the power consumption is about 6.12mW in BT connected, and consumption is about 7.75mW in advertising mode.
is it normal or has possibility to reduce it to extend the battery life?
thanks in advance.
thanks in advance.
What does this have to do with the topic of this thread - "power consumption of nRF52832" ?
excuse me, we are debugging the power consumption in our application, the value of ours is higher than evaluation board, just to see is there any chance to save more power consumption.
You typically don't need external pullups on the I2C, if you use the internal 13k pullups
13K would typically be a bit high for a 3V I2C bus, surely?
if it still needs pullup resistor on i2c
I2C always needs pullup resistors - that is fundamental to the bus operation.
The way to check if your value is OK is to look at the lines with an oscilloscope:
https://www.avrfreaks.net/comment/3074021#comment-3074021 - see the diagram & follow the link
Remember that the pullups will only ever draw current when the bus is in the low state; ie, during '0' bits of a bus communication. The bus idles high - so the pullups cause no current when idle.
Thanks for clarifying awneil
