Hi there,
I am using the nrfjprog to flash the nrf51822 via a J-Tag programmer. Here is the command I used in the command prompt:
nrfjprog --eraseall --programs softdevice.hex --program application.hex bootloader.hex --verify --reset
During the programming process, it prompts me this warning message:
"WARNING: Since the option "--dfu" was not given, the SoftDevice will include UICR settings. Please be aware that Device Firmware Update of the SoftDevice will not be possible with these settings."
Then, I included the "--dfu" in the command
nrfjprog --eraseall --programs softdevice.hex --dfu --program application.hex bootloader.hex --verify --reset
The SoftDevice (in Region 0 when the "--dfu" was not given) became in Region 1. I tested these two configuration on my device. They both worked. Is there any difference when SoftDevice is sitting at Region 1?
I tried to look for some information on the "--dfu" option. But I found no clear information.
--programs "hex_file" [--dfu] Programs the specified hex into the device. In addition, checks that the hex file is a well constructed SoftDevice: It contains a the FWID either in the UICR or the SoftDevice itself, it contains a valid value for the length of the SoftDevice, does not contain any data above the afore mentioned length, and only writes into SoftDevice reserved space in UICR. Can be combined with the erase operations, the reset operations and the other programming operations. If dfu option is given and the SoftDevice allows it, the device will not be run time protected. otherwise, the UICR.CLENR0 will be written. It will automatically disable the MPU NVM protection regions if enabled and enable it again after the program operation.
Thanks so much in advance for your help.
Cheers, Rocky
