UART communication with Arduino ERROR 1 [NRF_ERROR_SVC_HANDLER_MISSING]
I am able to successfully run the UART peripheral example and view data sent via uart from an arduino to the nrf. Now I am trying to use it with the nrf BLE relay example. However, either nothing gets outputted or I get the error ERROR 1 [NRF_ERROR_SVC_HANDLER_MISSING].
Here is the uart_evt handler with the line generating the error highlighted.
Here is the uart_init code. When I uncomment the code at the bottom I can actually see the data printed via uart. It just doesnt work with the event handler and errors out in it. Any help would be great. Thanks!
Also I am building off the example found at:
https://github.com/NordicPlayground/nrf52-ble-app-uart-relay
Thanks again.
  • Let's try to get the regular UART working first.
    This results in the value "4" being printed 11 times
    4 is the same as APP_UART_DATA
    typedef enum
        APP_UART_DATA_READY,          /**< An event indicating that UART data has been received. The data is available in the FIFO and can be fetched using @ref app_uart_get. */
        APP_UART_FIFO_ERROR,          /**< An error in the FIFO module used by the app_uart module has occured. The FIFO error code is stored in app_uart_evt_t.data.error_code field. */
        APP_UART_COMMUNICATION_ERROR, /**< An communication error has occured during reception. The error is stored in app_uart_evt_t.data.error_communication field. */
        APP_UART_TX_EMPTY,            /**< An event indicating that UART has completed transmission of all available data in the TX FIFO. */
        APP_UART_DATA,                /**< An event indicating that UART data has been received, and data is present in data field. This event is only used when no FIFO is configured. */
    } app_uart_evt_type_t;
    It indicats that you are not using the app_uart_fifo, but instead the non-FIFO app_uart.
    If you have app_uart.c in your project, then remove that, and use the app_uart_fifo.c instead
    If you still have issues after that, feel free to post your main.c file and/or your project.
