Unable to connect to Cloud using Asset Tracker on nRF9160 DK
Hello, I am currently learning to use nRF9160 DK in Guangzhou, China.
It is weird that my China Mobile cellphone SIM card can be used on this DK to connect to Cloud. However, iBasics SIM and China Telecom NBIOT SIM cannot connect to Cloud.
While using iBasics, it's LED3 that keeps blinking. While using China Telecom, LED3 blinks first, then LED4 blinks, LED1 and LED4 blinks at last.
The following is from nRF Connect during the entire session for China Telecom
+CSCON: 1
[00:00:08.419,586]
[0m<inf> asset_tracker: RRC mode: Connected
[0m
+CEREG: 1,"765E","075D6450",9,,,"11100000","00111000"
[00:00:10.095,031]
[0m<inf> asset_tracker: Connected to LTE network.
[0m
[00:00:10.101,623]
[0m<inf> asset_tracker: Connecting to cloud, attempt 1 of 8
[0m
[00:00:10.109,039]
[0m<inf> asset_tracker: Cloud connection request sent.
[0m
[00:00:10.115,966]
[0m<inf> asset_tracker: Connection response timeout is set to 30 seconds.
[0m
[00:00:10.124,664]
[0m<inf> asset_tracker: Network registration status: Connected - home network
[0m
[00:00:10.133,544]
[0m<inf> asset_tracker: PSM parameter update: TAU: 86400, Active time: -1
[0m
[00:00:10.142,242]
[0m<dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTING
[0m
[00:00:10.150,695]
[0m<inf> asset_tracker: CLOUD_EVT_CONNECTING
[0m
[00:00:20.343,505]
[0m<dbg> nrf_cloud_transport.nct_connect: IPv4 address: 54.166.31.114
[0m
[00:00:20.351,715]
[0m<dbg> nrf_cloud_transport.nct_mqtt_connect: MQTT clean session flag: 0
[0m
[00:00:25.044,555]
[1;33m<wrn> date_time: sntp_query, error: -116
[0m
[00:00:32.817,443]
[0m
[00:00:38.944,549]
[0m
[00:00:44.977,661]
[0m
[00:00:51.057,739]
[0m
[00:00:51.064,270]
[1;33m<wrn> date_time: Not getting time from any NTP server
[0m
[00:00:51.072,357]
[0m<inf> asset_tracker: DATE_TIME_OBTAINED_MODEM
[0m
+CSCON: 0
[00:01:16.166,137]
[0m<inf> asset_tracker: RRC mode: Idle
[0m
+CSCON: 1
[00:01:21.380,767]
[0m
+CSCON: 0
[00:01:43.162,567]
[0m
+CSCON: 1
[00:02:13.541,534]
[0m
+CSCON: 0
[00:02:35.173,370]
[0m
[00:03:00.723,693]
[0m<dbg> nrf_cloud_transport.nct_mqtt_connect: mqtt_connect failed -22
[0m
[00:03:00.732,025]
[0m
[00:03:00.740,509]
[0m
[00:03:00.746,582]
[1;31m<err> asset_tracker: Failed to connect to cloud, error -7
[0m
[00:03:00.754,333]
[1;31m<err> asset_tracker: Ensure device has a valid private key
[0m
[00:03:00.762,145]
[1;31m<err> asset_tracker: Device will reboot in 300 seconds
[0m
[00:03:00.769,653]
[1;31m<err> asset_tracker: LTE link disconnect
[0m
+CSCON: 1
[00:03:01.222,259]
[0m
+CEREG: 0,"765E","075D6450",9,0,0,"11100000","11100000"
+CSCON: 0
[00:03:06.757,415]
[0m
[00:03:07.170,684]
[1;31m<err> asset_tracker: Shutdown modem
[0m
  • AlbertSerica said:
    The asset tracker connected to the Internet after a few minutes.
     Not in the first log you provided. I thought those logs were from two different SIM cards.
    AlbertSerica said:
    The problem I encountered seems to be related to zzhc library, there is a page about zzhc but it's not clear about how to use it:
     Please provide your prj.conf file and Kconfig file and I will take a look.
