Quadrature decoder settings for motor encoder
Hello community,
I tried to read my motor encoders with the QDEC and capture the position of my motor.
Hardware: nRF52840 DK, 2 Hal motor encoders on pin 0.13 and 0.14 which are supplied with an external voltage of 3.3V.
Unfortunately, in my test setups either more edges were detected than available, or not all were detected because supposedly 2 edges occurred at the same time.
In the settings I could only find one setting at the time at which the QDEC should measure. Can this be changed so that the QDEC only reacts when it detects an edge and also recognizes this only once?
I have already experimented with different speeds, but as long as I do not come exactly to the time I have set in the QDEC come again and again errors and the Morot position does not fit.
PS: I have realized it temporarily with an interrupt when changing the state of these two pins, but this is relatively complicated by the comparison with the position of the other encoder and the detection of the direction of rotation.
Maybe one of you has already experiences with the QDEC and can tell me where I can make further settings except in the sdk_config.h.
Thanks in advance
Translated with www.DeepL.com/Translator (free version)
  • #include "includes.h"
    APP_PWM_INSTANCE(motor_pwm, PWM_TIMER);
        while(1)
              if(flag == 0b00000000)
                  initialisierung_aller_komponenten();
                  initialisierung_pwm(&motor_pwm);
              if(nrf_gpio_pin_read(BUTTON_CUSTOM_1) == 0 && flag == 0b00000001)
                  while (MOTOR_STELLUNG <= 1000)
                      for (number_of_pulses=min_number_of_pulses; number_of_pulses<= max_number_of_pulses; number_of_pulses++ )
                            pulses = number_of_pulses;
                            nrf_drv_qdec_enable();
                            m_report_ready_flag = false;
                            if(nrf_qdec_sample_get() == 1)
                                  MOTOR_STELLUNG = MOTOR_STELLUNG + 1;
                            else if(nrf_qdec_sample_get() == (-1))
                                  MOTOR_STELLUNG = MOTOR_STELLUNG - 1;
                            NRF_QDEC->TASKS_READCLRACC;
                      min_number_of_pulses  = 1;
                      NRF_LOG_RAW_INFO("MOTOR_STELLUNG: %d \r\n", MOTOR_STELLUNG);
                      NRF_LOG_FLUSH();
    This is my main.c.
    In the function initialisierung_aller_komponenten() are only a few settings for my other pins and the button.
    void qdec_event_handler(nrf_drv_qdec_event_t event)
        if (event.type == NRF_QDEC_EVENT_REPORTRDY)
            m_accdblread        = event.data.report.accdbl;
            m_accread           = event.data.report.acc;
            m_report_ready_flag = true;
            nrf_drv_qdec_disable();
    This is my functions_qdec.c.
  • Hi
    I see you have based your code on the SDK example.
    To be honest I am not sure exactly what the SDK example is trying to show, so I made my own modified example instead:
    273524_qdec_simple.zip
    This example sets up a simulated QDEC signal on pins 3 and 4, and configures the QDEC peripheral to use inputs 29 and 30.
    Every time a new report is ready it simply prints the status of that report to the log, and lets the QDEC run continuously.
    Can you give this example a go and see if it works better?
    If you connect the simulated pins to the input it should report a frequency of ~200Hz, as set by the call to qdec_simulator_set(200); in main.c
    If you connect your own input it should hopefully show the speed of your motor.
    I moved all the QDEC parameters into the main function to make it more obvious how the QDEC is configured.
    Best regards
    Torbjørn
