nrf52840 BLE not working
We have recently switched from using nrf52810 to nrf52840. Firmware porting went well until we tried using the BLE on nrf52840. No matter what we try the BLE will not start advertising. Even BLE examples in the SDK don't work ( tried ble_app_uart, ble_app_template,ble_app_hrs  ). When I flash softdevice (s140 provided in the sdk) and then the compiled example the BLE will not start. We never had these problems when working with the nrf52810 s112 sd. I have gone over the documentation and can't find any other reason why it will not work. All other peripherals (I2C, SPI, UART, even the proprietary ESB) works fine as long as I don't use the s140. The SDK version we used was 15.3.0. I've tried upgrading to 17.0.2  but the same result. The MCU seems to be unable to start the flashed FW with the s140 sd. Has anyone else ran into this issue?
Our board does not have an external crystal, but nrf52810 BLE worked fine on the internal RC osc. Has that changed?
  • I've tried multiple combinations and multiple different programs to flash ex:
    nrfjprog -f nrf52 --program s140_nrf52_7.2.0_softdevice.hex --sectorerase
    nrfjprog -f nrf52 --program nrf52840_xxaa.hex --sectorerase
    I've tried switching the commands. I also tried openocd just to make sure it wasn't a problem with the nrfjprog, and used a different programmer
    openocd -s $OPENOCD/tcl -f interface/stlink-v2.cfg -f target/nrf52.cfg -c init -c "reset init" -c halt -c "program  nrf52840_xxaa.bin verify 0x27000" -c reset -c exit
    openocd -s $OPENOCD/tcl -f interface/stlink-v2.cfg -f target/nrf52.cfg -c init -c "reset init" -c halt -c "program s140_nrf52_7.2.0_softdevice.hex verify" -c reset -c exit
    both failed.
  • You need to use mergehex to combine the softdevice and you hex into single hex before flashing it.
    What exmaple project did generate nrf52840_xxaa.hex?
    This does not have to be the problem, but if the application you program has data in the MBR page (which applies to for instance bootloaders form some SDK versions) you need to either use mergehex as suggested (then make sure to update to the latest nRF Command Line Tools due to a mergehex bug), or program without --sectorerase. A different approach would then be:
    nrfjprog -e
