What directories/files can I remove if using only BLE?
I have a working set of implementations placed in the 17.0.2 SDK examples directory. The projects use SoftDevice s140 for BLE and flash write operations. I would like to know which directories I can delete in the components directory and have the projects still build and run on the nRF52840 DK and any other MCU that is compatible with an nRF52840 using only BLE. The components directory is quite large. How about the external and external tools? Do I need them?
I want to do this to reduce the size of the package I send to other implementers as well as to simplify the appearance of the project.
  • The problem with that is that I started with an example project (glucose example) which used the SDK. As I moved over to SoftDevice (at least for Bluetooth and Flash writes) There were certain directories I could remove quite easily, like the Ble Services. But many of the other directories I can't say. Now clearly the h-files and c-files included in the IDE's project files are going to remain from what was in the original glucose project unless I remove them. So what I am trying to do is to remove those that I inherited from the original example but no longer use.  I guess there is no straight forward way to do this unless you are an SDK-SoftDevice developer and know how the entire infrastructure works.
  • Hi Brian,
    I afraid there isn't a straight forward way of doing that other than looking at the project raw file and remove the folder that's not included. Some trial and error maybe needed. But you don't need a deep knowledge of the stack to find those folder that's not needed. I would assume the process would take around 15 minutes.
