nRf52832 device name change by using mobile app
I need to change the Device name in nRf52832. Mobile app sends the request to nRf52832.
Thanks.
static void ChangeDeviceName(void)
        uint32_t err_code;
        ble_gap_conn_params_t gap_conn_params;
        static uint8_t index = 0;
        advertising_stop();
        //sprintf(Devicename3, "HUAWEI_DEVICE %d", index);
        index++;
                                              (uint8_t *) Devicename3,
                                              strlen(Devicename3));
        NRF_LOG_INFO("device name error %d", err_code);
  • #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_power.h"
    #include "nrf_dfu_ble_svci_bond_sharing.h"
    #include "nrf_svci_async_function.h"
    #include "nrf_svci_async_handler.h"
    #include "ble_dfu.h"
    #include "nrf_bootloader_info.h"
    #include "uicr_config.h"
    #include <stdbool.h>
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "AMANDA_DFU"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    #define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
    #define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static void ble_dfu_buttonless_evt_handler(ble_dfu_buttonless_evt_type_t event);
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    uint8_t AMANDA_NAME[20];
    char Devicename_str[20];
    char Devicename2[20];
    char set_devicename_flag = 0,set_advstart_flag=0;
    char dest_data_0[48];
    char retval = 0;
    char Devicename3[10] = "MemsTech";
    static bool m_advertising_is_ongoing = false;
    typedef enum
            BLE_FLASH_EVT_DEV_NAME = 0,
            BLE_FLASH_EVT_MAC_ADDRESS,
    } ble_device_flash_evt_type_t;
    #define MANUF_PAYLOAD_1                 0x4E    // N
    #define MANUF_PAYLOAD_2                 0x4F    // O
    #define MANUF_PAYLOAD_3                 0x52    // R
    #define MANUF_PAYLOAD_4                 0x44    // D
    #define MANUF_PAYLOAD_5                 0x49    // I
    #define MANUF_PAYLOAD_6                 0x43    // C
    #define PAYLOAD_SIZE                    1
    #define TOP_INDEX                       5
    #define APP_COMPANY_IDENTIFIER          0x0059                                  /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
    static ble_advdata_t                    new_advdata;
    static uint8_t manufacturing_data_payload_list [] =
        MANUF_PAYLOAD_1,
        MANUF_PAYLOAD_2,
        MANUF_PAYLOAD_3,
        MANUF_PAYLOAD_4,
        MANUF_PAYLOAD_5,
        MANUF_PAYLOAD_6
    static void pm_evt_handler(pm_evt_t const * p_evt)
        pm_handler_on_pm_evt(p_evt);
        pm_handler_flash_clean(p_evt);
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                Devicename_str[i]=p_evt->params.rx_data.p_data[i];
                if(Devicename_str[0]=='s' && Devicename_str[1]=='e' && Devicename_str[2]=='t')
                    set_devicename_flag = 1;
                else if(Devicename_str[0]=='s' && Devicename_str[1]=='t' && Devicename_str[2]=='a' && Devicename_str[2]=='r' && Devicename_str[2]=='t')
                    set_advstart_flag = 1;
                else if(Devicename_str[0]!='s' && Devicename_str[1]!='e' && Devicename_str[2]!='t')
                    memset(Devicename_str, '\0', sizeof(Devicename_str));
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
       // ble_dfu_buttonless_init_t dfus_init = {0};
        // Initialize NUS.
        .evt_handler = ble_dfu_buttonless_evt_handler
        err_code = ble_dfu_buttonless_init(&dfus_init);
        // END Block Added for DFU
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        uint32_t       err_code;
        uint8_t compare = 0xFF;
        uint8_t send_data = 1;
        char stop_arr[13] = "stop_ble\n";
        char start_arr[13] = "start_ble\n";
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if (data_array[0] != 's')
                    index = 0;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        /*NRF_LOG_DEBUG("Ready to send data over BLE NUS");
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);*/
                         compare = strcmp(data_array,stop_arr);
                         NRF_LOG_INFO(data_array);
                         if(compare == 0)
                            (void) sd_ble_gap_adv_stop(m_advertising.adv_handle);
                            memset(data_array, 0, sizeof(data_array));
                            send_data = 0;
                         compare = strcmp(data_array,start_arr);
                         if(compare == 0)
                            //uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
                            //advertising_start();
                            //gap_params_init();
                           // gatt_init();
                            //services_init();
                            //advertising_init();
                            //conn_params_init();
                            ble_advertising_restart_without_whitelist(&m_advertising);
                            //APP_ERROR_CHECK(err_code);
                            err_code =0;
                            send_data = 1;
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
        switch (event)
            case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
                NRF_LOG_INFO("Device is preparing to enter bootloader mode\r\n");
            case BLE_DFU_EVT_BOOTLOADER_ENTER:
                NRF_LOG_INFO("Device will enter bootloader mode\r\n");
            case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
                NRF_LOG_ERROR("Device will enter bootloader mode\r\n");
                NRF_LOG_INFO("Unknown event from ble_dfu.\r\n");
    static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event)
        switch (event)
            case NRF_PWR_MGMT_EVT_PREPARE_DFU:
                NRF_LOG_INFO("Power management wants to reset to DFU mode\r\n");
                // Change this code to tailor to your reset strategy.
                // Returning false here means that the device is not ready to jump to DFU mode yet.
