calling pm_peers_delete cause fatal error
why does it happened?
nRF5_SDK_17.0.2_d674dde/ble_app_multirole_lesc
  • Likely because you are trying to call adv_scan_start() in main(), but it's already advertising.
    delete_bonds() -> event PM_EVT_PEERS_DELETE_SUCEEDED -> adv_scan_start() called in pm_evt_handler()
    , then you call adv_scan_start() again in main(), and get NRF_ERROR_INVALID_STATE.
    Sigurd said:
    If you want to "force" delete_bonds to be called, then set erase_bonds= true instead
    alternatively, you could try this:
        advertising_init();
        delete_bonds(); // Scanning and advertising is started by PM_EVT_PEERS_DELETE_SUCEEDED.
        // Start execution.
        NRF_LOG_INFO("LE Secure Connections example started.");
        // Enter main loop.
        for (;;)
            idle_state_handle();
  • so it seems like the adv_scan_start() cause this so can I add delete_bonds() to a button without error?
    i need to try to stop advertising,but it seems like it cannot be stop using
    err_code=sd_ble_gap_adv_stop(m_advertising.adv_handle);
    the same error shows as above
    so how to stop advertise correctly
  • nvm I think I fix those I need to stop both
        err_code=sd_ble_gap_scan_stop();
