Trying to simply combine sample program. (ble_app_beacon and spis)
Hello.
Now, I'm trying to combine  ble_app_beacon and spis.
I succeeded in building and it generates hex file.
The problem is that the device stops sending BLE data
even if I put one line of spis code.
Deos anyone face the same problem as I have done?
Here is my main.c
#include <stdbool.h>
#include <stdint.h>
#include "nordic_common.h"
#include "bsp.h"
#include "nrf_soc.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "ble_advdata.h"
#include "app_timer.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_spi.h"
#include "nrfx_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_spi_mngr.h"
#include "sdk_config.h"
#include "nrf_drv_spis.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#if defined (LEGACY_DEFINE)
#undef NRFX_DEFINE
#define NRFX_DEFINE LEGACY_DEFINE
#define APP_BLE_CONN_CFG_TAG            1                                  /**< A tag identifying the SoftDevice BLE configuration. */
//#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(100, UNIT_0_625_MS)  /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
#define APP_BEACON_INFO_LENGTH          0x17                               /**< Total length of information advertised by the Beacon. */
#define APP_ADV_DATA_LENGTH             0x15                               /**< Length of manufacturer specific data in the advertisement. */
#define APP_DEVICE_TYPE                 0x02                               /**< 0x02 refers to Beacon. */
#define APP_MEASURED_RSSI               0xC3                               /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
//#define APP_COMPANY_IDENTIFIER          0x0059                             /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define APP_COMPANY_IDENTIFIER          0x004C                             /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define APP_MAJOR_VALUE                 0x01, 0x02                         /**< Major value used to identify Beacons. */
#define APP_MINOR_VALUE                 0x03, 0x04                         /**< Minor value used to identify Beacons. */
#define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                        0x45, 0x56, 0x67, 0x78, \
                                        0x89, 0x9a, 0xab, 0xbc, \
                                        0xcd, 0xde, 0xef, 0xf0            /**< Proprietary UUID for Beacon. */
#define DEAD_BEEF                       0xDEADBEEF                         /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO   18                                 /**< Position of the MSB of the Major Value in m_beacon_info array. */
#define UICR_ADDRESS                    0x10001080                         /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
static ble_gap_adv_params_t m_adv_params;                                  /**< Parameters to be passed to the stack when starting advertising. */
static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t              m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];  /**< Buffer for storing an encoded advertising set. */
// SPIS DEFINITIONS
#define SPIS_INSTANCE 1 /**< SPIS instance index. */
static const nrf_drv_spis_t spis = NRF_DRV_SPIS_INSTANCE(SPIS_INSTANCE);/**< SPIS instance. */
#define TEST_STRING "Nordic"
static uint8_t       m_tx_buf[] = TEST_STRING;           /**< TX buffer. */
static uint8_t       m_rx_buf[sizeof(TEST_STRING) + 1];    /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
static volatile bool spis_xfer_done; /**< Flag used to indicate that SPIS instance completed the transfer. */
#define APP_SPIS_SCK_PIN 26
#define APP_SPIS_MOSI_PIN 29
#define APP_SPIS_MISO_PIN 30
#define APP_SPIS_CS_PIN 31
 * @brief SPIS user event handler.
 * @param event
void spis_event_handler(nrf_drv_spis_event_t event)
    if (event.evt_type == NRF_DRV_SPIS_XFER_DONE)
        spis_xfer_done = true;
        NRF_LOG_INFO(" Transfer completed. Received: %s",(uint32_t)m_rx_buf);
// BLE FUNCTIONS
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
    .adv_data =
        .p_data = m_enc_advdata,
        .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
        .p_data = NULL,
        .len    = 0
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                    /**< Information advertised by the Beacon. */
    APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                         // implementation.
    APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                         // manufacturer specific data in this implementation.
    APP_BEACON_UUID,     // 128 bit UUID value.
    APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
    APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
    APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                         // this implementation.
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
    uint32_t      err_code;
    ble_advdata_t advdata;
    uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    ble_advdata_manuf_data_t manuf_specific_data;
    manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
    // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
    // UICR instead of using the default values. The major and minor values obtained from the UICR
    // are encoded into advertising data in big endian order (MSB First).
