Internal DFU Hash validation error
I am currently working on updating the examples/dfu/secure_bootloader_uart_debug example in SDK 15.3.0 to do an internal dfu on my nrf52840 DK rather than having the nrf communicating to an external source, like my laptop, during the dfu process. In the end, I want an app to store the init and firmware packets into external memory and validate it before going into dfu mode, then transfer the images from external to internal during the dfu process.  I have successfully been able to transfer an init packet from external memory and I have gotten to the execution stage of transferring the firmware image. My current dilemma is when calling the nrf_dfu_validation_hash_ok() I am getting a "Hash verification error" . Originally, I thought this was because the private.key and dfu_public_key.c did not coincide, thus making my dfu package not be able to transfer, however, I soon realized that this was not the case. I have only modified 3 files which you can see below. If anyone has any advice on how I should go about this, please let me know as soon as you can!
 * Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
#include "nrf_bootloader.h"
#include "compiler_abstraction.h"
#include "nrf.h"
#include "boards.h"
#include "sdk_config.h"
#include "nrf_power.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_dfu.h"
#include "nrf_error.h"
#include "nrf_dfu_settings.h"
#include "nrf_dfu_utils.h"
#include "nrf_bootloader_wdt.h"
#include "nrf_bootloader_info.h"
#include "nrf_bootloader_app_start.h"
#include "nrf_bootloader_fw_activation.h"
#include "nrf_bootloader_dfu_timers.h"
#include "app_scheduler.h"
#include "nrf_dfu_validation.h"
#include "nrf_drv_qspi.h"
//Opcode for QSPI functions
#define QSPI_STD_CMD_WRSR   0x01
#define QSPI_STD_CMD_RSTEN  0x66
#define QSPI_STD_CMD_RST    0x99
#define QSPI_STD_CMD_WREN   0x06
#define QSPI_STD_CMD_RDSR   0x05
#define QSPI_STD_CMD_RDID   0x9F
#define QSPI_STD_CMD_QREAD   0x6B
//function that waits for the qspi peripheral to finish
#define WAIT_FOR_PERIPH() do { \
        while (!m_finished) {} \
        m_finished = false;    \
    } while (0)
static volatile bool m_finished = false;
static nrf_dfu_observer_t m_user_observer; //<! Observer callback set by the user.
static volatile bool m_flash_write_done;
#define SCHED_QUEUE_SIZE      32          /**< Maximum number of events in the scheduler queue. */
#define SCHED_EVENT_DATA_SIZE NRF_DFU_SCHED_EVENT_DATA_SIZE /**< Maximum app_scheduler event size. */
bool erase_done = false;//flag set when qspi has been erased
#if !(defined(NRF_BL_DFU_ENTER_METHOD_BUTTON)    && \
      defined(NRF_BL_DFU_ENTER_METHOD_PINRESET)  && \
      defined(NRF_BL_DFU_ENTER_METHOD_GPREGRET)  && \
      defined(NRF_BL_DFU_ENTER_METHOD_BUTTONLESS))
    #error Configuration file is missing flags. Update sdk_config.h.
STATIC_ASSERT((NRF_BL_DFU_INACTIVITY_TIMEOUT_MS >= 100) || (NRF_BL_DFU_INACTIVITY_TIMEOUT_MS == 0),
             "NRF_BL_DFU_INACTIVITY_TIMEOUT_MS must be 100 ms or more, or 0 to indicate that it is disabled.");
#if defined(NRF_LOG_BACKEND_FLASH_START_PAGE)
STATIC_ASSERT(NRF_LOG_BACKEND_FLASH_START_PAGE != 0,
    "If nrf_log flash backend is used it cannot use space after code because it would collide with settings page.");
/**@brief Weak implemenation of nrf_dfu_init
 * @note   This function will be overridden if nrf_dfu.c is
 *         compiled and linked with the project
 #if (__LINT__ != 1)
__WEAK uint32_t nrf_dfu_init(nrf_dfu_observer_t observer)
    NRF_LOG_DEBUG("in weak nrf_dfu_init");
    return NRF_SUCCESS;
/**@brief Weak implementation of nrf_dfu_init
 * @note    This function must be overridden in application if
 *          user-specific initialization is needed.
__WEAK uint32_t nrf_dfu_init_user(void)
    NRF_LOG_DEBUG("in weak nrf_dfu_init_user");
    return NRF_SUCCESS;
static void flash_write_callback(void * p_context)
    UNUSED_PARAMETER(p_context);
    m_flash_write_done = true;
static void do_reset(void * p_context)
    NRF_LOG_FINAL_FLUSH();
#if NRF_MODULE_ENABLED(NRF_LOG_BACKEND_RTT)
    // To allow the buffer to be flushed by the host.
    nrf_delay_ms(100);
    NVIC_SystemReset();
static void bootloader_reset(bool do_backup)
    NRF_LOG_DEBUG("Resetting bootloader.");
    if (do_backup)
        m_flash_write_done = false;
        nrf_dfu_settings_backup(do_reset);
        do_reset(NULL);
static void inactivity_timeout(void)
    NRF_LOG_INFO("Inactivity timeout.");
    bootloader_reset(true);
/**@brief Function for handling DFU events.
static void dfu_observer(nrf_dfu_evt_type_t evt_type)
    switch (evt_type)
        case NRF_DFU_EVT_DFU_STARTED:
        case NRF_DFU_EVT_OBJECT_RECEIVED:
            nrf_bootloader_dfu_inactivity_timer_restart(
                        NRF_BOOTLOADER_MS_TO_TICKS(NRF_BL_DFU_INACTIVITY_TIMEOUT_MS),
                        inactivity_timeout);
        case NRF_DFU_EVT_DFU_COMPLETED:
        case NRF_DFU_EVT_DFU_ABORTED:
    if (m_user_observer)
        m_user_observer(evt_type);
/**@brief Function for initializing the event scheduler.
static void scheduler_init(void)
    APP_SCHED_INIT(SCHED_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
/**@brief Suspend the CPU until an interrupt occurs.
static void wait_for_event(void)
#if defined(BLE_STACK_SUPPORT_REQD) || defined(ANT_STACK_SUPPORT_REQD)
    (void)sd_app_evt_wait();
#else
    // Wait for an event.
    __WFE();
    // Clear the internal event register.
