Hi all, i had some problems on showing IQ data. how can i output my IQ values? im using 52833dk.
Maybe the problem come from here. I don't know which is best, but by toolchain manager it works fine for now. I suggest you to do the same.
yup im downloading now from toolchain thank you!
Zack,
I have found how to print IQ sample. In main.c, in cte_recv_cb, add the few lignes as show below
static void cte_recv_cb(struct bt_le_per_adv_sync *sync,
struct bt_df_per_adv_sync_iq_samples_report const *report)
printk("CTE[%u]: samples count %d, cte type %s, slot durations: %u [us], "
"packet status %s, RSSI %i\n",
bt_le_per_adv_sync_get_index(sync), report->sample_count,
cte_type2str(report->cte_type), report->slot_durations,
packet_status2str(report->packet_status), report->rssi);
printk("IQ sample content : \n");
for(int i=0; i<report->sample_count; i++){
printk("sample[%d] = I:%d Q:%d\n", i, report->sample[i].i, report->sample[i].q);
Also include bluetooth/hci.h, if not the compiler won't find bt_hci_le_iq_sample struct. You should see the rx controler print IQ value.
PER_ADV_SYNC[0]: [DEVICE]: 23:13:D2:D8:82:4B (random), tx_power 127, RSSI -63, CTE AOA, data length 0, data: CTE[0]: samples count 45, cte type AOA, slot durations: 2 [us], packet status CRC OK, RSSI -630 IQ sample content : sample[0] = I:5 Q:0 sample[1] = I:-6 Q:-1 sample[2] = I:5 Q:0 sample[3] = I:-6 Q:0 sample[4] = I:5 Q:-1 sample[5] = I:-6 Q:0 sample[6] = I:5 Q:-1 sample[7] = I:-6 Q:0 sample[8] = I:7 Q:8 sample[9] = I:15 Q:20 sample[10] = I:-17 Q:20 sample[11] = I:-4 Q:-5 sample[12] = I:-6 Q:14 sample[13] = I:-14 Q:-2 sample[14] = I:-7 Q:-6 sample[15] = I:-18 Q:-1 sample[16] = I:-1 Q:4 sample[17] = I:-15 Q:9 sample[18] = I:-7 Q:-32 sample[19] = I:4 Q:-11 sample[20] = I:10 Q:-23 sample[21] = I:26 Q:4 sample[22] = I:-3 Q:4 sample[23] = I:16 Q:-2 sample[24] = I:6 Q:12 sample[25] = I:-2 Q:7 sample[26] = I:9 Q:14 sample[27] = I:4 Q:-2 sample[28] = I:14 Q:8 sample[29] = I:-26 Q:20 sample[30] = I:-11 Q:1 sample[31] = I:-26 Q:3 sample[32] = I:-9 Q:-26 sample[33] = I:5 Q:0 sample[34] = I:-10 Q:-13 sample[35] = I:8 Q:-12 sample[36] = I:8 Q:-2 sample[37] = I:9 Q:-15 sample[38] = I:-3 Q:-4 sample[39] = I:-1 Q:-17 sample[40] = I:30 Q:10 sample[41] = I:6 Q:8 sample[42] = I:14 Q:21 sample[43] = I:-18 Q:21 sample[44] = I:-3 Q:-5
Hope it can help. Next step is calculate aoa with those.
Nathan
Hi Nathan,
thank you for sharing your information!!! great help!
Hello Nathan, I'm a beginner of nrf5340, and recently I'm working on the direction finding sample. I used nrf5340dk without other antenna matrix, and here's my output:
PER_ADV_SYNC[0]: [DEVICE]: 06:A2:07:3E:26:C0 (random), tx_power 127, RSSI -28, CTE AOA, data length 0, data: CTE[59]: samples count 168, cte type Unknown, slot durations: 0 [us], packet status CRC OK, RSSI 0It's different with yours, and I don't know what's wrong. Maybe it's because I used PCB antenna only. Could you tell me the type/name of antenna matrix you used, and how to connect with a board? Thanks a lot.
Best Regards.
