Simple example ADC for nRF5340 PDK
I want a simple example of ADC that can be used by nrf5340 pdk, so I found an example on the forum, but when I compile, it shows an error.
Can someone give me an example simple of ADC that works on nrf5340 pdk?
Thank you in advance!
 * Copyright (c) 2020 Libre Solar Technologies GmbH
#include <zephyr.h>
#include <sys/printk.h>
#include <drivers/adc.h>
#if !DT_NODE_EXISTS(DT_PATH(zephyr_user)) || \
	!DT_NODE_HAS_PROP(DT_PATH(zephyr_user), io_channels)
#error "No suitable devicetree overlay specified"
#define ADC_NUM_CHANNELS	DT_PROP_LEN(DT_PATH(zephyr_user), io_channels)
#if ADC_NUM_CHANNELS > 2
#error "Currently only 1 or 2 channels supported in this sample"
#if ADC_NUM_CHANNELS == 2 && !DT_SAME_NODE( \
	DT_PHANDLE_BY_IDX(DT_PATH(zephyr_user), io_channels, 0), \
	DT_PHANDLE_BY_IDX(DT_PATH(zephyr_user), io_channels, 1))
#error "Channels have to use the same ADC."
#define ADC_NODE		DT_PHANDLE(DT_PATH(zephyr_user), io_channels)
/* Common settings supported by most ADCs */
#define ADC_RESOLUTION		12
#define ADC_GAIN		ADC_GAIN_1
#define ADC_REFERENCE		ADC_REF_INTERNAL
#define ADC_ACQUISITION_TIME	ADC_ACQ_TIME_DEFAULT
/* Get the numbers of up to two channels */
static uint8_t channel_ids[ADC_NUM_CHANNELS] = {
	DT_IO_CHANNELS_INPUT_BY_IDX(DT_PATH(zephyr_user), 0),
	DT_IO_CHANNELS_INPUT_BY_IDX(DT_PATH(zephyr_user), 1)
static int16_t sample_buffer[ADC_NUM_CHANNELS];
struct adc_channel_cfg channel_cfg = {
	.gain = ADC_GAIN,
	.reference = ADC_REFERENCE,
	.acquisition_time = ADC_ACQUISITION_TIME,
	/* channel ID will be overwritten below */
	.channel_id = 0,
	.differential = 0
struct adc_sequence sequence = {
	/* individual channels will be added below */
	.channels    = 0,
	.buffer      = sample_buffer,
	/* buffer size in bytes, not number of samples */
	.buffer_size = sizeof(sample_buffer),
	.resolution  = ADC_RESOLUTION,
void main(void)
	int err;
	const struct device *dev_adc = DEVICE_DT_GET(ADC_NODE);
	if (!device_is_ready(dev_adc)) {
		printk("ADC device not found\n");
		return;
	 * Configure channels individually prior to sampling
	for (uint8_t i = 0; i < ADC_NUM_CHANNELS; i++) {
		channel_cfg.channel_id = channel_ids[i];
#ifdef CONFIG_ADC_NRFX_SAADC
		channel_cfg.input_positive = SAADC_CH_PSELP_PSELP_AnalogInput0
					     + channel_ids[i];
		adc_channel_setup(dev_adc, &channel_cfg);
		sequence.channels |= BIT(channel_ids[i]);
	int32_t adc_vref = adc_ref_internal(dev_adc);
	while (1) {
		 * Read sequence of channels (fails if not supported by MCU)
		err = adc_read(dev_adc, &sequence);
		if (err != 0) {
			printk("ADC reading failed with error %d.\n", err);
			return;
		printk("ADC reading:");
			int32_t raw_value = sample_buffer[i];
			printk(" %d", raw_value);
			if (adc_vref > 0) {
				 * Convert raw reading to millivolts if driver
				 * supports reading of ADC reference voltage
				int32_t mv_value = raw_value;
				adc_raw_to_millivolts(adc_vref, ADC_GAIN,
					ADC_RESOLUTION, &mv_value);
				printk(" = %d mV  ", mv_value);
		printk("\n");
		k_sleep(K_MSEC(1000));