    __SEV();
    __WFE();
/**@brief Continually sleep and process tasks whenever woken.
static void loop_forever(void)
    while (true)
        //feed the watchdog if enabled.
        nrf_bootloader_wdt_feed();
        app_sched_execute();
        if (!NRF_LOG_PROCESS())
            wait_for_event();
/**@brief Function for initializing button used to enter DFU mode.
static void dfu_enter_button_init(void)
    nrf_gpio_cfg_sense_input(NRF_BL_DFU_ENTER_METHOD_BUTTON_PIN,
                             BUTTON_PULL,
                             NRF_GPIO_PIN_SENSE_LOW);
static bool crc_on_valid_app_required(void)
    bool ret = true;
    if (NRF_BL_APP_CRC_CHECK_SKIPPED_ON_SYSTEMOFF_RESET &&
        (nrf_power_resetreas_get() & NRF_POWER_RESETREAS_OFF_MASK))
        nrf_power_resetreas_clear(NRF_POWER_RESETREAS_OFF_MASK);
        ret = false;
    else if (NRF_BL_APP_CRC_CHECK_SKIPPED_ON_GPREGRET2 &&
            ((nrf_power_gpregret2_get() & BOOTLOADER_DFU_GPREGRET2_MASK) == BOOTLOADER_DFU_GPREGRET2)
            && (nrf_power_gpregret2_get() & BOOTLOADER_DFU_SKIP_CRC_BIT_MASK))
        nrf_power_gpregret2_set(nrf_power_gpregret2_get() & ~BOOTLOADER_DFU_SKIP_CRC);
        ret = false;
    return ret;
static bool boot_validate(boot_validation_t const * p_validation, uint32_t data_addr, uint32_t data_len, bool do_crc)
    if (!do_crc && (p_validation->type == VALIDATE_CRC))
        return true;
    return nrf_dfu_validation_boot_validate(p_validation, data_addr, data_len);
/** @brief Function for checking if the main application is valid.
 * @details     This function checks if there is a valid application
 *              located at Bank 0.
 * @param[in]   do_crc Perform CRC check on application. Only CRC checks
                       can be skipped. For other boot validation types,
                       this parameter is ignored.
 * @retval  true  If a valid application has been detected.
 * @retval  false If there is no valid application.
static bool app_is_valid(bool do_crc)
    if (s_dfu_settings.bank_0.bank_code != NRF_DFU_BANK_VALID_APP)
        NRF_LOG_INFO("Boot validation failed. No valid app to boot.");
        return false;
    else if (NRF_BL_APP_SIGNATURE_CHECK_REQUIRED &&
        (s_dfu_settings.boot_validation_app.type != VALIDATE_ECDSA_P256_SHA256))
        NRF_LOG_WARNING("Boot validation failed. The boot validation of the app must be a signature check.");
        return false;
    else if (SD_PRESENT && !boot_validate(&s_dfu_settings.boot_validation_softdevice, MBR_SIZE, s_dfu_settings.sd_size, do_crc))
        NRF_LOG_WARNING("Boot validation failed. SoftDevice is present but invalid.");
        return false;
    else if (!boot_validate(&s_dfu_settings.boot_validation_app, nrf_dfu_bank0_start_addr(), s_dfu_settings.bank_0.image_size, do_crc))
        NRF_LOG_WARNING("Boot validation failed. App is invalid.");
        return false;
    // The bootloader itself is not checked, since a self-check of this kind gives little to no benefit
    // compared to the cost incurred on each bootup.
    NRF_LOG_DEBUG("App is valid");
    return true;
/**@brief Function for clearing all DFU enter flags that
 *        preserve state during reset.
 * @details This is used to make sure that each of these flags
 *          is checked only once after reset.
static void dfu_enter_flags_clear(void)
    if (NRF_BL_DFU_ENTER_METHOD_PINRESET &&
       (NRF_POWER->RESETREAS & POWER_RESETREAS_RESETPIN_Msk))
        // Clear RESETPIN flag.
        NRF_POWER->RESETREAS |= POWER_RESETREAS_RESETPIN_Msk;
    if (NRF_BL_DFU_ENTER_METHOD_GPREGRET &&
       ((nrf_power_gpregret_get() & BOOTLOADER_DFU_GPREGRET_MASK) == BOOTLOADER_DFU_GPREGRET)
            && (nrf_power_gpregret_get() & BOOTLOADER_DFU_START_BIT_MASK))
        // Clear DFU mark in GPREGRET register.
        nrf_power_gpregret_set(nrf_power_gpregret_get() & ~BOOTLOADER_DFU_START);
    if (NRF_BL_DFU_ENTER_METHOD_BUTTONLESS &&
       (s_dfu_settings.enter_buttonless_dfu == 1))
        // Clear DFU flag in flash settings.
        s_dfu_settings.enter_buttonless_dfu = 0;
        APP_ERROR_CHECK(nrf_dfu_settings_write(NULL));
/**@brief Function for checking whether to enter DFU mode or not.
static bool dfu_enter_check(void)
    if (!app_is_valid(crc_on_valid_app_required()))
        NRF_LOG_DEBUG("DFU mode because app is not valid.");
        return true;
    if (NRF_BL_DFU_ENTER_METHOD_BUTTON &&
       (nrf_gpio_pin_read(NRF_BL_DFU_ENTER_METHOD_BUTTON_PIN) == 0))
        NRF_LOG_DEBUG("DFU mode requested via button.");
        return true;
        NRF_LOG_DEBUG("DFU mode requested via pin-reset.");
        return true;
       (nrf_power_gpregret_get() & BOOTLOADER_DFU_START))
        NRF_LOG_DEBUG("DFU mode requested via GPREGRET.");
        return true;
        NRF_LOG_DEBUG("DFU mode requested via bootloader settings.");
        return true;
    return false;
#if NRF_BL_DFU_ALLOW_UPDATE_FROM_APP
static void postvalidate(void)
    NRF_LOG_INFO("Postvalidating update after reset.");
    nrf_dfu_validation_init();
    if (nrf_dfu_validation_init_cmd_present())
        uint32_t firmware_start_addr;
        uint32_t firmware_size;
        // Execute a previously received init packed. Subsequent executes will have no effect.