    // To set the UICR used by this example to a desired value, write to the address 0x10001080
    // using the nrfjprog tool. The command to be used is as follows.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
    // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
    // the following command should be used.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
    uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
    uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
    uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
    m_beacon_info[index++] = MSB_16(major_value);
    m_beacon_info[index++] = LSB_16(major_value);
    m_beacon_info[index++] = MSB_16(minor_value);
    m_beacon_info[index++] = LSB_16(minor_value);
    manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
    manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type             = BLE_ADVDATA_NO_NAME;
    advdata.flags                 = flags;
    advdata.p_manuf_specific_data = &manuf_specific_data;
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
    m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
    m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.duration        = 0;       // Never time out.
    //m_adv_params.scan_req_notification = 1;   //VLS
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
    ret_code_t err_code;
    err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    case BLE_GAP_EVT_SCAN_REQ_REPORT:
      NRF_LOG_INFO("RSSI %d",p_ble_evt->evt.gap_evt.params.scan_req_report.rssi);
      // No implementation needed.
    uint32_t ram_start = 0;
    // Enable BLE stack.
    //NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_evt_handler, NULL);
/**@brief Function for initializing logging. */
static void log_init(void)
/**@brief Function for initializing LEDs. */
static void leds_init(void)
    ret_code_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
/**@brief Function for initializing timers. */
static void timers_init(void)
        nrf_pwr_mgmt_run();
 * @brief Function for application main entry.
    // Initialize.
    log_init();
    timers_init();
    leds_init();
    power_management_init();
    ble_stack_init();
    advertising_init();
    NRF_POWER->TASKS_CONSTLAT = 1;
    // Start execution.
    NRF_LOG_INFO("Beacon started.");
    advertising_start();
    as_spi_write_reg(0x00,0x00);
    nrf_drv_spis_config_t spis_config = NRF_DRV_SPIS_DEFAULT_CONFIG;
    spis_config.csn_pin               = APP_SPIS_CS_PIN;
    spis_config.miso_pin              = APP_SPIS_MISO_PIN;
    spis_config.mosi_pin              = APP_SPIS_MOSI_PIN;
    spis_config.sck_pin               = APP_SPIS_SCK_PIN;
    APP_ERROR_CHECK(nrf_drv_spis_init(&spis, &spis_config, spis_event_handler));
    // Enter main loop.
    for (;; )
        idle_state_handle();
        as_spis_write_reg();
        memset(m_rx_buf, 0, m_length);
        spis_xfer_done = false;
        APP_ERROR_CHECK(nrf_drv_spis_buffers_set(&spis, m_tx_buf, m_length, m_rx_buf, m_length));
        while (!spis_xfer_done)
            __WFE();
        NRF_LOG_FLUSH();
        bsp_board_led_invert(BSP_BOARD_LED_0);
My environment is SDK 17.0.2 and SES 5.05d.
Kindly Regards,
Shigeto
  • Ok,
    Then the next step is to figure out what happens when SPIS works but the beacon doesn't work properly. What IRQ priority are you using for the SPIS module?
    regards
    Jared
    Thanks for a reply and sorry for a late reply due to the weekend.
    #ifndef NRFX_SPIS_DEFAULT_CONFIG_IRQ_PRIORITY
    #define NRFX_SPIS_DEFAULT_CONFIG_IRQ_PRIORITY 6
    I set IRQ of SPIS 6. default setting.
    IRQ of GPIO is also 6.
    Kindly Regards,
    Shigeto
    I found out that it jumps to 'app_error_fault_handler' in spite of being simplified main function.
