Join an existing mesh Network with a mesh provisioner (nrf mesh sdk)
Is it possible to join an existing mesh network with a provisioner made on Nrf52840 (s140)  ?
I have used the provisioner example to make a provisioner which actually create a new mesh network. But after an "erase all" of the board, the provisioning data are lost and the board can't reconnect to the network because information are lost during the erase (logic).
Is there a way to extract the provisioning data and mesh network data from the board to use them later on an other board ?
My goal is to create a mesh network with a device, then store in a file all the information related to this network to be able later with another board to join this network and add new devices.
I have setup a serial connection to send data through the usb port to my computer so I could retrieve and return the data by this method.
I know that this is possible in the mobile application with the "export network" and "import network" functions but I can't reproduce the functionality with the mesh SDK.
Is this possible? If yes how?
Regards
Used sdk :
- nRF5_SDK_16.0.0_98a08e2
- nrf5_SDK_for_Mesh_v4.2.0_src
Board used :
- nrf52840 evaluation board
- nrf52832 evaluation board
    Sorry for the late response.
    I made more tests and this what I got :
    1- I have tried to change the IV index tolerance (NETWORK_IV_RECOVERY_LIMIT ) of one node and the provisioner but nothing append because the tolerance is only for higher number : for example if the iv index is 30 and the tolerance is set to 10, the accepted incoming IV index are from 30 to 40 (and not 20 to 40). The issue is that when I reload the network, the provisioner index is set to 0, so its below the node index and nothing append.
    2- Considering that the health model used the iv index like other model and that I got instant alive event when I reload the network, I thought maybe it was my vendor model that had a problem.
    So I tried to launch a reconfiguration of the nodes when loading the network. For that I stored the devkey of my node and I reloaded it in memory when the network was loaded.
    I then waited for an alive event then I launched a configuration procedure from the provisioner for the node (node_setup_start) but nothing happened because the configuration model of the node did not respond. It ended up responding after 5 minutes like the other model.
    So I think that the event alive of the health model works differently from the rest and should potentially not use the iv index.
    3- I also noticed that if I reload my network on the provisioner and turn off and on my node, then all the models in the node respond instantly
    4- I would like to test the modification of the iv index of a node (as suggested in your message) but I can't find where to do it in the code. The incoming_data_received function that you give to me is only for check and update the iv index if needed but it runs if the message is valid, but when I reload my network and the models other than health don't respond, this function is never called (both on the node and the provisioner side).
    Regards
  • Hi Neicureuil,
    1. What you described is about right. That how it should work. You should have a way of communication between the old provisioner and the new provisioner to send the current IV Index, otherwise provisioning process is needed.
    2. 3. I don't have an answer for this. I would need to study the code a little bit more.
    4. Could you try what I suggested :
    The current IV Index is stored in m_net_state.iv_index in net_state.c .  If the device is provisioned the IV index is restored when the mesh config is loaded from flash (mesh_config_load). When net_state_enable() (restored_result_apply()) is called the IV index from flash will be applied to  m_net_state.iv_index.
    I just tried to debug the iv index with "net_state_beacon_iv_index_get()" on both side. I'm surprised to see that its return 0 on the both side, even after model commands sending.
    Regards
  • Hi Neicureruil,
    When did you call this function ? It's normal for a network to start with IV index = 0.
    I call it each time I received an alive event, and each time I received a model command acknowledgment.
    I have tried to set a custom IV index just after the mesh init and start function with net_state_iv_index_set. But same thing append, each time I debug it (same places that before) its return the same index (the index that I previously set) and its never increase.
    Regards