        if (nrf_dfu_validation_init_cmd_execute(&firmware_start_addr, &firmware_size) == NRF_DFU_RES_CODE_SUCCESS)
            if (nrf_dfu_validation_prevalidate() == NRF_DFU_RES_CODE_SUCCESS)
                if (nrf_dfu_validation_activation_prepare(firmware_start_addr, firmware_size) == NRF_DFU_RES_CODE_SUCCESS)
                    NRF_LOG_INFO("Postvalidation successful.");
    s_dfu_settings.bank_current = NRF_DFU_CURRENT_BANK_0;
    UNUSED_RETURN_VALUE(nrf_dfu_settings_write_and_backup(flash_write_callback));
static void qspi_handler(nrf_drv_qspi_evt_t event, void * p_context)
    UNUSED_PARAMETER(event);
    m_finished = true;
static void configure_memory()
    uint8_t temporary = 0x40;//qspi enable code, this if from NOR flash datasheet
    uint32_t err_code;
    uint8_t rx[4];
    nrf_qspi_cinstr_conf_t cinstr_cfg = {
        .opcode    = QSPI_STD_CMD_RSTEN,
        .length    = NRF_QSPI_CINSTR_LEN_1B,
        .io2_level = true,
        .io3_level = true,
        .wipwait   = true,
        .wren      = true
    // Send reset enable
    err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, NULL);
    // Send reset command
    cinstr_cfg.opcode = QSPI_STD_CMD_RST;
    // Send write enable
    cinstr_cfg.opcode = QSPI_STD_CMD_WREN;
    // Switch to qspi mode
    cinstr_cfg.opcode = QSPI_STD_CMD_WRSR;
    cinstr_cfg.length = NRF_QSPI_CINSTR_LEN_2B;
    err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, &temporary, NULL);
    // Read ID
    cinstr_cfg.opcode = QSPI_STD_CMD_RDID;
    cinstr_cfg.length = NRF_QSPI_CINSTR_LEN_4B;
    err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, &rx);
ret_code_t nrf_bootloader_init(nrf_dfu_observer_t observer)
    NRF_LOG_DEBUG("In nrf_bootloader_init");
    ret_code_t                            ret_val;
    nrf_bootloader_fw_activation_result_t activation_result;
    uint32_t                              initial_timeout;
    bool                                  dfu_enter = false;
    m_user_observer = observer;
    if (NRF_BL_DFU_ENTER_METHOD_BUTTON)
        dfu_enter_button_init();
    ret_val = nrf_dfu_settings_init(false);
    if (ret_val != NRF_SUCCESS)
        return NRF_ERROR_INTERNAL;
    // Postvalidate if DFU has signaled that update is ready.
    if (s_dfu_settings.bank_current == NRF_DFU_CURRENT_BANK_1)
        postvalidate();
    // Check if an update needs to be activated and activate it.
    activation_result = nrf_bootloader_fw_activate();
    switch (activation_result)
        case ACTIVATION_NONE:
            initial_timeout = NRF_BOOTLOADER_MS_TO_TICKS(NRF_BL_DFU_INACTIVITY_TIMEOUT_MS);
            dfu_enter       = dfu_enter_check();
        case ACTIVATION_SUCCESS_EXPECT_ADDITIONAL_UPDATE:
            initial_timeout = NRF_BOOTLOADER_MS_TO_TICKS(NRF_BL_DFU_CONTINUATION_TIMEOUT_MS);
            dfu_enter       = true;
        case ACTIVATION_SUCCESS:
            NRF_LOG_ERROR("Unreachable");
            return NRF_ERROR_INTERNAL; // Should not reach this.
        case ACTIVATION_ERROR:
    if (dfu_enter)
        nrf_bootloader_wdt_init();
        scheduler_init();
        dfu_enter_flags_clear();
        //If QSPI not already enabled/initialized
        if((NRF_QSPI->STATUS >> 24)==0x00)//is status register QSPI bit enabled?
        { // if not, initialize qspi
          nrf_drv_qspi_config_t config = NRF_DRV_QSPI_DEFAULT_CONFIG;
          ret_val = nrf_drv_qspi_init(&config, qspi_handler, NULL);
          if(ret_val!=NRF_SUCCESS)//when debugging if initialization not working, reset and reinitialize
            NVIC_SystemReset(); //if not initialized correctly, reset
          configure_memory(); //configure the qspi external memory
          //if the external memory already has init and firmware packages, delete this
          //if(erase_done == false)//check if chip has already been erased - case when dfu downloaded from cell module
          //  //erase chip erase
          //  m_finished = false;
          //  ret_code_t ret_val = nrf_drv_qspi_erase(NRF_QSPI_ERASE_LEN_64KB, 0);//erase 64KBytes or memory starting at address 0x00
          //  APP_ERROR_CHECK(ret_val);
          //  WAIT_FOR_PERIPH();
          //  erase_done = true;
        // Call user-defined init function if implemented
        //not used
        ret_val = nrf_dfu_init_user();
        //Currently disabled due to SD dfu update time taking too long
        nrf_bootloader_dfu_inactivity_timer_restart(initial_timeout, inactivity_timeout);//restart inactivity timer
        ret_val = nrf_dfu_init(dfu_observer);//bootloader goes into dfu
        NRF_LOG_DEBUG("Enter main loop");
        loop_forever(); // This function will never return.
        // Erase additional data like peer data or advertisement name
        ret_val = nrf_dfu_settings_additional_erase();
        //if qspi initialized uninitialize the qspi
        while((NRF_QSPI->STATUS >> 24)==0x01)
          nrf_drv_qspi_uninit();
        nrf_dfu_settings_backup(flash_write_callback);
        ASSERT(m_flash_write_done);
        nrf_bootloader_app_start();
    // Should not be reached.
nrf_bootloader.h
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "nrf_dfu_transport.h"
#include "nrf_dfu_req_handler.h"
#include "nrf_dfu_serial.h"
#include "nrf_dfu_flash.h"
//*********** Location of the images ***********
#define APPLICATION_INIT_PACKET_LOCATION 0x0000
#define APPLICATION_INIT_PACKET_MAX_SIZE 0x0200
#define APPLICATION_IMAGE_LOCATION 0x1000
#define APPLICATION_MAX_SIZE 0x20000
#define BOOTLOADER_SOFTDEVICE_INIT_PACKET_LOCATION 0x20000
#define BOOTLOADER_SOFDEVICE_IMAGE_LOCATION 0x21000
#define BOOTLOADER_SOFTDEVICE_MAX_SIZE 0x40000
#define COMMAND_OBJECT              0x01 //For init packet
#define DATA_OBJECT                 0x02 // For actual image packet
uint16_t mtu_size = 200;
static uint32_t m_firmware_start_addr;          /**< Start address of the current firmware image. */
static uint32_t m_firmware_size_req;            /**< The size of the entire firmware image. Defined by the init command. */
 * @brief This function calls the user's observer (@ref m_observer) after it is done handling the event.
