Can keil compiled library be used in segger embedded studio?
dear all
    Can keil compiled library be used in segger embedded studio? For example, I have a paw8001_ ofn114009_ 12_ m4f_ keil.lib
Library, can I put it directly into NRF connect SDK project to compile?
Best Regards
  • hi
    I put the config_ COMPILER_ Opt = - LM "into my pri.conf, the problem still exists, But there's one amazing thing,When I put the following code in *. C,Even though I don't make any calls。The compilation is successful。
    It looks like there's something wrong with the compiler。
    #include <math.h>
    #if(1)
    int compare(const void *, const void *);
    void test(void)
    const char *a[10] = {"enter", "number", "size", "begin", "of", "cat", "case","program","certain","a"};
    float op;
    float result;
    op = 0.08;
    result= sqrtf(op);
    result= log10f(op);
    result= expf(op);
    result= cosf(op);
    qsort(a, 10, sizeof(a[0]), compare);
    result= tanf(op);
    result= sinf(op);
    result= logf(op);
    int compare(const void *c, const void *d)
    int m,n,r;
    char **a, **b; // !!
    a = (char **)c;
    b = (char **)d;
    m = strlen(*a);
    n = strlen(*b);
    r = m - n;
    if (r != 0)
    return r;
    return memcmp(*a,*b,m);
    best regards
    It is good you have a work around, but it seems odd. I agree this seems like a compiler issue. I am not able to find any reference to this, but perhaps it is worth testing a different GCC version (though the workaround seems fair enough).
  • dear Einar Thorsrud
     By the way
     I encountered a strange problem with mcuboot in ncs1.6.0, and the program has been running for a long time  to FIH_PANIC  and It's not going to work.
      FIH_CALL(boot_go, fih_rc, &rsp);
      if (fih_not_eq(fih_rc, FIH_SUCCESS)) {
        BOOT_LOG_ERR("Unable to find bootable image");
        FIH_PANIC;
    Please ask what causes this?
    best regards
    Please open a new case for this question as it is not directly related to the original topic. (Also, I will be OoO from three weeks from today and unable to reply.)
