Increase size of custom SPM partition
I am using NCS v1.5.0 and my application runs in non-secure mode, and uses a custom SPM. Initially all build and ran correctly, and the SPM fit in a 32 KB partition. Then I added some secure services and the SPM image size increased and I got this build error:
           FLASH:         64 KB        48 KB    133.33%
            SRAM:        8568 B        64 KB     13.07%
        IDT_LIST:          40 B         2 KB      1.95c:/nordic/v1.5.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr\zephyr_prebuilt.elf section `.gnu.sgstubs' will not fit in region `FLASH'
c:/nordic/v1.5.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: SPM and app are sharing an SPU region. Cannot partition flash correctly into secure and non-secure. Adjust partitions sizes so they are placed in separate regions.
c:/nordic/v1.5.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: region `FLASH' overflowed by 16384 bytes
collect2.exe: error: ld returned 1 exit status
Looking at the partition manager setup for the SPM pm.yml file, I noticed that the size of the SPM partition was set by this config item CONFIG_PM_PARTITION_SIZE_SPM.
So in the custom SPM project options (file prj.conf) I added CONFIG_PM_PARTITION_SIZE_SPM=0x010000, making the SPM partition size 64 KB because the size of the custom SPM became 48 KB and the SoC internal flash has 32 KB pages.
After this change everything builds correctly:
[27/352] Performing build step for 'spm_subimage'
[190/195] Linking C executable zephyr\zephyr_prebuilt.elf
Memory region Used Size Region Size %age Used
FLASH: 64 KB 64 KB 100.00%
IDT_LIST: 40 B 2 KB 1.95%
[195/195] Linking C executable zephyr\zephyr.elf
but when it runs it is misteriously stuck in the function Zephyr OS initial thread and ends up in function "arch_cpu_idle()".
Then I changed config item value from hexadecimal to decimal, CONFIG_PM_PARTITION_SIZE_SPM=65536. But the build fails:
[24/352] Performing build step for 'spm_subimage'
           FLASH:         64 KB     415029 B     15.79%
(... building the application ...)
[346/352] Linking C executable zephyr\zephyr_prebuilt.elf
FAILED: zephyr/zephyr_prebuilt.elf
cmd.exe /C "cd . && C:\Nordic\v1.5.0\toolchain\opt\bin\arm-none-eabi-gcc.exe    zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj  -o zephyr\zephyr_prebuilt.elf  -Wl,-T  zephyr/linker.cmd  -Wl,-Map=C:/workspace/repos/DNG/build/zephyr/zephyr_prebuilt.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/libarch__arm__core__aarch32__cortex_m__mpu.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a  zephyr/lib/libc/newlib/liblib__libc__newlib.a  zephyr/lib/posix/liblib__posix.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/subsys/net/libsubsys__net.a  zephyr/subsys/net/ip/libsubsys__net__ip.a  zephyr/subsys/random/libsubsys__random.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/spi/libdrivers__spi.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/entropy/libdrivers__entropy.a  modules/nrf/lib/nrf_modem_lib/lib..__nrf__lib__nrf_modem_lib.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a  C:/Nordic/v1.5.0/nrfxlib/nrf_modem/lib/cortex-m33/hard-float/libmodem.a  modules/nrfxlib/nrf_security/src/mbedtls/libmbedtls_base_vanilla.a  modules/hal_nordic/libmodules__hal_nordic.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -L"c:/nordic/v1.5.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/thumb/v8-m.main+fp/hard"  -LC:/workspace/repos/DNG/build/zephyr  -lgcc  -Wl,--print-memory-usage  ../mbus/build/libmbusStack.a  ../dlms_server/build/libDlmsServer.a  zephyr/arch/common/libisr_tables.a  modules/nrfxlib/nrf_security/src/mbedtls/shared/libmbedcrypto_shared.a  modules/nrfxlib/nrf_security/src/mbedtls/oberon/libmbedcrypto_oberon.a  -mcpu=cortex-m33  -mthumb  -mabi=aapcs  -mfpu=fpv5-sp-d16  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -no-pie  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  spm/libspmsecureentries.a  -lm  -Wl,-lc  -L"C:/Nordic/v1.5.0/toolchain/opt/arm-none-eabi"/lib/thumb/v8-m.main+fp/hard  -Wl,-lgcc  -lc  -specs=nano.specs && cd ."
c:/nordic/v1.5.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe:zephyr/linker.cmd:58 cannot move location counter backwards (from 00065744 to 00065738)
FATAL ERROR: command exited with status 1: 'C:\Nordic\v1.5.0\toolchain\opt\bin\cmake.EXE' --build 'c:\workspace\repos\DNG\build'
Notice that the indication of the SPM used space is now correct, from when I used the hexadecimal value. But the build still fails:
What is the proper way to specify the size of the SPM partion, when using a custom build SPM ?
