SPI Communication is not working in NRF52840
I am using nrf52840 customized dongle  in our project. We have interfaced ADS1118 using spi communication with nrf52840 (customized dongle). The problem here with the spi communication is i am not able to read the data from the ADS1118  using spi communication i am reading the adc value as 0.
When we checked with the oscilloscope  we are not getting clk signal ,MISO ,MOSI signal only Chip select is high.
I am here by attaching the code Please give me the solution what could be the problem.
* Copyright (c) 2015 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include "nrf_drv_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "SEGGER_RTT.h"
#define SPI_INSTANCE 0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE); /**< SPI instance. */
static volatile bool spi_xfer_done; /**< Flag used to indicate that SPI instance completed the transfer. */
#define TEST_STRING "Nordic"
static uint8_t m_tx_buf[] = {0x0CB,0x9B}; //TEST_STRING; /**< TX buffer. */
static uint8_t m_rx_buf [2];//[sizeof(TEST_STRING) + 1]; /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf); /**< Transfer length. */
static uint8_t m_tx_buf1[] = {0x00,0x00}; //TEST_STRING; /**< TX buffer. */
static uint8_t m_rx_buf1[2]; //TEST_STRING; /**< TX buffer. */
* @brief SPI user event handler.
* @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
void * p_context)
spi_xfer_done = true;
NRF_LOG_INFO("Transfer completed.");
SEGGER_RTT_printf(0," Transfer completed\n");
for(int i=0;i<5;i++)
NRF_LOG_INFO("Data=%x\n.",m_rx_buf[i]);
if (m_rx_buf[0] != 0)
NRF_LOG_INFO(" Received:");
SEGGER_RTT_printf(0," Recieved\n");
NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
uint8_t data=0xff;
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.ss_pin = SPI_SS_PIN;
spi_config.miso_pin = SPI_MISO_PIN;
spi_config.mosi_pin = SPI_MOSI_PIN;
spi_config.sck_pin = SPI_SCK_PIN;
APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
NRF_LOG_INFO("SPI example started.");
while (1)
// Reset rx buffer and transfer done flag
memset(m_rx_buf, 0, m_length);
spi_xfer_done = false;
nrf_gpio_cfg_output(31);
nrf_delay_us(100);
nrf_gpio_pin_clear(31);
nrf_delay_ms(100);
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf1, m_length, m_rx_buf1, m_length));
SEGGER_RTT_printf(0," Data Received1: %x\n",m_rx_buf1[0]);
SEGGER_RTT_printf(0," Data Received2: %x\n",m_rx_buf1[1]);
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));
SEGGER_RTT_printf(0," Received1: %x\n",m_rx_buf[0]);
SEGGER_RTT_printf(0," Received2: %x\n",m_rx_buf[1]);
nrf_delay_ms(200);
nrf_delay_ms(200);
nrf_gpio_pin_set(31);
while (!spi_xfer_done)
__WFE();
NRF_LOG_FLUSH();
bsp_board_led_invert(BSP_BOARD_LED_0);
nrf_delay_ms(500);
  • Hi
    here are some points:
    1. No need to have pullup resistors on SPI i/o lines
    2. The default SPI config - NRF_DRV_SPI_DEFAULT_CONFIG has mode set to NRF_DRV_SPI_MODE_0, you are not setting this to NRF_DRV_SPI_MODE_1. You should run the SPI with frequency like 1Mhz, the default NRF_DRV_SPI_FREQ_4M (4Mhz)
    3. When you assign a CS pin to SPI, this pin is controlled by the SPI instance, no need to add any code for that.
    4. The reference manual of ADS1118 suggests series resistor of 50ohm on each SPI l/o lines to provide short circuit protection.
    5. Also the DRDY / Dout pin on nRF should be configured as falling edge triggered interrupt input.
    6. Since either config register or conversion register are 16bit type, you need to send 2 bytes , also the MSB goes first when writing / receiving the data.
    There are two ways to config the device and read conversion values: 32bit mode or 16bit mode. 32bit is reading config register and followed by conversion register. If reading config register is not required, then use 16bit mode, which sends the config register set value (tx) and at the same time receive conversion value.
    For 32bit, you can send 4 bytes, tx_buf first two bytes represent config register values, and rx_buf will receive conversion data (2 bytes) followed by configReg value (2bytes).
    First using 32bit mode: if configRegister = 0x058B (this is POR value), then since your buffers are 8bit
    m_tx_buf[0] = configRegister >> 8;
    m_tx_buf[1] = configRegister;
    and then if you run the following SPI transfer commands, you should receive the same value in rx_buffer. If you read the same value, then your SPI is working fine.
    nrf_drv_spi_transfer(&spi, m_tx_buf, 2, m_rx_buf, 4)
    the above will transmits 2 bytes which is the config register value and received data will be 4 bytes, this would be the conversion value followed by config reg value. The values in rx_buf[2] and rx_buf[3] should be same as tx_buf sent.
    For 16bit mode which is just reading the conversion data after DRDY is low, you can just send current config reg value (2bytes) and receive conversion data (2bytes) at the same time
    nrf_drv_spi_transfer(&spi, m_tx_buf, 2, m_rx_buf, 2)
    hope above helps.
