Hello!
I'd like to briefly introduce what I'm attempting to do: I'm trying to flash some samples from the Zephyr project into a custom board. The custom board is based on the RAK5010 which is supported by the project and uses nRF52840 as the chipset.
I am capable of building the samples from Zephyr and can see them work on the nRF52840-DK. So regarding setup for compiling and flashing, I believe I'm with the right setup.
The issue that I'm seeing is that when flashing a sample to the custom board, I'm "losing" connection with the USB.
For instance, this is what I have before flashing the "hello world" example:
$ ls /dev | grep ttyACM
ttyACM0
ttyACM1
$ ls /dev | grep ttyUSB
As you can see, there are 2 devices connected: ACM0 is the microusb connection with the board, while ACM1 is the connection done via JTAG.
I cannot flash to the custom board directly without a JTAG, as the tool isn't capable of seeing the board with the nrfjprog --ids command.
However, using the JTAG I can flash and the flash is sucessfull as can be seen in the following logs:
Flash output
$ west flash --erase
-- west flash: rebuilding
ninja: no work to do.
-- west flash: using runner nrfjprog
-- runners.nrfjprog: mass erase requested
Using board 59400959
-- runners.nrfjprog: Flashing file: /home/rys/Documents/repositorios/poc_nrf52840/zephyr/build/zephyr/zephyr.hex
Parsing image file.
Erasing user available code and UICR flash areas.
Applying system reset.
Checking that the area to write is not protected.
Programming device.
Enabling pin reset.
Applying pin reset.
-- runners.nrfjprog: Board with serial number 59400959 flashed successfully.
ttyACM1
I also tried to flash without the JTAG, but the board is never recognized by the nrfjprog tool during "west flash".
However, even though I'm capable of compiling and flashing successfully to the board (at least according to the logs), I cannot see the LED blink.