    #include <stdint.h>
    #include "bsp.h"
    #include "boards.h"
    #include <string.h>
    #undef NRFX_DEFINE
    //#define APP_BLE_OBSERVER_PRIO           1                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_SIGNAL_OUT                  0xc3                              /**< Proprietary SIGNAL OUT for Beacon. */
    #define UPDATE_MS                       5000
    #define BEACON_INTERVAL                 APP_TIMER_TICKS(UPDATE_MS)
    APP_TIMER_DEF(m_beacon_timer_id);                                               // Timer ID
    static volatile bool m_beacon_timer_flag = false;                               // Timer Flag
    // SPIS DEFINITIONS
    #define SPIS_INSTANCE 0 /**< SPIS instance index. */
    static const nrf_drv_spis_t spis_2 = NRF_DRV_SPIS_INSTANCE(SPIS_INSTANCE);/**< SPIS instance. */
    #define TEST_STRING "w"
    #define TEST_STRING_2 "D"
    static uint8_t       m_tx_buf2[] = TEST_STRING_2;           /**< TX buffer. */
    static uint8_t       m_rx_buf2[sizeof(TEST_STRING_2) + 1];    /**< RX buffer. */
    static const uint8_t m_length2 = sizeof(m_tx_buf2);        /**< Transfer length. */
     * @param event
    void spis_event_handler2(nrf_drv_spis_event_t event)
            NRF_LOG_INFO(" Transfer completed. Received: %s",(uint32_t)m_rx_buf2);
    // BLE FUNCTIONS
        .adv_data =
        .scan_rsp_data =
            .p_data = NULL,
            .len    = 0
                             // implementation.
        uint32_t      err_code;
     * @brief   Function for starting application timers.
     * @param   None.
     * @retval  None.
    static void application_timers_start(void)
    	// Start application timers.
    	err_code = app_timer_start(m_beacon_timer_id, BEACON_INTERVAL, NULL);
     * @brief   Function for stopping advertising.
     * @param   None.
     * @retval  None.
    static void advertising_stop(void)
    	err_code = sd_ble_gap_adv_stop(m_adv_handle);
    /*static void power_management_init(void)
            nrf_pwr_mgmt_run();
        // Initialize.
        //NRF_POWER->TASKS_CONSTLAT = 1;
        log_init();
        timers_init();
        leds_init();
        //power_management_init();
        ble_stack_init();
        advertising_init();
        NRF_LOG_INIT(NULL);
        // Start execution.
        //application_timers_start();
        /*nrf_drv_spis_config_t spis_config = NRF_DRV_SPIS_DEFAULT_CONFIG;
        nrf_gpio_cfg_output(APP_SPIS_CS_PIN);
        nrf_gpio_pin_set(APP_SPIS_CS_PIN);
        /*while (!spis_xfer_done)
            __WFE();
        //nrfx_spis_uninit(&spis);
        //APP_ERROR_CHECK(nrf_drv_spis_init(&spis_2, &spis_config, spis_event_handler2));
        // Enter main loop.
        for (;; )
            //NRF_LOG_FLUSH();
            // beacon update
            //advertising_stop();
            //memset(m_rx_buf2, 0, m_length2);
            //err_code = nrf_drv_spis_init(&spis_2, &spis_config, spis_event_handler2);
            //APP_ERROR_CHECK(err_code);
            //spis_xfer_done = false;
            //APP_ERROR_CHECK(nrf_drv_spis_buffers_set(&spis_2, m_tx_buf2, m_length2, m_rx_buf2, m_length2));
            //err_code = nrf_drv_spis_buffers_set(&spis_2, m_tx_buf2, m_length2, m_rx_buf2, m_length2);
                __WFE();
            //nrfx_spis_uninit(&spis_2);
            //advertising_init();
            //advertising_start();
    call stack says below...
    Wondering what is happing...
    'cos a beacon works fine after installing a softdevice and the built hex to device...
    Kindly Regards,
    Shigeto
  • If it goes into the error handler then it's because a function returns an error code somewhere. You now have to figure out by using breakpoints and the debugger exactly what function that returns the error code. Note, that when you use the debugger and halt a softdevice application, you'll have to restart the program before resuming it. You can't halt the application and then resume it without restarting as it will result in the application asserting. It's explained more in detail here and here.
    Thanks for a quick reply!!!
    OK. I will carefully read links that you attached.
    Kindly Regards,
    Shigeto
