How does nRF5340's network core access Crypto Cell?
Hi Sir/Madam,
Our application needs to be running on both cores and the network core needs to use some crypto algorithms provided by the crypto cell. From the data sheet, it seems the crypto cell is also reachable by the network core though it is owned by the application core, right? Can you give an example about how nrf5340 is configured so that the network core can use the crypto cell by using the mbedTLS?
Thank you!
Jun @ Intel, CA USA
  • Hi Einar,
    Thanks very much for your patience! I have better understanding now on the relationship between the crypto cell and the network core.
    One more question about crypto cell usage on the application core: our current application on the application core side actually doesn't enable the TrustZone mode, but can still use the the crypto cell through mbedTLS. Is enabling the trust zone necessary to access crypto cell and how is the mbedTLS on non-secure mode only app core still able to use crypto cell?
    By the way, the AES CCM peripheral on the network core side is NOT dedicated to Bluetooth, right? If we don't enable bluetooth on the network core, can we still use AES CCM for other purpose?
    Thank you!
    Jun
  • Hi Jun,
    You cannot use CryptoCell in any way from the non-secure domain, so no CryptoCell via mbedTLS either. You need to do it from secure mode. It is not a requirement to use TF-M though, but this is what we support going forward. You could also make something of your own, which is more minimal and only support what you need. But in any case, the code interfacing with CryptoCell must be in secure domain. If you look at the simpler SPM for inspiration. This demonstrates among other things how to use CryptoCell to get random numbers, and provide those to non-secure code via non-secure callable functions. You could do something similar.
    You can use it for what you want, so it is not dedicated to Bluetooth. But the feature set is for the most part limited to what you need for Bluetooth.
    Einar
  • Hi Einar,
    Just checked our config and and confirmed our app is built with "CONFIG_ARM_TRUSTZONE_M=y". So, the application is configured as a secured one. So, you are right, the mbedTLS is actually running at the secure mode.
    Thanks for the detailed explanations!
    Jun