  • Hello, please have a look, I have to put .txt as a suffix to get Kconfig uploaded:
    4237.prj.conf
    # Copyright (c) 2018 Nordic Semiconductor ASA
    menu "Asset tracker"
    rsource "src/ui/Kconfig"
    config APPLICATION_WORKQUEUE_STACK_SIZE
    	int "Application workqueue stack size"
    	default 4096
    config APPLICATION_WORKQUEUE_PRIORITY
    	int "Application workqueue priority"
    	default SYSTEM_WORKQUEUE_PRIORITY
    menu "GPS"
    choice
    	prompt "GPS device"
    	default GPS_USE_SIM
    	help
    	  Select from which device GPS data will be fetched.
    config GPS_USE_SIM
    	bool "Use GPS simulator"
    	select GPS_SIM
    	select GPS_SIM_TRIGGER
    	help
    	  Use simulated GPS data.
    config GPS_USE_EXTERNAL
    	bool "User provided GPS device"
    	help
    	  Provide a GPS device that location data will be fetched from and
    	  sent to nRF Cloud
    endchoice
    config GPS_DEV_NAME
    	string "GPS device name"
    	default GPS_SIM_DEV_NAME if GPS_USE_SIM
    	help
    	  GPS device from which location data will be fetched and sent
    	  to nRF Cloud.
    config GPS_CONTROL_ON_LONG_PRESS
    	bool "Control the GPS state with button"
    	default y
    	help
    	  Control the GPS operation with long-press on the button.
    	  Press for 5 seconds to enable, or 5 seconds to disable.
    config GPS_CONTROL_PSM_ENABLE_ON_START
    	bool "Enable PSM when starting GPS"
    	help
    	  The nRF9160 modem needs to be set in PSM mode for the GPS to start
    	  searching for satellites. Enabling this option will do so
    	  automatically, otherwise the application must handle it.
    config GPS_CONTROL_PSM_DISABLE_ON_STOP
    	bool "Disable PSM when stopping GPS"
    	help
    	  Selecting this option will disable PSM when the GPS is stopped.
    	  During a PSM interval, the device is not reachable from the outside
    	  until the interval times out, or the device itself attempts to
    	  send data on the link.
    config GPS_CONTROL_FIRST_FIX_CHECK_DELAY
    	int "Time from Cloud conenction until first fix check"
    	default 30
    	help
    	  The amount of time that should pass between successfully establishing
    	  connection to cloud until first attempt to get position fix.
    	  Attempting to get a fix means entering PSM mode, in which the device
    	  is not reachable for the duration of the interval, or until the
    	  device itself sends data and then for the duration for the set
    	  active time thereafter.
    config GPS_CONTROL_FIX_CHECK_INTERVAL
    	int "Interval in seconds to between check for position fix"
    	default 120
    	help
    	  The fix check interval gives the interval for how long it will go
    	  between each retry to achieve position fix. The actual fix time will
    	  vary with factors such as satellite coverage, surrounding buildings
    	  and landscape, PSM interval and activity time requested and granted
    	  by the network.
    config GPS_CONTROL_FIX_CHECK_OVERDUE
    	int "Longest allowed time in seconds between checks for position fix"
    	default 900
    	help
    	  between each retry to achieve position fix, when GPS_START_ON_MOTION
    	  enabled, even if no motion is detected.
    config GPS_CONTROL_FIX_TRY_TIME
    	int "Time in seconds to try to get fix"
    	default 180
    	help
    	  Amount of time the device will attempt to get position fix. Note that
    	  if the interval is interrupted by the device sending data, the timer
    	  is not reset, and the actual try time will be shortened due to
    	  the device not being in PSM mode all the time. If fix is not acquired
    	  before it times out, the device will try to get fix again in
    	  GPS_CONTROL_FIX_CHECK_INTERVAL seconds. If GPS_CONTROL_FIX_COUNT is reached
    	  before the full GPS_CONTROL_FIX_TRY_TIME has passed, the GPS will be stopped.
    config GPS_CONTROL_FIX_COUNT
    	int "Number of position fix before stopping GPS"
    	default 3
    	help
    	  The number of fixes to get before stopping the GPS, within the time
    	  set in GPS_CONTROL_FIX_CHECK_INTERVAL.
    config GPS_CONTROL_MAX_FAILED_FIX_ATTEMPTS
    	int "Number of failed fix attempts before stopping GPS"
    	default 3
    	help
    	  Number of retries to get fix before shutting down the GPS until user
    	  input tells it to start retrying.
    config GPS_START_ON_MOTION
    	bool "Motion triggered GPS update"
    	default n
    	help
    	  When accelerometer detects movement, and GPS is enabled, update GPS
    	  position, but if no movement, wait a longer delay between updates
    	  to conserve power.
    endmenu # GPS
    menu "Device and modem"
    config POWER_OPTIMIZATION_ENABLE
    	bool "Enable power optimization"
    	default y
    	select LTE_EDRX_REQ
    if MODEM_INFO
    config HOLD_TIME_RSRP
    	int "Minimum time [s] between RSRP subscription messages"
    	default 60
    	help
    	  The minimum time in seconds where the modem
    	  informer is allowed to submit RSRP data to the cloud.
    endif
    endmenu # Device
    menuconfig MOTION
    	bool "Enable motion sensing in Asset Tracker"
    	default y
    	help
    	  Enables motion sensing in asset tracker with real
    	  sensors or simulated ones.
