nRF Connect Programmer hangs on start
Configuration:
  • nRF Connect for Desktop v3.7.0
  • Programmer v1.4.11
  • PCA10040 v2.0.0 EVK (date code 2020.39)
  • When Programmer app does start Log says: "Using nrfjprog library 10.12.1, pc-nrfjprog-js 1.7.6".
  • OS: Windows 10.
I can program debug with this EVK using SES.
When I start the Programmer app with the EVK plugged in, Programmer app hangs with blank screen.
I have tried upgrading/downloading EVK J-Link to v6.92 and 6.44e.  With 6.44e, sometimes Programmer will start, then hang when I attempt to select this J-Link.
CTRL+R while Programmer is stuck will re-start it (spinning wheel), then it goes blank again.
I can get no log output to debug the issue from Programmer, since it just hangs with blank screen.
Any suggestions?
  • Additional debugging:
    I tested a second computer with the same EVK and nRF Connect/Programmer versions and everything worked.
    Then I went back to the initial machine (System Report above) and removed all other USB hubs and devices.  In that configuration Programmer functions correctly.
    By process of elimination I found that a Brother ADS-1200 scanner causes the failure of Programmer to start and/or detect attached J-Link.  Or, powering off the scanner fixes Programmer (not enumerated in Device Manager).
    There is some USB conflict with the scanner.
    I can work around this issue, but it should be investigated and addressed by Nordic to ensure that the Programmer functions regardless of other USB devices connected to the computer.
    Thank you for this additional information. I'll update our internal team that is currently investigating this.
    best regards
    Jared
