nRF5 SDK possible to OTA update to nRF Connect SDK?
Just need a quick checking on this.
Currently we using nRF5 SDK, after production, is it possible we OTA update the firmware which using nRF Connect SDK?
This very important for us to decide our roadmap of development.
Thank you
Best Regards,
Alan
  • Thanks for your reply, Amanda.
    I am very interested to hear if this is possible using the nRF5 SDK UART DFU bootloader. I will be attempting it at some point so I would appreciate any instructions you can give similar to your post to
    I thought updating devices from nRF5 SDK to NCS over DFU would be a common request by users so perhaps it could deserve a blog post or an app note.
  • Hi
    I am finally working on the process for UART DFU update from nRF5 SDK -> NCS, but I am having some issues.
    I am testing with Nordic example projects as much as possible to help you identify any issues
    I am flashing the PCA10040 (nRF52 DK) with the 'examples/dfu/secure_bootloader/pca10040_uart_debug' application included in the latest nRF_SDK_17.0.2. This application allows me to enter UART DFU bootloader. I can test writing the included test application 'examples/dfu/secure_dfu_test_images/uart/nrf52832/blinky_mbr.zip'. This process works fine as expected (nRF5 SDK -> nRF5 SDK).
    To begin testing from nRF5 SDK -> NCS:
    1. I again flash the same secure_bootloader DFU example application to enter DFU mode.
    2. I then follow the instructions you linked here to flash the Zephyr blinky.zip application (I also add the --key-file parameter to sign it).
    west build -b nrf52dk_nrf52832 zephyr/samples/basic/blinky
    nrfutil pkg generate --hw-version 52 --sd-req=0x00 --application build/zephyr/zephyr.hex --application-version 1 blinky.zip --key-file private.key
    nrfutil dfu serial -pkg blinky.zip -p /dev/ttyACM0
    However, after the DFU seems to complete, the application does not boot (LEDs are not blinking). You can find the device DFU logs here.
    NOTE: After DFU completes the logs always seem to be cut short, this occurs even on successful update with the example application earlier.
    Some questions/points:
    1. Flashing the Zephyr blinky example directly works fine as you would expect.
    2. I also added the small change to the nRF bootloader that suggested.
    3. The instructions in the link you provided are only included in the nRF52840 Dongle board page, they are not included in the nRF52 DK board page. Are these instructions not compatible with nRF52 DK?
    4. As there is no private.key provided with the secure_bootloader DFU example applications I use my own dfu_public_key.c and private.key files to like the bootloader and NCS Blinky application.
    5. I have tried with both `nrfutil dfu serial` and `usb-serial` parameter. There seems to be slight differences in how the DFU completes at the end, but the end result is the same (LEDs are not blinking).
