i have to advertise Lis3dh data. I have accelerometer and nrf52840 dk. Pls assist how can i advertise the data of lis3dh xyz values
Max. advertisement time with the BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE flag is 180 seconds, see BLE_GAP_ADV_TIMEOUT_LIMITED_MAX .
Do you get BLE_ADV_EVT_IDLE event after APP_ADV_DURATION is been expired? If so, start advertising following the BLE_ADV_EVT_IDLE event.
-Amanda
when i have i have:
BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
APP_ADV_DURATION to 18000 and
{ uint32_t err_code;
switch (ble_adv_evt)
{ case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
break; } }
my device advertises for 3 mins.
BUT when
changed flags to BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
and APP_ADV_DURATION to 0 ;
err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST); APP_ERROR_CHECK(err_code);
but this way the device stops advertising.
What i need is that my device should advertise unlimitedly
pls help
Changing to BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE and setting APP_ADV_DURATION to 0 should advertise unlimitedly. You need to debug or check the debug log to see why BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE causes to stop advertising.
If you use BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE, you can start advertising in the BLE_ADV_EVT_IDLE event.
I will be out of the office for the next few days and back next Monday. If you still have the issue, please create a new support case. Sorry for the inconvenience.
Amand
thankyou it is working now
