High current consumption offset when using internal RC oscillator as compared to crystal oscillator for low frequency clock.
Describe the bug
When trying to sleep core on NRF52805 using low frequency internal rc oscillator, average current consumption is ~189.50 uA while when using external crystal oscillator, average current consumption is ~ 8 uA.
I can't provide actual application code that I'm running, however, the only difference at Kconfig level it's whether to decide which low frequency crystal is used. I tried to get into the errata section to find out if it was something related to it but it doesn't. Also, I do not have UART enabled, and verification have been made to confirm that there is no GPIO line floating.
How to reproduce
Chip model: NRF52805 CAAA
os: Linux / GNU
sdk-nrf tag: v1.5.1, v1.4.0
Microcontroller is using System ON and DC-DC is enabled
  • Use internal rc crystal oscillator
    • remove extra capacitors and crystal connected to xtal pins
    • leave extra capacitors and crystal connected to xtal pins
  • Measure current consumption going into NRF52805
  • prj.conf:
    • CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y
      CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
      CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=n
  • Extra configurations:
    • CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_LF_ALWAYS_ON=n
  • When device sleeps and debugger is connected these are the register values:
    • Fields in CLOCK > LFCLKSTAT:
      SRC: RC 32.768 kHz RC oscillator - Source of LFCLK
      STATE: Running LFCLK running - LFCLK state
      Fields in CLOCK > HFCLKSTAT:
      SRC: RC 64 MHz internal oscillator (HFINT) - Source of HFCLK
      STATE: Running HFCLK running - HFCLK state
      Fields in CLOCK > LFCLKSRC:
      SRC: RC 32.768 kHz RC oscillator - Clock source
One way to quickly reproduce the behavior it's modifying system off sample on zephyr samples:
 * Copyright (c) 2019 Nordic Semiconductor ASA
#include <stdio.h>
#include <zephyr.h>
#include <device.h>
#include <init.h>
#include <power/power.h>
#include <hal/nrf_gpio.h>
#define CONSOLE_LABEL DT_LABEL(DT_CHOSEN(zephyr_console))
/* Prevent deep sleep (system off) from being entered on long timeouts
 * or `K_FOREVER` due to the default residency policy.
 * This has to be done before anything tries to sleep, which means
 * before the threading system starts up between PRE_KERNEL_2 and
 * POST_KERNEL.  Do it at the start of PRE_KERNEL_2.
static int disable_ds_1(const struct device *dev)
	ARG_UNUSED(dev);
	pm_ctrl_disable_state(POWER_STATE_DEEP_SLEEP_1);
	return 0;
SYS_INIT(disable_ds_1, PRE_KERNEL_2, 0);
void main(void)
	int rc;
	uint8_t i;
	const struct device *all_devices;
	static volatile uint16_t devices_count;
	devices_count = z_device_get_all_static(&all_devices);
	for(i = 0; i < devices_count; ++i)
		rc = device_set_power_state(&(all_devices[i]), DEVICE_PM_LOW_POWER_STATE, 0, 0);
	k_sleep(K_MSEC(1000000));
	printk("ERROR: System off failed\n");
	while (true) {
		/* spin to avoid fall-off behavior */
Expected behavior
To have similar results on current consumption as when using external crystal oscillator with slightly offset.
  • , I tested the beacon sample from NCS v1.5.1 using same symbols you shared, however, I didn't expected results.
    I was wondering what device tree were you using to compile, since there is no direct DTO on official repository when using standalone NRF52805.
    I guess would be great if you can share the exact code you have modified on beacon sample along with DTO configurations.
  • Hi
    Due to the summer vacation period we are currently understaffed, so delayed replies must be expected. I am sorry about any inconvenience this might cause.
    On my end I didn't have to edit anything in the device tree overlay file when building for the nRF52805. I have uploaded the entire 805 build folder. Adding it to the zephyr\samples\bluetooth\beacon folder in NCS should be sufficient. Flashing either the zephyr.elf or zephyr.hex files here should provide an example that is advertising, as the first .hex file I uploaded just goes straight to sleep due to the "STATE_LOCK" config which locks it in the deep sleep state.
    805_build.zip
    Simon
