I have tested FOTA code in nRF52840 DK and it works perfect but i have custom board build with nrf52840 when i implement the code it doesn't get start
custom board not have 32.768khz crystal
I have confg
# Clock configuration
CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
in prj.conf
and also in child_mage\mcuboot.conf
config_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
but when i check configure nrf connect
for menuconfig
but when i see mcuboot config
how to change it in .config file
and when i change this in configure menu
i got this error
Hi Håkon,
i have
disable the two stage low frequency clock
changed to synthesized from HFCLK
it works
but i need to config in .conf
how to do it
the mcuboot.conf changes doesn't work can you help for it
It seems that mcuboot tries to use temp sensor for calibration intervals. We will need to disable this specifically for mcuboot. Could you try this in mcuboot.conf?
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_MAX_SKIP=0 CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_TEMP_DIFF=0
Håkon
I have used HFCLK in main menu so i need to use same in mcuboot.conf
