agps: SUPL session failed, error: -13
We are using 1.5.1 tag and building on the agps-sample called "v1.5.1\nrf\samples\nrf9160\agps\".
We see problems with downloading SUPL-data and also EVT_BLOCKED and stops searching at all.
No apparent reason for it what we can see. Perhaps bugs that were not fixed in 1.5.1 but in later commits? We need help with this.
See log below.
Best
Johan
LOG BELOW
[00:00:00.204,956] <inf> resetinfo: Reset reason = 0x00000001
[00:00:00.213,317] <err> resetinfo: Reboot reason: RESET_REASON_RESET_PIN
[00:00:00.234,619] <dbg> 9160.provision_certificates
[00:00:01.975,952] <inf> agps_sample: A-GPS sample has started
[00:00:01.991,210] <dbg> nrf9160_gps.configure_antenna: MAGPIO set: AT%XMAGPIO=1,0,0,1,1,1574,1577
[00:00:02.002,838] <dbg> nrf9160_gps.open_socket: GPS socket created, fd: 1232491587
[00:00:03.329,071] <inf> modem: ICCID: 89462008001000226627
[00:00:03.337,249] <inf> modem: IMSI: 248030105093729
[00:00:03.344,940] <inf> modem: MFW: mfw_nrf9160_1.3.0
[00:00:03.367,614] <dbg> modem.modem_set_gps_active: Activating GPS...
[00:00:03.431,091] <dbg> nrf9160_gps.gps_priority_set: GPS priority disabled
[00:00:03.448,272] <dbg> nrf9160_gps.start: GPS operational
[00:00:03.456,726] <inf> agps_sample: Periodic GPS search started with interval 0 s, timeout 0 s
[00:00:03.468,139] <inf> agps_sample: GPS_EVT_SEARCH_STARTED
[00:00:03.476,501] <dbg> nrf9160_gps.gps_thread: A-GPS data update needed
[00:00:03.485,839] <inf> agps_sample: GPS_EVT_AGPS_DATA_NEEDED
[00:00:03.494,262] <inf> modem: LTE connecting...
[00:00:03.501,556] <dbg> modem.modem_lte_connect: Activating LTE
[00:00:03.569,091] <wrn> gps_storage: store nrf52 uptime = 11321473 ms
[00:00:11.130,187] <dbg> modem.lte_lc_evt_handler: REG status: 2
[00:00:20.234,680] <dbg> modem.lte_lc_evt_handler: REG status: 5
[00:00:20.243,377] <inf> modem: LTE connected
[00:00:20.250,335] <dbg> agps.init_supl: Using GPS driver to input assistance data
[00:00:20.260,498] <inf> agps: SUPL is initialized
[00:00:20.267,913] <dbg> agps.open_supl_socket: CONFIG_POSIX_MAX_FDS=8
[00:00:20.277,038] <dbg> agps.open_supl_socket: CONFIG_NRF_MODEM_LIB_HEAP_SIZE=2048
[00:00:20.288,757] <dbg> agps.open_supl_socket: ip 173.194.222.192 (c0dec2ad) port 7276
[00:00:20.568,572] <inf> agps: Starting SUPL session
[00:00:20.578,186] <dbg> agps.supl_logger: ULP encoding length: 38
[00:00:20.587,493] <dbg> agps.supl_logger: Bytes sent: 38
[00:00:21.248,138] <dbg> agps.supl_logger: Bytes received: 34, total 34
[00:00:21.257,873] <dbg> agps.supl_logger: ULP ossDecode success, choice 3
[00:00:21.267,425] <dbg> agps.supl_logger: SUPL server responded using version 2.0.4
[00:00:21.277,770] <dbg> agps.supl_logger: SUPL response received
[00:00:21.286,621] <dbg> agps.supl_logger: ULP encoding length: 57
[00:00:21.295,989] <dbg> agps.supl_logger: Bytes sent: 57