static void dfu_observer(nrf_dfu_evt_type_t event)
    switch (event)
#ifndef NRF_DFU_NO_TRANSPORT
            UNUSED_RETURN_VALUE(nrf_dfu_transports_close(NULL));
    /* Call user's observer if present. */
        m_user_observer(event);
// Simple algorithm for finding the end of the firmware image in the external memory
uint32_t find_image_size(uint32_t start_address, size_t length)
    uint32_t img_size = 0;//start the image size at 0
    uint8_t m_rx_buf[length];
    nrf_drv_qspi_read(&m_rx_buf,length,start_address);//load init packet from flash into buffer
    nrf_delay_ms(50);
    while(img_size < length)
        if(m_rx_buf[img_size] != 0xFF || m_rx_buf[img_size+1]!=0xFF || m_rx_buf[img_size+2]!=0xFF)
          //if the current byte and the next byte, are not cleared, go to the next byte
            img_size += 1;// keep count of the image size
            break;//if the current and the next byte are cleared ( == 0xFF) then break and return image size
    return img_size;
void init_pkt_transfer(void)
    nrf_dfu_response_t p_res;
    nrf_dfu_request_t p_req;
    uint32_t len = find_image_size(APPLICATION_INIT_PACKET_LOCATION,
                                               APPLICATION_INIT_PACKET_MAX_SIZE);
    uint8_t m_rx_buf[len];
    //Get MTU
    p_req.request = NRF_DFU_OP_MTU_GET;
    p_res.mtu.size = mtu_size;
    on_mtu_get_request(&p_req,&p_res);
    //select command
    p_req.request           = NRF_DFU_OP_OBJECT_SELECT;
    p_req.callback.response = dfu_req_handler_rsp_clbk;
    p_req.select.object_type = COMMAND_OBJECT;
    nrf_dfu_command_req(&p_req,&p_res);
    //Create command
    p_req.request = NRF_DFU_OP_OBJECT_CREATE;
    p_req.create.object_type = COMMAND_OBJECT;
    p_req.create.object_size = len;
    //Write Command - writing from external to internal memory
    p_req.request = NRF_DFU_OP_OBJECT_WRITE;//change the opcode to write
    nrf_drv_qspi_read(m_rx_buf,len+1,APPLICATION_INIT_PACKET_LOCATION);//read init packet from external memory into buffer starting at init packet location
    nrf_delay_ms(5);
    p_req.write.p_data = m_rx_buf;
    nrf_delay_ms(5);
    p_req.write.len = len;
    free((void*)p_req.write.p_data);
    //Calculate CRC Command
    p_req.request           = NRF_DFU_OP_CRC_GET;
    //Execut Init packet Command
    p_req.request           = NRF_DFU_OP_OBJECT_EXECUTE;
void fw_pkt_transfer(void)
    uint32_t len = find_image_size(APPLICATION_IMAGE_LOCATION, APPLICATION_IMAGE_LOCATION + APPLICATION_MAX_SIZE);
    uint8_t m_rx_buf[mtu_size];
    //select command
    p_req.select.object_type = DATA_OBJECT;
    nrf_dfu_data_req(&p_req,&p_res);
    //Create command
    p_req.create.object_type = DATA_OBJECT;
    uint32_t write_addr = APPLICATION_IMAGE_LOCATION;
    while(s_dfu_settings.write_offset!=len)
        memset(m_rx_buf,0,sizeof(m_rx_buf));//clear buffer
        if((s_dfu_settings.write_offset + mtu_size) < len)//if the current image size is less that the required image size
            nrf_drv_qspi_read(m_rx_buf, mtu_size ,write_addr + s_dfu_settings.write_offset);//read init packet from external memory into buffer starting at init packet location
            nrf_delay_ms(5);//flush delay
            p_req.write.len = mtu_size;
            nrf_drv_qspi_read(m_rx_buf, len - s_dfu_settings.write_offset ,write_addr + s_dfu_settings.write_offset);//read init packet from external memory into buffer starting at init packet location
            nrf_delay_ms(5);
            nrf_delay_ms(5);
            p_req.write.len = len-s_dfu_settings.write_offset;
        //printf("Next s_dfu_settings.write_offset size: %i\n",s_dfu_settings.write_offset);
    uint32_t ret_val;
    NRF_LOG_INFO("Entering DFU mode.");
    dfu_observer(NRF_DFU_EVT_DFU_INITIALIZED);
    ret_val = nrf_dfu_flash_init(false);
        return ret_val;
    init_pkt_transfer();
    fw_pkt_transfer();
    return ret_val;
nrf_dfu.h
#include <stdint.h>
#include <stdbool.h>
#include "nrf_dfu_types.h"
#include "nrf_dfu_handling_error.h"
#include "nrf_fstorage.h"
#include "app_util.h"
#include "pb.h"
#include "pb_common.h"
#include "pb_decode.h"
#include "dfu-cc.pb.h"
#include "crc32.h"
#include "sdk_macros.h"
#include "nrf_crypto.h"
#include "nrf_assert.h"
#define NRF_LOG_MODULE_NAME nrf_dfu_req_handler
NRF_LOG_MODULE_REGISTER();
#define NRF_DFU_PROTOCOL_VERSION    (0x01)
#define QSPI_XIP_START_ADDR         0x12000000
#ifndef NRF_DFU_PROTOCOL_REDUCED
#define NRF_DFU_PROTOCOL_REDUCED 0
STATIC_ASSERT(DFU_SIGNED_COMMAND_SIZE <= INIT_COMMAND_MAX_SIZE);
    } while (0)
static nrf_dfu_observer_t m_observer;
static uint8_t m_rx_buff[64];
    m_finished = true;
static void on_dfu_complete(nrf_fstorage_evt_t * p_evt)
    UNUSED_PARAMETER(p_evt);
    NRF_LOG_DEBUG("All flash operations have completed. DFU completed.");
    m_observer(NRF_DFU_EVT_DFU_COMPLETED);
static nrf_dfu_result_t ext_err_code_handle(nrf_dfu_result_t ret_val)
    if (ret_val < NRF_DFU_RES_CODE_EXT_ERROR)
        return ret_val;
        nrf_dfu_ext_error_code_t ext_err =
                (nrf_dfu_ext_error_code_t)((uint8_t)ret_val - (uint8_t)NRF_DFU_RES_CODE_EXT_ERROR);
        return ext_error_set(ext_err);
#if !NRF_DFU_PROTOCOL_REDUCED
static void on_protocol_version_request(nrf_dfu_request_t const * p_req, nrf_dfu_response_t * p_res)
    UNUSED_PARAMETER(p_req);
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_PROTOCOL_VERSION");
    if (NRF_DFU_PROTOCOL_VERSION_MSG)
        p_res->protocol.version = NRF_DFU_PROTOCOL_VERSION;
        NRF_LOG_DEBUG("NRF_DFU_OP_PROTOCOL_VERSION disabled.");
        p_res->result = NRF_DFU_RES_CODE_OP_CODE_NOT_SUPPORTED;
static void on_hw_version_request(nrf_dfu_request_t const * p_req, nrf_dfu_response_t * p_res)
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_HARDWARE_VERSION");
    p_res->hardware.part    = NRF_FICR->INFO.PART;
    p_res->hardware.variant = NRF_FICR->INFO.VARIANT;
