HI,
I have already got output from each of the SHT20 and MLX90614 sensors. Now I want to combine both the code. Regards, I need an help to Setup prj.conf file
Thanks & Regards
Navin
HI,
provide the applications you want to combine
I will send my applications and also share my prj.conf file here. Kindly check that and tell me if anything is wrong
Thanks & Regards
Navin
Hi Heidi,
5732.nrf5340dk_nrf5340_cpuapp.overlay
while opening the project with the above overlay file I have facing the error called
create_nordic_project.py failed (1)
the log was
Creating solution VET_Firm.emProject F:/v1.5.0/toolchain/opt/bin/cmake.exe -GNinja -DBOARD=nrf5340dk_nrf5340_cpuapp -DBOARD_DIR=F:\v1.5.0\zephyr\boards\arm\nrf5340dk_nrf5340 -BF:\v1.5.0\zephyr\samples\MyProjects\VET_Firm\build_nrf5340dk_nrf5340_cpuapp -SF:\v1.5.0\zephyr\samples\MyProjects\VET_Firm -DNCS_TOOLCHAIN_VERSION=1.5.0 -DDTC_OVERLAY_FILE=F:\v1.5.0\zephyr\samples\MyProjects\VET_Firm/nrf5340dk_nrf5340_cpuapp.overlay -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=F:\v1.5.0\toolchain\segger_embedded_studio/html/configure_nordic_project_menuconfig.py -- Application: F:/v1.5.0/zephyr/samples/MyProjects/VET_Firm -- Zephyr version: 2.4.99 (F:/v1.5.0/zephyr) -- Found Python3: F:/v1.5.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter -- Found west (found suitable version "0.9.0", minimum required is "0.7.1") -- Board: nrf5340dk_nrf5340_cpuapp -- Cache files will be written to: F:/v1.5.0/zephyr/.cache -- Found dtc: F:/v1.5.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6") -- Found toolchain: gnuarmemb (F:/v1.5.0/toolchain/opt) -- Found BOARD.dts: F:/v1.5.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts -- Found devicetree overlay: F:/v1.5.0/zephyr/samples/MyProjects/VET_Firm/nrf5340dk_nrf5340_cpuapp.overlay -- Configuring incomplete, errors occurred! Including boilerplate (Zephyr base): F:/v1.5.0/zephyr/cmake/app/boilerplate.cmake -- Using NCS Toolchain 1.5.0 for building. (F:/v1.5.0/toolchain/cmake) devicetree error: 'interrupts' is marked as required in 'properties:' in F:/v1.5.0/zephyr/dts/bindings\i2c\nordic,nrf-twim.yaml, but does not appear in <Node /soc/peripheral@50000000/i2c@8000/BNO055@28 in 'nrf5340dk_nrf5340_cpuapp.dts.pre.tmp'> CMake Error at F:/v1.5.0/zephyr/cmake/dts.cmake:229 (message): gen_defines.py failed with return code: 1 Call Stack (most recent call first): F:/v1.5.0/zephyr/cmake/app/boilerplate.cmake:533 (include) F:/v1.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include) F:/v1.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate) CMakeLists.txt:8 (find_package) error: cmake failed create_nordic_project.py failed (1)
I think the above error is because of the Device tree. Already, You know our requirements. Kindly check my overlay file and correct me.
Kindly respond, We are waiting for a long time.
Thanks & Regards
Navin
Hi
As I mentioned earlier, due to the summer holidays, long wait times on DevZone are to be expected.
In the log, it says
so you need to add the "interrupts" field in all the I2C sub-nodes, because it's specified as required by the binding file.
After taking a closer look, I see that you're defining all the sub-nodes with the "nordic, nrf-twim" binding, which is incorrect.
For the compatible-property of the sub-nodes, you need to use the vendor specific bindings, not "nordic,nrf-twim".
For example, in the BME680 Sample, the BME680 device is defined with the BME680 binding:
&i2c0 {
bme680@76 {
compatible = "bosch,bme680";
reg = <0x76>;
label = "BME680";
Source: zephyr/samples/sensor/b,e680/boards/nrf52840dk_nrf52840.overlay-L9
It doesn't look like any of the devices you are using have a binding definition in Zephyr (see the Bindings index for a complete list of available devicetree bindings in Zephyr).
