sdk17.0.2
so i am trying to flush rx/tx while the command execute
cannot find
app_fifo_flush()
or
app_uart_flush()
anyone know how to do it?
unfortunately I am using it as a product on a unix system base
for this app Im trying to use this cli command to control N devices in ble
find out it might be a bug in it can you guys tell me how to fix it
actually we really need the cli command to control all of this
I mean even I change the size of
NRF_CLI_CMD_BUFF_SIZE
the bug still happened
Hi
I would strongly recommend considering another example if you are going to use this for a product.
For instance, you can either run a standard Bluetooth HCI example on the nRF device, and run a standard Bluetooth host such as BlueZ on the Unix side. Then you will interface to the Bluetooth devices in a way that is common for other Unix applications.
Alternatively, you can develop a custom application for the nRF device that controls the N devices, and provides an application specific interface between the nRF and the Unix host.
The advantage of this method is that you can implement a more efficient, application specific command set between the nRF and the Unix host, but the drawback is that you need to do more application development on the nRF side. If you use the HCI example on the nRF you don't really have to do much development at all.
If you think that using the ble_app_interactive example is the only option I can register an internal ticket to get help from the software team to improve the example, but I can not guarantee that this will be prioritized.
Best regards
Torbjørn
Hi
I will discuss the case with the CLI developer when he is back next week, and ask for some advice on how to proceed with this case.
You should mention this issue to your local Nordic sales representative also, and he can help give this case priority.
Best regards
Torbjørn
The reason for artifacts in the UART CLI is that it doesn't use flow control so if you paste multple bytes some will get lost as receiver is being stopped and restarted after each byte. There are 2 options:
- enable flow control
- use different transport, namely UART which is using libuarte driver. Libuarte is a driver which allows continues reception on UART, receiver is never stopped and DMA buffers are seamlessly changed. For setting up libuarte transport see this example https://infocenter.nordicsemi.com/topic/sdk_nrf5_v17.0.2/cli_libuarte_example.html?cp=8_1_4_6_8.