    /* FICR values are in Kilobytes, we report them in bytes. */
    p_res->hardware.memory.ram_size      = NRF_FICR->INFO.RAM   * 1024;
    p_res->hardware.memory.rom_size      = NRF_FICR->INFO.FLASH * 1024;
    p_res->hardware.memory.rom_page_size = NRF_FICR->CODEPAGESIZE;
static void on_fw_version_request(nrf_dfu_request_t const * p_req, nrf_dfu_response_t * p_res)
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_FIRMWARE_VERSION");
    NRF_LOG_DEBUG("Firmware image requested: %d", p_req->firmware.image_number);
    if (NRF_DFU_PROTOCOL_FW_VERSION_MSG)
        uint8_t fw_count = 1;
        if (SD_PRESENT)
            fw_count++;
        if (s_dfu_settings.bank_0.bank_code == NRF_DFU_BANK_VALID_APP)
            fw_count++;
        p_res->result = NRF_DFU_RES_CODE_SUCCESS;
        if (p_req->firmware.image_number == 0)
            /* Bootloader is always present and it is always image zero. */
            p_res->firmware.type    = NRF_DFU_FIRMWARE_TYPE_BOOTLOADER;
            p_res->firmware.version = s_dfu_settings.bootloader_version;
            p_res->firmware.addr    = BOOTLOADER_START_ADDR;
            p_res->firmware.len     = BOOTLOADER_SIZE;
        else if ((p_req->firmware.image_number == 1) && SD_PRESENT)
            /* If a SoftDevice is present, it will be firmware image one. */
            p_res->firmware.type    = NRF_DFU_FIRMWARE_TYPE_SOFTDEVICE;
            p_res->firmware.version = SD_VERSION_GET(MBR_SIZE);
            p_res->firmware.addr    = MBR_SIZE;
            p_res->firmware.len     = SD_SIZE_GET(MBR_SIZE);
        else if ((p_req->firmware.image_number < fw_count))
            /* Either there is no SoftDevice and the firmware image requested is one,
             * or there is a SoftDevice and the firmware image requested is two.
            p_res->firmware.type    = NRF_DFU_FIRMWARE_TYPE_APPLICATION;
            p_res->firmware.version = s_dfu_settings.app_version;
            p_res->firmware.addr    = nrf_dfu_app_start_address();
            p_res->firmware.len     = s_dfu_settings.bank_0.image_size;
            NRF_LOG_DEBUG("No such firmware image");
            p_res->firmware.type    = NRF_DFU_FIRMWARE_TYPE_UNKNOWN;
            p_res->firmware.version = 0x00;
            p_res->firmware.addr    = 0x00;
            p_res->firmware.len     = 0x00;
        NRF_LOG_DEBUG("NRF_DFU_OP_FIRMWARE_VERSION disabled.");
static void on_ping_request(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_PING");
    p_res->ping.id = p_req->ping.id;
void on_mtu_get_request(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_MTU_GET");
    p_res->mtu.size = p_req->mtu.size;
#endif // !NRF_DFU_PROTOCOL_REDUCED
static void on_prn_set_request(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
    UNUSED_PARAMETER(p_res);
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_RECEIPT_NOTIF_SET");
static void on_abort_request(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_ABORT");
    m_observer(NRF_DFU_EVT_DFU_ABORTED);
/* Set offset and CRC fields in the response for a 'command' message. */
static void cmd_response_offset_and_crc_set(nrf_dfu_response_t * const p_res)
    ASSERT(p_res);
    /* Copy the CRC and offset of the init packet. */
    p_res->crc.offset = s_dfu_settings.progress.command_offset;
    p_res->crc.crc    = s_dfu_settings.progress.command_crc;
static void on_cmd_obj_select_request(nrf_dfu_request_t const * p_req, nrf_dfu_response_t * p_res)
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_OBJECT_SELECT (command)");
    p_res->select.max_size = INIT_COMMAND_MAX_SIZE;
    cmd_response_offset_and_crc_set(p_res);
static void on_cmd_obj_create_request(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
    ASSERT(p_req);
    ASSERT(p_res);
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_OBJECT_CREATE (command)");
    //m_observer(NRF_DFU_EVT_DFU_STARTED);
    nrf_dfu_result_t ret_val = nrf_dfu_validation_init_cmd_create(p_req->create.object_size);
    p_res->result = ext_err_code_handle(ret_val);
static void on_cmd_obj_write_request(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
    ASSERT(p_req);
    ASSERT(p_req->write.p_data);
    ASSERT(p_req->write.len);
    ASSERT(p_res);
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_OBJECT_WRITE (command)");
    nrf_dfu_result_t ret_val;
    ret_val = nrf_dfu_validation_init_cmd_append(p_req->write.p_data, p_req->write.len);
    /* Update response. This is only used when the PRN is triggered and the 'write' message
     * is answered with a CRC message and these field are copied into the response. */
    /* If a callback to free the request payload buffer was provided, invoke it now. */
    //if (p_req->callback.write)
    //    p_req->callback.write((void*)p_req->write.p_data);
static void on_cmd_obj_execute_request(nrf_dfu_request_t const * p_req, nrf_dfu_response_t * p_res)
    ASSERT(p_req);
    ASSERT(p_res);
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_OBJECT_EXECUTE (command)");
    ret_val = nrf_dfu_validation_init_cmd_execute(&m_firmware_start_addr, &m_firmware_size_req);
    if (p_res->result == NRF_DFU_RES_CODE_SUCCESS)
        if (nrf_dfu_settings_write_and_backup(NULL) == NRF_SUCCESS)
            /* Setting DFU to initialized */
            NRF_LOG_DEBUG("Writing valid init command to flash.");
            p_res->result = NRF_DFU_RES_CODE_OPERATION_FAILED;
static void on_cmd_obj_crc_request(nrf_dfu_request_t const * p_req, nrf_dfu_response_t * p_res)
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_CRC_GET (command)");
/** @brief Function handling command requests from the transport layer.
 * @param   p_req[in]       Pointer to the structure holding the DFU request.
 * @param   p_res[out]      Pointer to the structure holding the DFU response.
 * @retval NRF_SUCCESS      If the command request was executed successfully.
