Zigbee end-device (NRF52840) leaving the coordinator (also NRF52840)
I've been working with the NRF52840 for a while now. My setup is based on the CLI coordinator code and a bunch of end devices running the multisensor freertos based program.
Recently something weird started to happen. After being paired with the coordinator for like days, some end devices disconnect from the network and never re-join again. Also, the connection status LED turns off and never turns on again unless I manually reboot the power of the end device. What could be the issue here?
What can I do to prevent this? Should I make kind of a watchdog to the connection status?
Fernando
  • Hi
    In the multisensor freertos application, the end device timeout is set by the zb_set_ed_timeout() function in the main() loop by default, if you want the device to stay connected for longer, this can be increased to up to 16384 minutes, and it also has a keep-alive timeout in zb_set_keepalive_timeout() you can use to keep the connection alive.
    Simon
