Problem to read back flash with NVS when concurrent use with Bluetooth
We need to save 3 strings to flash using NVS. Based on the code sample in zephyr\samples\subsys\nvs we set the initialization and then write and read these data.
To have successful read back we need to make some dummy write to NVS before, else the reading doesn't correspond to the previous written value.
We have done the following observation:
  • doing read/write of the NVS before enabling Bluetooth works fine
  • doing read/write after enabling Bluetooth retrieves the very first data instead of the last written (and some more strange behaviour)
  • the Bluetooth stack is doing a second nvs_init() with larger sector number to fs structure
Our question are the following
  • is there more documentation on NVS than the basic developer source ?
  • is there any precautions to use "custom" access to NVS at the same time as Bluetooth stack ?
  • should we split the storage area for each uses or ID's should be fully managed by Bluetooth stack without any problems ?
We initiate fs with DTS flash controller definition (ex: nRF52833 -> storage begin at 0x7a000)
Config is NCS 1.5.0 or 1.6.0, nRF52840DK
Romain
  • Hi Vidar,
    It used to work fine but now I face problem to compile the same code with MCUBoot enabled...
    This MACRO generates an error
    fs.offset = FLASH_AREA_OFFSET(user_storage);
    If I use one partition named storage this work but as soon as I split it in storage + user-storage it fails.
    The overlay of my custom board nRF52840 is as below
    /* User storage */
    &flash0 {
        partitions {
            storage_partition: partition@f8000 {
                label = "storage";
                reg = < 0xf8000 0x6000 >;
            user_partition: partition@fe000 {
                label = "user-storage";
                reg = < 0xfe000 0x2000 >;
    proj.conf extract
    NVS concern:
    # Enable bonding
    CONFIG_SETTINGS=y
    CONFIG_BT_BONDABLE=y
    CONFIG_BT_SETTINGS=y
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_SETTINGS_NVS=y
    CONFIG_SETTINGS_NVS_SECTOR_COUNT=4
    New lines MCUBoot concern:
    # Bootloader
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG=y
    CONFIG_MCUMGR_LOG_LEVEL_DBG=y
    # DFU and OTA update
    CONFIG_DFU_TARGET=y
    CONFIG_DFU_TARGET_MCUBOOT=y
    CONFIG_FLASH=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    CONFIG_RING_BUFFER=y
    # Firmware signing
    CONFIG_SIGN_IMAGES=y
    Any idea on what could be wrong ?
    Best regards.
    I should have pointed this out earlier, but the partition manager will take over and manage the memory layout once you start doing Multi-image builds. This means that the DTS configuration will be ignored.
    Please try to add the yaml code below into a file named "pm_static.yml" and place it in your project directory. This should configure the partition manager to include your partition.
    user_storage:
      address: 0xfc000
      end_address:0xfe000
      placement:
        before:
        - settings_storage
      region: flash_primary
    settings_storage:
      address: 0xfe000
      end_address: 0x100000
      placement:
        before:
        - end
    Vidar
  • Vidar,
    The error still remains.
    This is not clear for me, the dts and overlay files will be ignored about &flash0 part only ?
    The content seems not identical to my overlay file...  Is the code below the "perfect" equivalence of my overlay ? (it doesn't work neither)
    storage:
      address: 0xf8000
      end_address: 0xfe000
      placement:
        before:
        - user_storage
    user_storage:
      address: 0xfe000
      placement:
        before:
        - end
    Edit: I can build now
    According to my pm_static.yml there is 3 "storage" partitions
    - settings_storage size 0x2000 (generated only with MCU Boot)
    - storage size 0x6000 (default 0x8000)
    - user_storage size 0x2000 (new custom partition from storage)
    Knowing this, CONFIG_SETTINGS_NVS_SECTOR_COUNT=4 should still influence on storage ?
    settings_storage:
      address: 0xf6000
      end_address: 0xf8000
      placement:
        before:
        - end
    sram_primary:
      address: 0x20000000
      end_address: 0x20040000
      region: sram_primary
    storage:
      address: 0xf8000
      placement:
        before:
        - user_storage
    user_storage:
      address: 0xfe000
      placement:
        before:
        - end
  • The settings module will use the 'settings_storage' instead of the 'storage' partition now when the Partition Manager is enabled, so you can remove the storage partition and keep settings_storage + user_storage.
    CONFIG_SETTINGS_NVS_SECTOR_COUNT will work in the same way as before.
