RTT not appearing in modified ble_app_uart example
I have been developing software on the ble_app_uart example in Segger Embedded Studio with sdk 17.0.2.  The example has RTT enabled but I noticed when I try to use RTT in my modified version that no RTT shows up in the debugging window.  I added various libraries and changed the config file, but did not remove anything or turn off anything in the config file from the example.  I wasn't sure how to troubleshoot this and was wondering what potential problems might be interfering with RTT outputs in the debugging terminal.  Here is my main() code, I can add more if necessary.
    bool erase_bonds;
    ret_code_t rc;
    // Initialize.
    twi_init();
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    /* Register first to receive an event when initialization is complete. */
    (void) fds_register(fds_evt_handler);
    rc = fds_init();
    APP_ERROR_CHECK(rc);
    /* Wait for fds to initialize. */
    wait_for_fds_ready();
    // Start execution.
    //turn on LED3 while on and not in sleep mode
    nrf_gpio_cfg_output(LED2);
    nrf_gpio_pin_clear(LED2);
    //button press waits for a button press event or times out and goes to sleep mode if no button press is received in 15 seconds
    buttonPress();
    nrf_delay_ms(100);
    advertising_start();
    //advertise for 15 seconds then try to send the data
    nrf_delay_ms(5000);
    //SendTime sends the entire memory, should add a condition to make sure that it's connected to BLE, potentially only send new entries etc.
    SendTime();
    //wait 5 seconds after sending the data before entering sleep mode, just here to give time to read in devtools for debugging
    nrf_delay_ms(5000);
    sleep_mode_enter_wakeup_enabled();
    // Enter main loop.
    for (;;)
        idle_state_handle();
  • Hi
    Sorry, I was referring to defines like NRF_LOG_CLI_CMDS and  NRF_CLI_ENABLED, which are set to 0 (and need to be enabled to use the CLI) in the ble_app_uart sdk_config.h file. I'm not sure if this is what's causing the lack of RTT logging, but it's worth a shot.
    As I'm running out of leads as to what is causing this, I think I might need to try reproducing this on my end, as looking at it first hand usually makes it easier to spot what's causing it. Can you upload a .zip file with your project that can be placed in the SDK and run, so I don't have to use time reproducing the exact project you have?
    Simon
  • I was referring to defines like NRF_LOG_CLI_CMDS and  NRF_CLI_ENABLED, which are set to 0 (and need to be enabled to use the CLI) in the ble_app_uart sdk_config.h file. I'm not sure if this is what's causing the lack of RTT logging, but it's worth a shot.
    I tried that out but still no luck.
    Sure, although when I give the paths for library locations to the preprocessor, those paths will be based on the location of my SDK on my hard drive.  How do I get around this?  I think what I did should work as I made sure all the referenced locations were just to the SDK and the SDK is just sitting at the top of a directory on my drive.  Let me know if you have issues with it.  It worked for me but it had to be within a folder within examples.  On my machine the path is: D:\nRF5SDK1702d674dde\nRF5_SDK_17.0.2_d674dde\examples\peripheral\RebuildDemoV1.0.  I added a chart of the logic too which should hopefully make it easier to follow what's going on.
    One thing I noticed rebuilding was that when I was adding the necessary sections for fstorage/fds/twi/crc16 to the config file that there were duplicates of some statements.  All the files I added to the config file are commented at the top of the page but I was wondering if there might be some issues from things being defined twice/turned on at the top/back off later.
    RebuildDemoV1.0.zipSoftware Logic Chart.pdf
  • Hi Jake
    It took a minute to get the device up and running due to the paths you mentioned, but it was easy enough to remedy on my end when I knew. However, I had some trouble building due to this function in your main.c:
      switch(writeBool)
         case 0 :
            snprintf(intermediate, sizeof(intermediate), "S: %x:%x:%d %x/%x/%x", rx_data[2], rx_data[1], rx_data[0], rx_data[5], rx_data[4], rx_data[6]);
         case 1 :
            snprintf(intermediate, sizeof(intermediate), "E: %x:%x:%d %x/%x/%x", rx_data[2], rx_data[1], rx_data[0], rx_data[5], rx_data[4], rx_data[6]);
         default :
    First off, I get a warning because the switch condition has a boolean value, and tit seems like the snprintf functions are interfering with the way SEGGER_RTT_Syscalls_SES.c does RTT. If I commented this function out and set the RETARGET_ENABLED define in sdk_config.h to 0 on my end, RTT seems to work fine in the RTT Viewer, as it prints the wake up process every few seconds:
    I think you need to rework this function as it seems to be the culprit to why the RTT viewer doesn't work. Please note that I didn't get the example running while using this function, so what changes did you make to other files, like the SEGGER_RTT_Syscalls_SES.c to get it to run on your end?
    Simon
  • I changed RETARGET_ENABLED to 0 and this fixed it, RTT is now working, thanks so much for working with me for so long!
    What does RETARGET_ENABLED actually do?  I checked the documentation page but there wasn't a description for it.
    I wasn't getting any issues on my end with the bool switch statement or snprintf, and I didn't make any changes to SEGGER_RTT_Syscalls_SES.c to get it to run on my end so I'm not sure why it caused issues for you.  I can look into it more if you'd like but my main problem is solved.
    This is outside the scope of the question, but how do you avoid this issue with the paths so that it can build purely from within the SDK?
  • Hi Jake
    The RETARGET_ENABLED will let youinclude the retarget layer for stdio functions. This is necessary to use printf to transmit data over UART, which is what your application tried doing when you had this define set to 1 and would be why the logging didn't go to RTT.
    By default, all functions should already only be called from inside the SDK, with the path being set to ../../../SDK, setting the path prior to the SDK version to be relative.
    Simon