[00:00:22.303,161] <dbg> agps.supl_logger: read again
[00:00:22.600,952] <dbg> agps.supl_logger: Bytes received: 708, total 708
[00:00:22.610,961] <dbg> agps.supl_logger: ULP ossDecode more input 4
[00:00:23.620,422] <dbg> agps.supl_logger: read again
[00:00:23.753,448] <dbg> agps.supl_logger: Bytes received: 708, total 1416
[00:00:23.763,458] <dbg> agps.supl_logger: ULP ossDecode more input 4
[00:00:24.772,583] <dbg> agps.supl_logger: read again
[00:00:25.640,686] <dbg> agps.supl_logger: Bytes received: 708, total 2124
[00:00:25.650,665] <dbg> agps.supl_logger: ULP ossDecode more input 4
[00:00:26.659,851] <dbg> agps.supl_logger: read again
[00:00:27.667,388] <dbg> agps.supl_logger: read again
[00:00:28.675,170] <dbg> agps.supl_logger: read again
[00:00:29.682,861] <dbg> agps.supl_logger: read again
[00:00:30.690,643] <dbg> agps.supl_logger: read again
[00:00:31.698,425] <dbg> agps.supl_logger: read again
[00:00:32.706,237] <dbg> agps.supl_logger: Timeout expired
[00:00:32.714,294] <dbg> agps.supl_logger: SUPL error: 3
[00:00:32.722,290] <dbg> agps.supl_logger: ULP encoding length: 34
[00:00:32.731,628] <dbg> agps.supl_logger: Bytes sent: 34
[00:00:32.739,624] <dbg> agps.supl_logger: SUPL session internal resources released
[00:00:32.749,847] <dbg> agps.supl_logger: SUPL session finished
[00:00:32.758,422] <err> agps: SUPL session failed, error: -13
[00:00:32.767,089] <err> agps: SUPL request failed, error: -13
[00:00:32.775,756] <err> agps_sample: Failed to request A-GPS data, error: -13
[00:00:32.785,980] <dbg> nrf9160_gps.print_satellite_stats: Tracking: 0 Using: 0 Unhealthy: 0
[00:00:32.797,088] <dbg> nrf9160_gps.print_satellite_stats: Seconds since last fix 32
[00:00:32.808,319] <dbg> nrf9160_gps.gps_thread: Waiting for time window to operate
[00:00:32.818,542] <inf> agps_sample: GPS_EVT_OPERATION_BLOCKED
[00:00:37.287,292] <dbg> nrf9160_gps.gps_thread: GPS has time window to operate
[00:00:37.297,180] <inf> agps_sample: GPS_EVT_OPERATION_UNBLOCKED
[00:00:37.305,908] <dbg> nrf9160_gps.print_satellite_stats: Tracking: 0 Using: 0 Unhealthy: 0
[00:00:37.317,016] <dbg> nrf9160_gps.print_satellite_stats: Seconds since last fix 37
[00:00:38.287,475] <dbg> nrf9160_gps.print_satellite_stats: Tracking: 0 Using: 0 Unhealthy: 0
[00:00:38.298,614] <dbg> nrf9160_gps.print_satellite_stats: Seconds since last fix 38
[00:00:39.287,536] <dbg> nrf9160_gps.print_satellite_stats: Tracking: 0 Using: 0 Unhealthy: 0
[00:00:39.298,645] <dbg> nrf9160_gps.print_satellite_stats: Seconds since last fix 39
[00:00:40.287,567] <dbg> nrf9160_gps.print_satellite_stats: Tracking: 0 Using: 0 Unhealthy: 0
[00:00:40.298,675] <dbg> nrf9160_gps.print_satellite_stats: Seconds since last fix 40
[00:00:42.383,605] <dbg> nrf9160_gps.gps_thread: Waiting for time window to operate
[00:00:42.393,859] <inf> agps_sample: GPS_EVT_OPERATION_BLOCKED
