Join an existing mesh Network with a mesh provisioner (nrf mesh sdk)
Is it possible to join an existing mesh network with a provisioner made on Nrf52840 (s140)  ?
I have used the provisioner example to make a provisioner which actually create a new mesh network. But after an "erase all" of the board, the provisioning data are lost and the board can't reconnect to the network because information are lost during the erase (logic).
Is there a way to extract the provisioning data and mesh network data from the board to use them later on an other board ?
My goal is to create a mesh network with a device, then store in a file all the information related to this network to be able later with another board to join this network and add new devices.
I have setup a serial connection to send data through the usb port to my computer so I could retrieve and return the data by this method.
I know that this is possible in the mobile application with the "export network" and "import network" functions but I can't reproduce the functionality with the mesh SDK.
Is this possible? If yes how?
Regards
Used sdk :
- nRF5_SDK_16.0.0_98a08e2
- nrf5_SDK_for_Mesh_v4.2.0_src
Board used :
- nrf52840 evaluation board
- nrf52832 evaluation board
    Oh ok. I thought the index was incrementing with each command.
    So, the fact that the config and custom model don't respond during the 5-10 minutes after the network reload while the health model receives the alive events doesn't look like an iv index problem because during my tests, the time elapsed between the creation of the network and the reload of the network was about 5-10 minutes.
    Would it be possible to have the name and the file of the functions through which the received message passes between the moment when the NRF chip receives it and the moment when it is transmitted to the model ? I will try to debug all the path to see at which level the received message does not fulfill the condition to pass to the higher level.
    Regards
    My favorite place for debugging is in the access.c file. Please look for the log where we print "TX:" and "RX:"
    It's on the access layer right before getting to the model.
    From that you can trace up to the transport layer. For example the function upper_transport_access_packet_in() in transport.c is where the packet receved in upper transport layer, before getting to access layer.
    Before the transport layer is the network layer, the packet is handled in network_packet_in() in network.c
    I have put some logs in  upper_transport_access_packet_in and network_packet_in on the nodes side.
    After the provisioning I have logs and all works nice but after a network reload, always health model events are received by the provisioner from the node, but I didn't get logs for commands sending by the provisioner on the node side, so I think it's either a problem in an even lower layer or it's the provisioner that doesn't send the message..
    I will try soon to logs the provisioner side to be sure that the model message is correctly send on the network after the provisioner reload the network.
    Regards
  • Hi Neicureuil,
    I would suggest to test trying to add a new "normal" node to the network by hardcoded provisioning, instead of adding the new provisioner.
    This way it's easier to test if the model that is not health model works or not.
    As I mentioned, you may want to compare what you hardcoded to what stored in the flash if they are the same. You can use two identical node, one is provisioned by a provisioner and one is hardcoded provisioning data that you added.
    I don't find anything inconsistent in sending the model messages.
    Is there another index that would be related to the number of messages sent by models (like IV but will be increase at each model message, or a thing like that) ?
    Regards
