Queries and Programing Interface for nRF52840 custom Board
We want to use nRF52840 SoC as our controller in our custom Board. I have reviewed the product specification document of nrf52840. I have following queries:
  1. Is High Voltage mode only used when we want to operate nRF52840 SoC with Li-Po Batteries or 5V DC source directly?
  2. Is there any other use of High Voltage Mode?
  3. In Normal Voltage mode can we run nRf52840 SoC with 3.6V DC source?
  4. For programing custom nRF52840 board using nRF52840 DK, we have to supply VDD pin on custom board with 3.0V?
  5. Is the below mention block diagram for programing nRF52840 custom board using nRF52840 DK correct?
Moghees Bin Zahid
  • Sorry for late reply and Thanks for the reply. So if we are using nRF52840 SoC in low power mode and at 3V, than above diagram that I have attach with question is correct?
    For first time we have to program it to change value of REG0
    I have read following link from Nordic Q/A page programing nRF52840 SoC in High Voltage Mode. In this page it says we have to program once nRF52840 SoC to change value of REG0. To change value of REG0 we have to supply directly to VDD and change REG0 output to 3V. After that we can program our SoC in High Voltage mode by attaching VDD to VTG. So I want to ask can we directly supply voltage at VDD if we are using it in high voltage mode?
    Moghees
     And in Normal voltage mode, Yes correct.
     No!!! In high voltage mode, VDD is an output. You should therefore never supply it in high voltage mode. Note the answer from the Nordic engineer says:
    • Make a debugger adapter that shorts VDDH and VDD if VDDH < 3.9V.
    Shorting VDDH and VDD will put the nRF into normal mode, thus making VDD an input.
    I think what you should do is to get a stand alone debugger that supports programming at your intended voltage.
    regards
    Jared
  • Thankyou for the reply, So I should be using debugger that supports programing at 1.8V. If I am using nRF52840 SoC in High Voltage mode?
    In order to program custom board we need to define custom_board.h and after that we can program soft device and our application code as well or do we need anything else?
    High voltage mode:
    In high voltage mode, meaning VDD and VDDH is not tied together, the nRF will support a input voltage on VDDH from 2V5 to 5V5. High voltage mode uses a two stage regulator stage to regulate the input voltage to the internal system voltage 1V3. The two stages are REG0 and REG1. REG0 regulates the input voltage from VDDH down to what is specified in the REG0 register. By default this register is set to 1V8. This voltage is commonly referred to as VDD and, and is also the GPIO voltage, which again decides the programming voltage you'll have to use when you try to program the IC through the SWD interface. In this case the VDD pin acts as a output and should therefore not be supplied.
    Normal voltage mode:
    In normal voltage mode, meaning VDD and VDDH is tied together, the nRF will support a voltage on VDD from 1V7 to 3V6. VDD is therefore an input in this case. Normal voltage mode omits REG0 and only use REG1 to regulate the input voltage directly to the system power. In this case, as in the previous, the GPIO voltage is equal to VDD, which means that the supported programming voltage depends on VDD.
    As explained, the nRF52840 in high voltage mode will by default set the programming voltage to 1V8. To change this, you would therefore have to use a programmer that supports 1V8 and then program a fw that changes the REG0 register.
     Yes.
    best regards
    Jared
    Documentation on the power configuration for the nRF52840 can be found here.
