PPI CHANNEL USED TO generate pulse wave
Hi All,
I am using NRF51822 chip pca10001 development board.
I flashed ble_app_hrs application to the board.
I configure 3 channel for PPI.
static void ppi_init(void)
  uint32_t err_code;
	 err_code = sd_ppi_channel_assign(0,
                                     &(NRF_TIMER2->EVENTS_COMPARE[0]),
                                     &(NRF_GPIOTE->TASKS_OUT[0]));
		err_code = sd_ppi_channel_assign(1,
                                     &(NRF_TIMER2->EVENTS_COMPARE[1]),
		err_code = sd_ppi_channel_assign(2,
                                     &(NRF_TIMER2->TASKS_CLEAR));
I configure gpiote task for channel 0.
void gpiote_channel_0_set(void)
	 nrf_gpiote_task_config(0, AC_OUT_PIN, NRF_GPIOTE_POLARITY_TOGGLE, \
                           NRF_GPIOTE_INITIAL_VALUE_HIGH);
Now i enable all 3 channels.
__inline void ppi_enable(void)
		uint32_t err_code;
		err_code = sd_ppi_channel_enable_set( (PPI_CHEN_CH0_Msk) |  (PPI_CHEN_CH1_Msk)| (PPI_CHEN_CH2_Msk));
    APP_ERROR_CHECK(err_code)
The timer2 is intialised as fallows.
static void timer2_init(void)
   /* Start 16 MHz crystal oscillator */
    NRF_CLOCK->EVENTS_HFCLKSTARTED    = 0;
    NRF_CLOCK->TASKS_HFCLKSTART       = 1;
    /* Wait for the external oscillator to start up */
    while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
        // Do nothing.
		NRF_TIMER2->TASKS_CLEAR = 1;
    NRF_TIMER2->MODE        = TIMER_MODE_MODE_Timer;
		NRF_TIMER2->PRESCALER   = 4;
    /* Load initial values to Timer 2 CC registers */
    /* Set initial CC0 value to anything > 1 */
		NRF_TIMER2->BITMODE   = TIMER_BITMODE_BITMODE_16Bit;
Now i am updating timer2 cc0 value and cc1 value from BLE characteristic interrupt and then i start the timer.
But for constant cc0 and cc1 value its giving two waveform.
ex- cc0=1000(1ms), cc1=10000(9ms);
i am getting two wave
  1. 1ms on and 9ms off.
  2. 1ms off and 9ms on.
I need to get only first wave all the time if i write constant value to ble characteristic
Could any one tell me how to solve this?. ( I need to do this with PPI only).
I tried by reinitialising all ppi and gpiote for every ble characteristic interrupt then also it dont work.
Kindly tell me what is the issue.
Regards Punit
