nRF9160 DK - Asset Tracker Application - Connect to EMEA nRF Cloud?
I am testing the nRF9160 DK and used the asset tracker application with the IBasis SIM.
Application works fine under CAT M1 network (IBasis SIM is roaming on o2/Telefonica in Germany), but I can't connect to the MQTT broker / nRF cloud on NB-IoT.
(Modem is attached on NB-IoT, signal level (RSRP, RSRQ) is good).
Most likely, this is due to latency issues, as MQTT runs on TCP, which already fairly heavy for NB IoT.
Secondly, I noticed that the application uses a NRF cloud / MQTT server in the US (east coast, Virgina).
Domain: a2n7tk1kp18wix-ats.iot.us-east-1.amazonaws.com
I can connect to MQTT brokers nearby in Europe on NB-IoT (used for example the MQTT sample application), TCP connection was stable enough to support MQTT.
Question is hence, is there a server/gateway for the nRF cloud MQTT broker in Europe or other regions than US East?
Thanks.
BR
Kevin
  • Hello again Kevin,
    My apologies for the delayed answer. It took me some time double-checking this internally.
    TCP is not always supported in NB-IoT networks, and that is generally a known issue in some networks in Germany.
    But we might need modem traces here to find the root cause of the issue, as we are not sure what the root cause could be.
    I don’t know if this is something you wanna try, but you can follow this guide to do so.
    Thanks and regards,
    Markus
  • Hi Markus,
    Sorry, I didn't get to that earlier, but I have just looked at what things I need to do. Currently, everything is prepared for the modem tracing, I am using the asset tracker v1.
    However, it seems modem traces are on the first COM port, same as my application log. On the nRF9160 DK, this seems to be UART1 (within Zephyr called UART0?), nRF91 UART2 (within Zephyr called UART1) is disabled on the DK (DTS file states: /* Disable UART1, because it is used by default in TF-M */).
    It seems as if I need to flip more than just one switch.
    What is the recommended setup, naturally I want to keep my application UART console?
    ADDING: Does it not cause issues if the modem trace + application logs & AT command interface are on the same COM port?
    BR
    Kevin
  • Hi Markus,
    I figured it out how to redirected the logging and Zephyr console to the RTT backend.
    The AT command handler is still on the first COM port, which is also the modem trace port.
    I did capture 2 traces (+ application log of failing scenario in NBIOT), one working with CATM, the other one failing the MQTT connect in NBIOT (the modem is registered to NBIOT though). Find the files attached.
    The trace files (RAW format) are relatively small, so I am not sure if I did everything correctly. Please advise if something is wrong.
    Please let me know if the modem team does find something interesting in the logs (use the CAT M trace to cross compare if you like to).
    Thanks and best regards,
    Kevin
    trace-2021-08-06T09-16-18.114Z_CATM.bin
    trace-2021-08-06T09-28-10.019Z_NBIOT.bin
    00> *** Booting Zephyr OS build v2.6.0-rc1-ncs1  ***
    00>
    00> [00:00:00.244,232] <inf> asset_tracker: Asset tracker started
    00> [00:00:00.244,628] <inf> watchdog: Watchdog timeout installed. Timeout: 60000
    00> [00:00:00.245,056] <inf> watchdog: Watchdog started
    00> [00:00:00.254,455] <dbg> nrf_cloud_transport.allocate_and_copy_client_id: client_id = nrf-352656106651436
    00> [00:00:00.258,911] <dbg> nrf_cloud_transport.nct_settings_set: Settings key: p_sesh, size: 4
    00> [00:00:00.259,399] <dbg> nrf_cloud_transport.nct_settings_set: Read setting val: 1
    00> [00:00:00.263,702] <dbg> nrf_cloud_transport.nct_topics_populate: accepted_topic: nrf-352656106651436/shadow/get/accepted
    00> [00:00:00.264,251] <dbg> nrf_cloud_transport.nct_topics_populate: rejected_topic: $aws/things/nrf-352656106651436/shadow/get/rejected
    00> [00:00:00.264,801] <dbg> nrf_cloud_transport.nct_topics_populate: update_delta_topic: $aws/things/nrf-352656106651436/shadow/update/delta
    00> [00:00:00.265,380] <[00:00:14.504,028] <dbg> nrf_cloud_transport.nct_connect: IPv4 address: 34.232.204.81
    00> [00:00:14.504,486] <dbg> nrf_cloud_transport.nct_mqtt_connect: MQTT clean session flag: 0
    00> [00:00:15.637,054] <inf> asset_tracker: DATE_TIME_OBTAINED_NTP
    00> [00:01:22.950,653] <dbg> nrf_cloud_transport.nct_mqtt_connect: mqtt_connect failed -104
    00> [00:01:22.951,141] <err> nrf_cloud: nRF cloud connect failed -104
    00> [00:01:22.951,538] <dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTING
    00> [00:01:22.952,362] <err> nrf_cloud: nRF cloud connect failed -5
    00> [00:01:22.952,758] <inf> asset_tracker: CLOUD_EVT_CONNECTING
    00> [00:01:22.953,094] <err> asset_tracker: Failed to connect to cloud, error -5
    00> [00:01:22.953,521] <err> asset_tracker: Device will reboot in 300 seconds
    00> [00:01:22.954,833] <err> asset_tracker: LTE link disconnect
    00> [00:01:23.479,675] <inf> asset_tracker: LTE cell changed: Cell ID: -1, Tracking area: -1
    00> [00:01:23.789,276] <inf> asset_tracker: RRC mode: Idle
    00> [00:01:24.138,214] <err> asset_tracker: Shutdown modem
  • Thanks a lot, Kevin!
    As discussed on Teams, since I will be on vacation for the next couple of weeks you can upload the files to Jira and tag Jan Tore Guggedal.
    Markus
  • Hello Kevin,
    as discussed on Teams, I am closing this ticket for now and re-open it in case you are able to reproduce the described behaviour.
    Markus