                // Here is an example using a variable to delay resetting the device:
              /*  if (!m_ready_for_reset)
                     return false;
                break;*/
                // Implement any of the other events available from the power management module:
                //      -NRF_PWR_MGMT_EVT_PREPARE_SYSOFF
                //      -NRF_PWR_MGMT_EVT_PREPARE_WAKEUP
                //      -NRF_PWR_MGMT_EVT_PREPARE_RESET
                return true;
        NRF_LOG_INFO("Power management allowed to reset to DFU mode\r\n");
        return true;
    NRF_PWR_MGMT_HANDLER_REGISTER(app_shutdown_handler, 0);
    /* This function will update the device name and advertising data accordingly. */
    /*void change_ble_device_name(uint8_t *device_name)
        //uint32_t               err_code;
        /* Change device name */
       /* uint32_t err_code = sd_ble_gap_device_name_set(&sec_mode,
                                               (uint8_t *) Devicename2,
                                              strlen(Devicename2));
        /* Store Current connection state od adv lib */
        /*uint16_t m_adv_current_slave_link_conn_handle_saved = m_advertising.current_slave_link_conn_handle;
        /* Re-initialize advertising module */
        /*err_code = ble_advertising_init(&m_advertising, &init);
        /* Re-store Current connection state lib */
        /*m_advertising.current_slave_link_conn_handle = m_adv_current_slave_link_conn_handle_saved;
    static void advertising_stop(void)
            if (m_advertising_is_ongoing == true)
                    err_code = sd_ble_gap_adv_stop(m_advertising.adv_handle);
                    NRF_LOG_INFO("Advertising Stop");
            uint32_t err_code;
            ble_advdata_manuf_data_t    manuf_data;
            new_advdata.p_manuf_specific_data = &manuf_data;
            static uint8_t payload_index = 0;
            advertising_stop();
            index++;
            manuf_data.company_identifier = APP_COMPANY_IDENTIFIER;
            manuf_data.data.p_data = manufacturing_data_payload_list + payload_index;
            manuf_data.data.size = PAYLOAD_SIZE;
            err_code = ble_advertising_advdata_update(&m_advertising, &new_advdata, NULL);
            if(payload_index == TOP_INDEX)
                payload_index = 0;
                payload_index++;
            //err_code = app_sched_event_put(NULL, 0, advertising_start);
    //BLE_ADVERTISING_DEF(m_advertising);
    static ble_advertising_init_t adv_init;
    void bluetooth_update_name(uint8_t* name) {
    	BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&sec_mode);
    	//if (current_config.name[0] != '\0') {
    //		err_code = sd_ble_gap_device_name_set(&sec_mode, name, strnlen(name, 10));
    	//	APP_ERROR_CHECK(err_code);
    //	else {
    		err_code = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)Devicename2, strlen(Devicename2));
      //sd_ble_gap_adv_stop(&m_advertising.adv_handle);
    	err_code = ble_advdata_encode(&adv_init.advdata, m_advertising.enc_advdata, &m_advertising.adv_data.adv_data.len);
    	//VERIFY_SUCCESS(err_code);
    	if (m_advertising.adv_modes_config.ble_adv_extended_enabled == true)
    #ifdef BLE_GAP_ADV_SET_DATA_SIZE_EXTENDED_CONNECTABLE_MAX_SUPPORTED
    		m_advertising.adv_data.scan_rsp_data.len = BLE_GAP_ADV_SET_DATA_SIZE_EXTENDED_CONNECTABLE_MAX_SUPPORTED;
    #else
    		m_advertising.adv_data.scan_rsp_data.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX;
    #endif // BLE_GAP_ADV_SET_DATA_SIZE_EXTENDED_CONNECTABLE_MAX_SUPPORTED
    	err_code = ble_advdata_encode(&adv_init.srdata,
    		m_advertising.adv_data.scan_rsp_data.p_data,
    		&m_advertising.adv_data.scan_rsp_data.len);
    	sd_ble_gap_adv_set_configure(&m_advertising.adv_handle,
    		m_advertising.p_adv_data,
    		NULL);
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        //err_code = ble_dfu_buttonless_async_svci_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        //printf("\r\nUART started.\r\n");
        // Enter main loop.
        for (;;)
            idle_state_handle();
            if(set_devicename_flag == 1)
                NRF_LOG_INFO("set received");
                set_devicename_flag = 0;
                for(int i=0; i< 15; i++)
                  Devicename2[i] = Devicename_str[i+4];
                NRF_LOG_INFO("%s",NRF_LOG_PUSH(Devicename2));
                //setGapDeviceName(Devicename2);
                //change_ble_device_name(Devicename2);
                NRF_LOG_INFO("Change device name");
                //advertising_stop();
                ChangeDeviceName();
                //bluetooth_update_name(Devicename2);
                //device_flash_update_evt_handler(BLE_FLASH_EVT_DEV_NAME, Devicename2, sizeof(Devicename2));
                //ble_advertising_restart_without_whitelist(&m_advertising);
            if(set_advstart_flag == 1)
              set_advstart_flag = 0;
              //Readvertising_start();
    Check this code
    As I suggest in the first reply, it should call ble_advertising_advdata_update() with the same 'srdata' and 'advata' arguments that were used in advertising_init(). This process will update your adv. payload with the new GAP device name. Here is a simple example.
            uint32_t err_code;
            char Devicename3[]="Nordic";
            advertising_stop();
            err_code = ble_advertising_advdata_update(&m_advertising, &adv_init.advdata, &adv_init.srdata);
            NRF_LOG_INFO("Update device name: %s", Devicename3);
    You can put ble_app_template_274738_change_device_name.zip under nRF5_SDK_17.0.2_d674dde\examples\ble_peripheral to test.
    -Amanda H.