    if MOTION
    choice
    	prompt "Accelerometer device"
    	default ACCEL_USE_SIM
    	help
    	  Select which device will provide accelerometer data.
    config ACCEL_USE_SIM
    	bool "Use simulated accelerometer data"
    	select SENSOR
    	select SENSOR_SIM
    	select SENSOR_SIM_TRIGGER
    	help
    	  Use sensor simulator to generate accelerometer data for
    	  flip detection data sent to nRF Cloud.
    config ACCEL_USE_EXTERNAL
    	bool "User provided accelerometer device"
    	help
    	  The user will provide an accelerometer device that will
    	  be used for flip detection.
    endchoice
    if ACCEL_USE_SIM
    config ACCEL_DEV_NAME
    	string
    	default SENSOR_SIM_DEV_NAME
    config ACCEL_TRIGGER
    	bool
    	default SENSOR_SIM_TRIGGER
    config FLIP_INPUT
    	int "Button or switch number to simulate flip"
    	range 1 4 if BOARD_NRF9160DK_NRF9160NS
    	range 1 1 if BOARD_THINGY91_NRF9160NS
    	default 3 if BOARD_NRF9160DK_NRF9160NS
    	default 1 if BOARD_THINGY91_NRF9160NS
    	help
    	  Button or switch number to use for simulating
    	  a board flip event.
    	  1 - Button 1
    	  2 - Button 2
    	  3 - Switch 1
    	  4 - Switch 2
    endif
    if ACCEL_USE_EXTERNAL
    	string "Accelerometer device name"
    	help
    	  Device from which accelerometer data will be fetched and used
    	  for orientation detection and sent to nRF Cloud.
    endif
    config ACCEL_INVERTED
    	bool "Accelerometer inverted"
    	default y if BOARD_THINGY91_NRF9160NS
    	help
    	  Enable if the accelerometer is mounted with the top side facing
    	  down when the board itself is in normal position.
    endif # MOTION
    menu "Cloud"
    config MQTT_KEEPALIVE
    	int "Time after last transmission to send a ping to keep connection on"
    	default 1200
    	help
    	  This should be set to the expected time between messages sent from
    	  this device. Making it larger than the expected data period does not
    	  conserve bandwidth, as the ping is only sent if nothing else
    	  has been within the specified period. Shorter values can prevent hidden
    	  NAT timeouts at the carrier, but also will interrupt GPS fix attempts
    	  and slow down TTFF.
    config CLOUD_BUTTON
    	bool "Enable button sensor"
    	default y
    config CLOUD_BUTTON_INPUT
    	int "Set button sensor button number"
    	default 1
    config CLOUD_CONNECT_RETRY_DELAY
    	int "Cloud connection retry delay in seconds"
    	default 480
    	help
    	  Time to wait before trying to reconnect to the cloud if the
    	  previous attempt failed (in seconds).
    config CLOUD_CONNECT_COUNT_MAX
    	int "Maximum number of cloud connection attempts"
    	default 8
    	help
    	  Maximum number of unsuccessful cloud connection attempts.
    	  Device will wait for the value defined by CLOUD_CONNECT_RETRY_DELAY
    	  between attempts.
    config CLOUD_WAIT_DURATION
    	int "Cloud connection acknowledge wait duration"
    	default 30
    	help
    	  How long the device should wait for a CONNACK
    	  event from the cloud when connecting.  Device will reboot
    	  if an ack is not received within the duration.
    config CLOUD_FOTA_APP
    	bool "Enable firmware over-the-air upgrades for application"
    	depends on AWS_FOTA || NRF_CLOUD_FOTA
    	depends on DFU_TARGET_MCUBOOT
    	default y
    config CLOUD_FOTA_MODEM
    	bool "Enable firmware over-the-air upgrades for modem"
    	depends on DFU_TARGET_MODEM_DELTA
    	default y
    config CLOUD_FOTA_BOOT
    	bool "Enable firmware over-the-air upgrades for bootloader"
    	depends on SECURE_BOOT
    	default y
    config CLOUD_CONNECT_ERR_REBOOT_S
    	int "Seconds to wait before rebooting when a cloud connect error occurs"
    	default 300
    if NRF_CLOUD_CLIENT_ID_SRC_RUNTIME
    config CLOUD_RUNTIME_CLIENT_ID
    	string "Client ID used for cloud connection"
    	default "my_runtime_client_id"
    endif # NRF_CLOUD_CLIENT_ID_SRC_RUNTIME
    endmenu # Cloud
    menuconfig ENVIRONMENT_SENSORS
    	bool "Enable environment sensing in Asset Tracker"
    	default y
    	help
    	  Enables environment sensing in asset tracker with real
    if ENVIRONMENT_SENSORS
    config USE_BME680_BSEC
    	bool "Use Bosch BME680 BSEC lib"
    	default n
    	help
    	  Enable use of Bosch BSEC library. The library itself is not a part of
    	  NCS and must be downloaded from Bosch Sensortec.
