Adding nrf_nvic_state_t nrf_nvic_state = {0}; causes code not to build. No reason for build failure
I am still trying to figure out what NVIC_SystemReset actually does and why a build and run always gives an error forcing me to press the reset button on the DK to function,
I found this text in the documentation:
In order to use this module, the following code has to be added to a .c file:
Definitions and declarations starting with __ (double underscore) in this header file are not intended for direct use by the application.
I had not done this, so I added it as a global in my 'main' file to see if NVIC_SystemReset() would behave in an expected manner and if that would fix the build and load issue I have on the nRF523840 DK. Well, after adding that line of code the build simply fails. No reason, no indication that this line of code caused it. The only reason I knew that it was the reason is because the code built before adding that one line of code.
So now I have another question. How is it that the documentation states that I MUST add this line to use NVIC calls through SoftDevice yet adding it causes the build to fail? Without that line the code mostly works, especially in debug mode. I did not catch this requirement earlier because it is not noted in the functions, but in a different place.
Is the documentation wrong? Perhaps misleading and that line is only needed for SOME of the NVIC SotfDevce calls? I am very confused. Something is not working right with respect to loading new code, and doing an NVIC_SystemReset when the module finishes (after a BTLE disconnect). The idea is that the NVIC_SystemReset should bring the module back to the program start as if the board just powered up.
Just did a global search for the implementation in some example in the SDK and there was none. The comment was found in several nrf_nvic.h files. This gets more confusing by the hour. Am I running down a rathole?
  • HealthAtHome.apk
    GhsDriver.apk
    First of all, thanks a million for actually checking it out. So you are not seeing the issue at all? Maybe I should re-flash the DK with SoftDevice? It is possible I have corrupted something by loading different projects onto the same board (all using the same SoftDevice and based only on SoftDevice). This project, however, is the only one that makes use of possible MTU size increases which means I have to allocate more memory for SoftDevice. I think I have done that correctly. Could it be something getting corrupted when the Bluetooth runs?
    I am really at a loss here, but I can give you an Android application that supports this GHS if that would help. I have attached two apks. Install the GhsDriver first. It supports the Bluetooth for GHS devices. Install the Health@Home next. It is the application. The drivers are like plugins which give installable support for proprietary health devices. They can be installed and uninstalled independent of the application. To run the app, give it the permissions (for Bluetooth scanning and popup discovery). Start the app. You will get a message saying you are not provisioned. Ignore. When it starts, select a patient (pick the default; the only preloaded option) and the Bluetooth is now active.
    To run the device on the DK button 3 starts advertising. Button 2 disconnects. After the disconnect, the DK device calls the sd_nvic_SystemReset(). You should be able to press button 3 to restart advertising but you might have to press the DK's reset button.
    When all is working you will see measurements received on the Android app. The DK is currently set to simulate a Spirometer. It only does one maneuver and nothing else. There is a 5 second wait before each reported sequence to simulate the user performing the maneuver. When the finally summary measurement is received, just press button three to disconnect.
    When you erase the flash doesn't that also erase SoftDevice? I assume you re-install SoftDevice and then install the app (via build-run in Segger Embedded Studio). I have done that once before using nFRConnect.  What code generation optimizations are you using? I think the last attempts I have been using had the optimizations set at none. The other optimization I have been using is optimized for size.
  • Hi
    It doesn't seem like it, no. The application seems to boot OK, whether or not I press the reset button or power cycle the board first.
    No, that shouldn't be a problem. As long as the flash areas used by your current example are valid, and verifies OK, it doesn't matter if there is some remaining code in unused areas of the flash.
    You can also run erase all before flashing your code just to ensure that the chip is empty before you flash the application, but I wouldn't expect this to be the problem in this case.
    Correct, the SoftDevice will also be erased. When flashing the application directly from SES the SoftDevice will automatically be programmed if it is not already present. Once the SoftDevice has been programmed SES will no longer flash it, but only flash the application.
    I didn't make any changes, I simply opened, built and flashed the example that you sent me.
    Ideally these changes shouldn't make a difference, unless you are using the debugger.
    I will set aside some time tomorrow in order to test the Android application you shared.
    Best regards
    Torbjørn
  • Okay ... I am going for the erase and flash. I ALWAYS get that start up error every power up and build-run install. The only time I don't is if I use the build-debug install. But I am also using Bluetooth and on the disconnect is when I write to flash (bonding info and stored data if there is any - but in all cases stored data always gets uploaded and deleted so I never have any to store).
    But this is driving me nuts!
    I went to 'Target' connected J-Link, did an erase and then download and I got no error.
    If I do not do the erase and connect and download or do build-run I get the error. I have to do the erase first to avoid it.
  • Hi
    Could there be an issue if there is some existing bonding data stored in the flash when you boot?
    When working on applications that bond I always do an erase all out of habit, otherwise you can get issues because you have a fresh application install that has old data from a previous build in the non volatile memory area.
    As a side note I don't appear to be able to connect using your APK.
    When I first start the program I get a notification that there is "No provisioning". I get past that, allow the app to turn bluetooth off and on again, but I don't see any patient in the list even though I can confirm that the board is advertising (I can see it in nRF Connect).
    Not sure if I have to do anything else to get it to work?
    Best regards
    Torbjørn
  • I really appreciate you going through all of this What makes it so hard is that all works nice when I use the debugger (build and debug). And in that case flash loads nicely (if there is anything to load).
    As far as the app is concerned when you get to the main page after all that pain-in-the-@$$ permission stuff you should see an orange line of text across the top which says
    Please select a patient. Readings cannot be made until a patient is selected.
    There should be at least one patient with the boring name 'Default Patient'. What you are supposed to do is press the taskbar where it says 'Search for Patient' and when you do the single name
    'Default Patient' should appear in the top line of the main screen, and a keyboard at the bottom. All you have to do is touch 'Default Patient', then it will appear in the toolbar and the little lites to the left will start to flash. They are scanning for classic and BTLE devices in cycles.
    You should not have to do anymore. If a device the app understands is discovered it will popup on the screen. Just pick it. Them you should see the green circle in the upper middle of the screen start to flash (connected). It will keep flashing until disconnected.
    For it to work you have to also install the GhsDriver (its a 'plugin' that supports devices following the GHS 'standard'). Standard devices that follow the BT SIG health profiles are supported by default. But this project is a test GHS, so you will need that plugin.
    I think I made a video at one time on how to use the app. I should have one, but I do not have any decent video making software!