 *                          Any other error code indicates that the data request
 *                          could not be handled.
void nrf_dfu_command_req(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
    ASSERT(p_req);
    ASSERT(p_res);
    switch (p_req->request)
        case NRF_DFU_OP_OBJECT_CREATE:
            on_cmd_obj_create_request(p_req, p_res);
        } break;
        case NRF_DFU_OP_CRC_GET:
            on_cmd_obj_crc_request(p_req, p_res);
        } break;
        case NRF_DFU_OP_OBJECT_WRITE:
            on_cmd_obj_write_request(p_req, p_res);
        } break;
        case NRF_DFU_OP_OBJECT_EXECUTE:
            on_cmd_obj_execute_request(p_req, p_res);
        } break;
        case NRF_DFU_OP_OBJECT_SELECT:
            on_cmd_obj_select_request(p_req, p_res);
        } break;
            ASSERT(false);
        } break;
static void on_data_obj_select_request(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_OBJECT_SELECT (data)");
    p_res->select.crc    = s_dfu_settings.progress.firmware_image_crc;
    p_res->select.offset = s_dfu_settings.progress.firmware_image_offset;
    p_res->select.max_size = DATA_OBJECT_MAX_SIZE;
    NRF_LOG_DEBUG("crc = 0x%x, offset = 0x%x, max_size = 0x%x",
                  p_res->select.crc,
                  p_res->select.offset,
                  p_res->select.max_size);
static void on_data_obj_create_request(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_OBJECT_CREATE (data)");
    if (!nrf_dfu_validation_init_cmd_present())
        /* Can't accept data because DFU isn't initialized by init command. */
        NRF_LOG_ERROR("Cannot create data object without valid init command");
        p_res->result = NRF_DFU_RES_CODE_OPERATION_NOT_PERMITTED;
        return;
    if (p_req->create.object_size == 0)
        NRF_LOG_ERROR("Object size cannot be 0.")
        p_res->result = NRF_DFU_RES_CODE_INVALID_PARAMETER;
        return;
    if (  ((p_req->create.object_size & (CODE_PAGE_SIZE - 1)) != 0)
        && (s_dfu_settings.progress.firmware_image_offset_last + p_req->create.object_size != m_firmware_size_req))
        NRF_LOG_ERROR("Object size must be page aligned");
        return;
    if (p_req->create.object_size > DATA_OBJECT_MAX_SIZE)
        /* It is impossible to handle the command because the size is too large */
        NRF_LOG_ERROR("Invalid size for object (too large)");
        p_res->result = NRF_DFU_RES_CODE_INSUFFICIENT_RESOURCES;
        return;
    if ((s_dfu_settings.progress.firmware_image_offset_last + p_req->create.object_size) >
        NRF_LOG_ERROR("Creating the object with size 0x%08x would overflow firmware size. "
                      "Offset is 0x%08x and firmware size is 0x%08x.",
                      p_req->create.object_size,
                      s_dfu_settings.progress.firmware_image_offset_last,
        return;
    s_dfu_settings.progress.data_object_size      = p_req->create.object_size;
    s_dfu_settings.progress.firmware_image_crc    = s_dfu_settings.progress.firmware_image_crc_last;
    s_dfu_settings.progress.firmware_image_offset = s_dfu_settings.progress.firmware_image_offset_last;
    s_dfu_settings.write_offset                   = s_dfu_settings.progress.firmware_image_offset_last;
    /* Erase the page we're at.
    if (nrf_dfu_flash_erase((m_firmware_start_addr + s_dfu_settings.progress.firmware_image_offset),
                            CEIL_DIV(p_req->create.object_size, CODE_PAGE_SIZE), NULL) != NRF_SUCCESS)
    if(nrf_drv_qspi_chip_erase() != NRFX_SUCCESS)
        NRF_LOG_ERROR("Erase operation failed");
        p_res->result = NRF_DFU_RES_CODE_INVALID_OBJECT;
        return;
    NRF_LOG_DEBUG("Creating object with size: %d. Offset: 0x%08x, CRC: 0x%08x",
                 s_dfu_settings.progress.data_object_size,
                 s_dfu_settings.progress.firmware_image_offset,
                 s_dfu_settings.progress.firmware_image_crc);
static void on_data_obj_write_request(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_OBJECT_WRITE (data)");
        return;
    uint32_t const data_object_offset = s_dfu_settings.progress.firmware_image_offset -
    if ((p_req->write.len + data_object_offset) > s_dfu_settings.progress.data_object_size)
        /* Can't accept data because too much data has been received. */
        NRF_LOG_ERROR("Write request too long");
        return;
    uint32_t const write_addr = m_firmware_start_addr + s_dfu_settings.write_offset;
    /* CRC must be calculated before handing off the data to fstorage because the data is
     * freed on write completion.
    uint32_t const next_crc =
        crc32_compute(p_req->write.p_data, p_req->write.len, &s_dfu_settings.progress.firmware_image_crc);
    ASSERT(p_req->callback.write);
    ret_code_t ret =
        nrf_dfu_flash_store(write_addr, p_req->write.p_data, p_req->write.len, NULL);
    if (ret != NRF_SUCCESS)
        /* When nrf_dfu_flash_store() fails because there is no space in the queue,
         * stop processing the request so that the peer can detect a CRC error
         * and retransmit this object. Remember to manually free the buffer !
