How to specify signing the key with MCUBoot
I am using NCS v1.5.0 and an nRF9160 on a custom board, my application has a custom SPM and the secondary slot for the firmware image upgrade is stored on an external flash.
I generated a private key, and I am passing it to the MCUBoot as CONFIG_BOOT_SIGNATURE_KEY_FILE="C:/workspace/repos/DNG/keys/development_private.pem". This key appears to be used because I see during the build process:
=== child image mcuboot - begin ===
Including boilerplate (Zephyr base): C:/Nordic/v1.5.0/zephyr/cmake/app/boilerplate.cmake
-- Application: C:/Nordic/v1.5.0/bootloader/mcuboot/boot/zephyr
-- Using NCS Toolchain 1.5.0 for building. (C:/Nordic/v1.5.0/toolchain/cmake)
-- Zephyr version: 2.4.99 (C:/Nordic/v1.5.0/zephyr)
-- Found Python3: C:/Nordic/v1.5.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.9.0", minimum required is "0.7.1")
-- Board: dng_nrf9160
-- Cache files will be written to: C:/Nordic/v1.5.0/zephyr/.cache
-- Found dtc: C:/Nordic/v1.5.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (C:/Nordic/v1.5.0/toolchain/opt)
-- Found BOARD.dts: C:/workspace/repos/DNG/boards/arm/dng_nrf9160/dng_nrf9160.dts
-- Found devicetree overlay: C:/Nordic/v1.5.0/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: C:/workspace/repos/DNG/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/workspace/repos/DNG/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/workspace/repos/DNG/build/mcuboot/zephyr/include/generated/device_extern.h
Parsing C:/Nordic/v1.5.0/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration 'C:/workspace/repos/DNG/boards/arm/dng_nrf9160/dng_nrf9160_defconfig'
Merged configuration 'C:/Nordic/v1.5.0/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'C:/workspace/repos/DNG/mcuboot.conf'
Configuration saved to 'C:/workspace/repos/DNG/build/mcuboot/zephyr/.config'
Kconfig header saved to 'C:/workspace/repos/DNG/build/mcuboot/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: C:/Nordic/v1.5.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
MCUBoot bootloader key file: C:/workspace/repos/DNG/keys/development_private.pem
-- Configuring done
-- Generating done
-- Build files have been written to: C:/workspace/repos/DNG/build/mcuboot
=== child image mcuboot - end ===
The problem is that on startup, MCUBoot complains that it cannot find the image:
*** Booting Zephyr OS build v2.4.99-ncs1 ***
[00:00:00.380,249] <inf> mcuboot: Starting bootloader
[00:00:00.380,920] <wrn> mcuboot: Failed reading sectors; BOOT_MAX_IMG_SECTORS=256 - too small?
[00:00:00.380,981] <err> mcuboot: Image in the primary slot is not valid!
[00:00:00.380,981] <err> mcuboot: Unable to find bootable image
I suspect this is related to the signing keys used, but I cannot understand why or where the problem is occuring.
I tried adding CONFIG_BOOT_SIGNATURE_KEY_FILE="C:/workspace/repos/DNG/keys/development_private.pem" to the application prj.conf, but got this warning:
warning: BOOT_SIGNATURE_KEY_FILE (defined at C:/Nordic/v1.5.0/nrf\modules\Kconfig.mcuboot:10) was
assigned the value 'C:/workspace/repos/DNG/keys/development_private.pem' but got the value ''. Check
these unsatisfied dependencies: (!MCUBOOT_BUILD_STRATEGY_FROM_SOURCE) (=n). See
docs.zephyrproject.org/.../CONFIG_BOOT_SIGNATURE_KEY_FILE.html and/or
look up BOOT_SIGNATURE_KEY_FILE in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
might be helpful too.
The project configurations and options are in this zip file: 8081.project.zip
My understanding is that the build system is given the private key (through the option CONFIG_BOOT_SIGNATURE_KEY_FILE) and then:
1. the MCUBoot build process generates the *public key*, converts it to a C array and it gets hardcoded in the bootloader firmware
2. the application build system uses the *private key* to sign the image using the image tool
3. finally, the bootloader and the signed application (my application + custom SPM) are merged into a single hex file
4. the command "west flash" flashes the combined bootloader + app hex
Is this correct ? If so, how can I specify the private key to the build process of MCUBoot and my application ?
I found similar issues in this link and also this one, but the anwsers were not clear to me.
