What exactly does the nrf_serial_flush?
I'm doing a project with Zigbee using the nRF52840 and I want to read some sensors that talk via UART.
I have ported with success the nrf_uart example but after discovering that this library doesn't have support for multiple UART instances I've changed to the nrf_serial library.
Everything is working, but I'm lacking some understandings regarding for instance the nrf_serial_flush() function. What is the purpose of this function? In the beginning, I thought that the purpose of this function was to clear out the buffer and assure the transmission in a blocking state. However, that's not true.
I want to be able to toggle a GPIO pin after the transmission done, like having a transmission done pin. How can I do that? I'm using DMA and for now, the only way that I discover to do that was by using the nrf_queue_is_empty() function to constantly check if the queue is already empty.... That solves the problem but creates an unnecessary overhead to the CPU in my option because I'm polling the nrf_queue_is_empty() function.
Thanks in advance,
Fernando
  • Yes, I have both 32Mhz and 32.768kHz external clocks. I tried to call the nrf_drv_clock_hfclk_request and the behavior is still the same. One of the tasks that I'm running in parallel is a Zigbee application and I noticed that with that task off, the framing errors are very low. So, I did a quick search to see if the easyDMA of UART1 is using repeated addresses but I guess no. I'm starting to think that this is somehow a priority-related issue... Is that possible? How are the DMA to RAM transfers being handled? Do I need to change the priority values?
     The priority of ISR handling becomes very important if you are not using HW flow control. But with this, i would still expect to see overrun errors and not framing errors.
    I cannot put my head around this behavior. Are you seeing less errors per average transaction or are you seeing less errors per average time? Because if it is the second, I could understand as Zigbee task and stack taking more time to process its data and giving UART ISR less time to process its data.
    nrf_serial is somewhat less preffered library over libuarte and is also a reason we removed it from latest SDKs. Can you please try to move to libuarte? I know that this sounds like work, but there could be only two possibilities to explore. One is clock inaccuracies and the other is possible nrf_serial bug. I know that the libuarte is very stable so atleast we can exclude one suspecting direction.
  • Well, I switched to the app_uart_fifo implementation. It's a lot more stable than the nrf_serial. Libuarte would be my next option. But since app_uart_fifo seems to be stable I will stick with this one.
    However, I've just finished the implementation a few minutes ago. It would be great if you could explain a few things about app_uart_fifo implementation.
    How is handled the reception in this implementation? Is it by interrupts? I know that there is an event handler putting the RX data into a buffer, but is this module still using easyDMA?
     Yes, it is interrupt based which is handled in nrfx_uarte.c/nrfx_uart.c. If EasyDMA is used or not depends on what you have set in nRF5_SDK_17.0.2_d674dde\integration\nrfx\legacy\apply_old_config.h NRFX_UARTE_ENABLED which inturn depends on your settings in sdk_config.h.   Just set UARTX_ENABLED and UART_EASY_DMA_SUPPORT to 1 in sdk_config.h and you will see that easydma will be used though the hal driver nrfx_uarte.c