        return;
    /* Update the CRC of the firmware image. */
    s_dfu_settings.write_offset                   += p_req->write.len;
    s_dfu_settings.progress.firmware_image_offset += p_req->write.len;
    s_dfu_settings.progress.firmware_image_crc     = next_crc;
    /* This is only used when the PRN is triggered and the 'write' message
    p_res->write.crc    = s_dfu_settings.progress.firmware_image_crc;
    p_res->write.offset = s_dfu_settings.progress.firmware_image_offset;
static void on_data_obj_crc_request(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_CRC_GET (data)");
    NRF_LOG_DEBUG("Offset:%d, CRC:0x%08x",
    p_res->crc.crc    = s_dfu_settings.progress.firmware_image_crc;
    p_res->crc.offset = s_dfu_settings.progress.firmware_image_offset;
 * Function that validates firmware in external memory and writes to internal memory
//static void on_data_obj_execute_external_memory(void)
//    ret_code_t          ret;
//    nrf_dfu_response_t res =
//        .request = NRF_DFU_OP_OBJECT_EXECUTE,
//    //if the offset is equal to the expected image size
//    if (s_dfu_settings.progress.firmware_image_offset == m_firmware_size_req)
//        NRF_LOG_DEBUG("Whole firmware image received. Postvalidating NOR flash.");
//        res.result = nrf_dfu_validation_post_data_execute(0x12000000, m_firmware_size_req); //validate code in external memory
//        res.result = ext_err_code_handle(res.result);//check if validation had any errors
//        if(res.result ==NRF_DFU_RES_CODE_SUCCESS)//if validation successful
//            //erase internal flash space for firmware
//            if (nrf_dfu_flash_erase(m_firmware_start_addr,
//                            CEIL_DIV(m_firmware_size_req, CODE_PAGE_SIZE), NULL) != NRF_SUCCESS)
//                NRF_LOG_ERROR("Erase operation failed");
//                res.result = NRF_DFU_RES_CODE_INVALID_OBJECT;
//                return;
//            int image = 0;
//            while( image != m_firmware_size_req)
//               uint32_t write_addr = m_firmware_start_addr + image;//offset flash address
//               memset(m_rx_buff,0,sizeof(m_rx_buff));//clear buffer
//               if((image) < m_firmware_size_req)//if the current image size is less that the required image size
//                  ret = nrf_drv_qspi_read(m_rx_buff,sizeof(m_rx_buff),image);//read qspi
//                  APP_ERROR_CHECK(ret);
//                  nrf_delay_ms(50);//wait for read function to be done
//                  ret = nrf_dfu_flash_store(write_addr,m_rx_buff, sizeof(m_rx_buff), NULL);//store memory in flash
//                  image = image + 64; //increment current image size by the required mtu size
//               else
//                  ret = nrf_drv_qspi_read(m_rx_buff,sizeof(m_firmware_size_req-image),image);//read the rest of the firmware stored in memory
//                  ret = nrf_dfu_flash_store(write_addr,m_rx_buff,sizeof(m_firmware_size_req-image),NULL);//write the rest of the firmware to flash
//                  image = m_firmware_size_req;//set the image size equal to the required firmware size
//               printf("Current image size: %i\n",image);
//          nrf_drv_qspi_uninit();//uninitialize qspi
static void on_data_obj_execute_request_sched(void * p_evt, uint16_t event_length)
    UNUSED_PARAMETER(event_length);
    ret_code_t          ret;
    nrf_dfu_request_t * p_req = (nrf_dfu_request_t *)(p_evt);
    /* Wait for all buffers to be written in flash. */
    if (nrf_fstorage_is_busy(NULL))
        ret = app_sched_event_put(p_req, sizeof(nrf_dfu_request_t), on_data_obj_execute_request_sched);
            NRF_LOG_ERROR("Failed to schedule object execute: 0x%x.", ret);
        return;
        NRF_LOG_DEBUG("Whole firmware image received. Postvalidating.");
        #if NRF_DFU_IN_APP
        res.result = nrf_dfu_validation_post_data_execute(m_firmware_start_addr, m_firmware_size_req);
        #else
        res.result = nrf_dfu_validation_activation_prepare(m_firmware_start_addr, m_firmware_size_req);
        /* Provide response to transport */
        p_req->callback.response(&res, p_req->p_context);
        ret = nrf_dfu_settings_write_and_backup((nrf_dfu_flash_callback_t)on_dfu_complete);
        UNUSED_RETURN_VALUE(ret);
        res.result = NRF_DFU_RES_CODE_SUCCESS;
        if (NRF_DFU_SAVE_PROGRESS_IN_FLASH)
            /* Allowing skipping settings backup to save time and flash wear. */
            ret = nrf_dfu_settings_write_and_backup(NULL);
    NRF_LOG_DEBUG("Request handling complete. Result: 0x%x", res.result);
static bool on_data_obj_execute_request(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_OBJECT_EXECUTE (data)");
    uint32_t const data_object_size = s_dfu_settings.progress.firmware_image_offset -
    if (s_dfu_settings.progress.data_object_size != data_object_size)
        /* The size of the written object was not as expected. */
        NRF_LOG_ERROR("Invalid data. expected: %d, got: %d",
                      data_object_size);
        return true;
    /* Update the offset and crc values for the last object written. */
    s_dfu_settings.progress.data_object_size           = 0;
    s_dfu_settings.progress.firmware_image_crc_last    = s_dfu_settings.progress.firmware_image_crc;
    s_dfu_settings.progress.firmware_image_offset_last = s_dfu_settings.progress.firmware_image_offset;
    //on_data_obj_execute_external_memory();
    on_data_obj_execute_request_sched(p_req, 0);
    m_observer(NRF_DFU_EVT_OBJECT_RECEIVED);
    return false;
bool nrf_dfu_data_req(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
    ASSERT(p_req);
    ASSERT(p_res);
    bool response_ready = true;
            on_data_obj_create_request(p_req, p_res);
        } break;
            on_data_obj_write_request(p_req, p_res);
        } break;
            on_data_obj_crc_request(p_req, p_res);
        } break;
            response_ready = on_data_obj_execute_request(p_req, p_res);
        } break;
            on_data_obj_select_request(p_req, p_res);
        } break;
            ASSERT(false);
        } break;
    return response_ready;
/**@brief Function for handling requests to manipulate data or command objects.
 * @param[in]  p_req    Request.
 * @param[out] p_res    Response.
 * @return  Whether response is ready to be sent.