    config BOSCH_BSEC_LIBRARY_PATH
    	string "Path to Bosch BSEC library folder"
    	default "$(ZEPHYR_BASE)/../nrf/ext/BSEC_1.4.8.0_Generic_Release"
    	help
    	  Path to the folder where the Bosch BSEC library is placed.
    config ENVIRONMENT_DATA_SEND_INTERVAL
    	int "Interval in seconds for sending environment data"
    	default 30
    	help
    	  Interval between each sampling and sending of environment sensor data.
    	  If the GPS is active, sensor data will not be sent before it is
    	  stopped. The unit is seconds.
    config ENVIRONMENT_DATA_BACKOFF_TIME
    	int "Time to delay sending environment data if GPS active"
    	default 20
    	help
    	  Time in seconds before retrying to send environment sensor data if
    	  the GPS is active.
    choice
    	prompt "Temperature measurement device"
    	default TEMP_USE_SIM
    	help
    	  Select which device will provide temperature data.
    config TEMP_USE_SIM
    	bool "Use simulated temperature data"
    	select SENSOR
    	select SENSOR_SIM
    	help
    	  Use sensor simulator to generate temperature data to send to
    	  nRF Cloud.
    config TEMP_USE_EXTERNAL
    	bool "User provided temperature device"
    	help
    	  The user provides a temperature device that is
    	  used for temperature measurement.
    endchoice
    if TEMP_USE_SIM
    config TEMP_DEV_NAME
    	string
    config TEMP_TRIGGER
    	bool
    config TEMP_SIM_BUTTON
    	int "Button or switch to trigger 'data ready' event"
    	help
    	  Button or switch number to use for triggering
    	  a 'data ready' event.
    	  1 - Button 1
    	  2 - Button 2
    	  3 - Switch 1
    	  4 - Switch 2
    endif
    if TEMP_USE_EXTERNAL
    	string "Temperature device name"
    	help
    	  Device from which temperature data will be fetched and
    	  sent to nRF Cloud.
    endif
    endif # ENVIRONMENT_SENSORS
    menuconfig LIGHT_SENSOR
    	bool "Light sensor"
    	select BH1749 if BOARD_THINGY91_NRF9160NS
    if LIGHT_SENSOR
    config LIGHT_SENSOR_DEV_NAME
    	string "Light sensor device name"
    	default "BH1749" if BOARD_THINGY91_NRF9160NS
    config LIGHT_SENSOR_DATA_SEND_INTERVAL
    	int "Interval in seconds for sending light sensor data"
    	default 60
    	help
    	  Interval between each sampling and sending of light sensor data.
    endif # LIGHT_SENSOR
    config GPS_START_AFTER_CLOUD_EVT_READY
    	bool "Automatic start of GPS on CLOUD_EVT_READY event after reset"
    	default n
    	help
    	  Enabling this will make the GPS automatically start after a reset.
    	  Useful when operating as a GPS tracker outdoors for a longer period
    	  of time.
    config ASSET_TRACKER_WATCHDOG_TIMEOUT_MSEC
    	int "Watchdog timeout in milliseconds"
    	default 60000
    config USE_AT_HOST
    	bool "Enable AT commands"
    	default y
    	select AT_HOST_LIBRARY
    	help
    	  Enable the AT host library so that AT commands can be sent to and
    	  received from a serial terminal.
    endmenu
    menu "Zephyr Kernel"
    source "Kconfig.zephyr"
    endmenu
    config ZZHC
        bool "Self-Registration Daemon"
        select NRF_MODEM_LIB
        select SETTINGS
        select AT_CMD
        select AT_CMD_PARSER
        select AT_NOTIF
        select BASE64
        select JSON_LIBRARY
        depends on TRUSTED_EXECUTION_NONSECURE
    module = ASSET_TRACKER
    module-str = Asset Tracker
    source "${ZEPHYR_BASE}/subsys/logging/Kconfig.template.log_config"
  • Hi, it doesn't look like you've added "CONFIG_ZZHC=y" to the prj.conf file?
  • Hello, I haven't not added it yet. I'm not sure the correct to do the following:
    • Configure the following option if you want to use this library:
    CONFIG_TRUSTED_EXECUTION_NONSECURE
    In other public posts, I saw others also raised similar questions
  • I see. Yes, that is a bit confusing.
    You can just add "CONFIG_ZZHC=y" to the prj.conf file, no need to do anything with it in the Kconfig, since it's already defined here.
