W�
    � Cf <W�	,�,�
    � Cf"�W�� Cf"�W�@�
    � Cf%!W�� Cf(�A ��� Cf+A
    � Cf+~B � Cf-�B
    � Cf3�B � CfWdB � CfXkA �f� Cf[�A � Cf\fA �f� Cf^�A
    � Cf_0B � CfhpB � C�W�		� C‚W�� C��W�
    � C��W�� C��W� �
    � C�W�� C�ZW�����
    � C��W�� C�IW��
    � C��W�
    � C�sW�����
    � C��W�� C�6W��
    � C��W�� C��W�	����
    � C��W�� C�3W�	�
    � C�oW�� C��W�
    L����
    � C��W�� C�W�
    � C�_W�
    � C��B � C�$kB � C�%A ��� C�'hA � C�(�A ��� C�+�A
    � C�,sB � C�.�B � C�;�W�
    � C�HW�� C�O�W�
    � C�R+W�� C�T�W�
    � C�W%W�
    � C�Z0W�
    � C�]�W�� C�dW�
    � C�f�W�
    � C�pB � C��B � C��A �f� C��A � C��A �f� C��A
    � C�&B � C� �B 77� HxX��4�0f�����k�g����,�`77� Hyb��4�0f�����l�g��77� H|�i�4�0f�����o�g�l�� H|��� H}4J f���� H}LR ..� H}M�C *0(�0(�� H}WCC � H�61Y�� H�L�Y���0J+
  • The reason we are not able to decrypt the connection is due to LE secure connection is used (with diffie-hellman), unfortunately such connection can't be decrypted.
    However, I can find that the slave send a security request upon re-connection here, ref:
    This means (or at least suggests) that if the nRF52 is the peripheral device, then this FW have not followed the:
    "I have been working on this problem in a different case, I want to find out if your issue is related. To confirm please comment out the line bt_conn_set_security() that is found in bt_gatt_connected() in gatt.c and repeat your setup. Please do this test first."
    Can you double check with your collegues what may be calling bt_conn_set_security() here in the project, if not done by the bt_gatt_connected() in gatt.c?
  • This means (or at least suggests) that if the nRF52 is the peripheral device, then this FW have not followed the:
    That patch isn't integrated into our build system yet, since we need to patch the OS.
    Because of that some builds have it, others don't.
    I have previously tested this bug both with and without this patch, and the behavior was the same in both cases. Which is the reason it was (accidentally) left disabled when running the logs in this case.
