could you please share how charging LED / Error LED will behave in various conditions. I could not find this information anywhere.
BR
Pallav
BR
Pallav
Battery is a new Phone battery and it gives good backup.
When LED is ON the voltage is 4.221V and when LED is off the voltage is 4.167V
Vterm is set for 4.2V
Can you provide a scope plot of VBUS, VSYS and VBAT please?
I have connected again for the measurements but this time, that blinking is not coming. Looks like the jumper wires could be the issue, not sure though.
I will do some more tests and confirm in a day or so.
Did this get resolved?
I can see from video the blinking was slow so I expect it was not same issue as I am now seeing.
I am getting an approx 10 Hz (9.65Hz) short spike of 400us length on CHG when battery has been full for a long time. I am using approx 157mA chargerate (2.4k ICHG resistor) and battery is a 320mAh cell. I can not see any spikes on VBUS, VBAT or VSYS.
It appears to only happen when battery is fully charged and have been so for a while.
I discovered this behavior can come about from low voltage on the bus (long thin cables) or overloaded usb port. Just in case others search and find this...