static bool nrf_dfu_obj_op(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
    /* Keep track of the current object type since write and execute requests don't contain it. */
    static nrf_dfu_obj_type_t current_object = NRF_DFU_OBJ_TYPE_COMMAND;
    if (    (p_req->request == NRF_DFU_OP_OBJECT_SELECT)
        ||  (p_req->request == NRF_DFU_OP_OBJECT_CREATE))
        STATIC_ASSERT(offsetof(nrf_dfu_request_select_t, object_type) ==
                      offsetof(nrf_dfu_request_create_t, object_type),
                      "Wrong object_type offset!");
        current_object = (nrf_dfu_obj_type_t)(p_req->select.object_type);
    switch (current_object)
        case NRF_DFU_OBJ_TYPE_COMMAND:
            nrf_dfu_command_req(p_req, p_res);
        case NRF_DFU_OBJ_TYPE_DATA:
            response_ready = nrf_dfu_data_req(p_req, p_res);
            /* The select request had an invalid object type. */
            NRF_LOG_ERROR("Invalid object type in request.");
            current_object = NRF_DFU_OBJ_TYPE_INVALID;
static void nrf_dfu_req_handler_req_process(nrf_dfu_request_t * p_req)
    ASSERT(p_req->callback.response);
    /* The request handlers assume these values to be set. */
    nrf_dfu_response_t response =
        .request = p_req->request,
        .result  = NRF_DFU_RES_CODE_SUCCESS,
        case NRF_DFU_OP_PROTOCOL_VERSION:
            on_protocol_version_request(p_req, &response);
        } break;
        case NRF_DFU_OP_HARDWARE_VERSION:
            on_hw_version_request(p_req, &response);
        } break;
        case NRF_DFU_OP_FIRMWARE_VERSION:
            on_fw_version_request(p_req, &response);
        } break;
        case NRF_DFU_OP_PING:
            on_ping_request(p_req, &response);
        } break;
        case NRF_DFU_OP_MTU_GET:
            on_mtu_get_request(p_req, &response);
        } break;
        case NRF_DFU_OP_RECEIPT_NOTIF_SET:
            on_prn_set_request(p_req, &response);
        } break;
        case NRF_DFU_OP_ABORT:
            on_abort_request(p_req, &response);
        } break;
            /* Restart the inactivity timer on CREATE messages. */
            /* Fallthrough. */
            response_ready = nrf_dfu_obj_op(p_req, &response);
        } break;
            NRF_LOG_INFO("Invalid opcode received: 0x%x.", p_req->request);
            response.result = NRF_DFU_RES_CODE_OP_CODE_NOT_SUPPORTED;
    if (response_ready)
        NRF_LOG_DEBUG("Request handling complete. Result: 0x%x", response.result);
        p_req->callback.response(&response, p_req->p_context);
        if (response.result != NRF_DFU_RES_CODE_SUCCESS)
            m_observer(NRF_DFU_EVT_DFU_FAILED);
static void nrf_dfu_req_handler_req(void * p_evt, uint16_t event_length)
    nrf_dfu_req_handler_req_process(p_req);
ret_code_t nrf_dfu_req_handler_on_req(nrf_dfu_request_t * p_req)
    ret_code_t ret;
    if (p_req->callback.response == NULL)
        return NRF_ERROR_INVALID_PARAM;
    ret = app_sched_event_put(p_req, sizeof(nrf_dfu_request_t), nrf_dfu_req_handler_req);
        NRF_LOG_WARNING("Scheduler ran out of space!");
    return ret;
ret_code_t nrf_dfu_req_handler_init(nrf_dfu_observer_t observer)
    ret_code_t       ret_val;
    nrf_dfu_result_t result;
    if (observer == NULL)
    ret_val  = nrf_dfu_flash_init(true);
#else
        return ret_val;
        /* Execute a previously received init packed. Subsequent executes will have no effect. */
        result = nrf_dfu_validation_init_cmd_execute(&m_firmware_start_addr, &m_firmware_size_req);
        if (result != NRF_DFU_RES_CODE_SUCCESS)
            /* Init packet in flash is not valid! */
    m_observer = observer;
    /* Initialize extended error handling with "No error" as the most recent error. */
    result = ext_error_set(NRF_DFU_EXT_ERROR_NO_ERROR);
    UNUSED_RETURN_VALUE(result);
    return NRF_SUCCESS;
  • Update: I have fixed the write error, and the bootloader is able to step all the way through via the debugger. However, when it finally disable the interrupts, the application is not activating. I checked flash memory and saw that the firmware was written correctly and so was the updated start address. I have attached my debug output. Please let me know if you have any ideas as to why this is occurring.
    <info> app: Inside main
    <debug> app: In nrf_bootloader_init
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <warning> nrf_dfu_settings: Resetting bootloader settings since neither the settings page nor the backup are valid (CRC error).
    <debug> nrf_dfu_settings: Writing settings...
    <debug> nrf_dfu_settings: Erasing old settings at: 0x000FF000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FF000, len=1 pages), queue usage: 0
    <debug> nrf_dfu_flash: Flash erase success: addr=0x000FF000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FF000, src=0x20003D2C, len=896 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000FF000, pending 0
    <info> nrf_dfu_settings: Backing up settings page to address 0xFE000.
    <debug> nrf_dfu_settings: Erasing old settings at: 0x000FE000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FE000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x000FE000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FE000, src=0x200040AC, len=896 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000FE000, pending 0
    <debug> app: Enter nrf_bootloader_fw_activate
    <info> app: No firmware to activate.
    <info> app: Boot validation failed. No valid app to boot.
    <debug> app: DFU mode because app is not valid.
    <info> nrf_bootloader_wdt: WDT is not enabled
    <debug> app: in weak nrf_dfu_init_user
    <debug> app: timer_stop (0x2000005C)
    <info> app: Entering DFU mode.
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_MTU_GET
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (command)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
    <debug> nrf_dfu_validation: PB: Init packet data len: 62
    <debug> app: Enter nrf_dfu_cache_prepare()
    <debug> app: required_size: 0x5E4.
    <debug> app: single_bank: false.
    <debug> app: keep_app: false.
    <debug> app: keep_softdevice: false.
    <debug> app: SD_PRESENT: false.
    <debug> app: Bank contents:
    <debug> app: Bank 0 code: 0x00: Size: 0x0
    <debug> app: Bank 1 code: 0x00: Size: 0x0
    <debug> app: pass: 0.
    <debug> app: cache_address: 0x1000.
    <debug> app: cache_too_small: false.
    <debug> app: keep_firmware: false.
    <debug> app: delete_more: false.
    <debug> nrf_dfu_validation: Write address set to 0x00001000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FF000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_req_handler: Writing valid init command to flash.
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (data)
    <debug> nrf_dfu_req_handler: crc = 0x0, offset = 0x0, max_size = 0x1000
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    <debug> nrf_dfu_req_handler: Creating object with size: 1508. Offset: 0x00000000, CRC: 0x00000000
    a)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001000, src=0x2003FE68, len=200 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00001000, pending 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000010C8, src=0x2003FE68, len=200 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000010C8, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001190, src=0x2003FE68, len=200 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00001190, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001258, src=0x2003FE68, len=200 bytes), queue usage: 1
    ding 0
    a)
    ding 0
    a)
    ding 0
    a)
    <debug> nrf_dfu_settings: Using settings page.
    <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
    <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    <debug> app: Valid App
    <debug> app: Enter nrf_dfu_app_continue
    <debug> app: No copy needed
    <debug> app: Setting app as valid
    <debug> app: Resetting bootloader.
    <debug> app: App is valid
    <warning> nrf_dfu_settings: No additional data erased
    <debug> app: Running nrf_bootloader_app_start with address: 0x00001000
    <debug> app: Disabling interrupts. NVIC->ICER[0]: 0x0
  • Have you turned off compiler optimization for your bootloader project? In that case, you may be encountering the bug mentioned in this other forum thread: https://devzone.nordicsemi.com/f/nordic-q-a/62777/need-help-with-custom-dfu-bootloader-transferring-back-to-main-app/255924#255924
