otPlatSettingsWipe undefined reference error
Hello All,
I am developing thread base system.
I am using SDK - nRF5_SDK_for_Thread_and_Zigbee_v4.1.0_32ce5f8
Dev-kit - nrf52840
I am using mtd code for development of my product. For requirement I need to follow these 4 steps to join network
1 factory reset
2. ifconfig
3. Joiner start XXXX
4. thread start.
So, I have modified the mtd code as per my requirement to auto configure the above commands using API.
I am able execute "ifconfig", "Joiner Start XXX" and "thread Start" using respective APIs in main file. (Without entering CLI).
But If I use "otPlatSettingsWipe" API to factory reset I am getting "undefined reference to `otPlatSettingsWipe'"  error.
Can anyone help how to resolve this issue ? or for Factory reset is there any other function?
I am following CLI command flow to execute using API's
Thanks in advance
Rohit R
  • Hi
    I think I understand the problem better now, and will try to replicate your issue tomorrow.
    Sorry for this delay, but I need to get some more hardware to work with first.
    In the meantime, could you check if otInstanceErasePersistentInfo() returns an error?
    Sigurd Hellesvik
  • Hi
    otInstanceErasePersistentInfo() will erase the data. However, the data is already loaded. I managed to erase and reload the data by loading thread before erasing and then reinilizing(deinit+init) thread after:
    thread_init(&thread_configuration);
    err_code = otInstanceErasePersistentInfo(thread_ot_instance_get());
    thread_soft_deinit();
    Add this before the first thread_init() in your code.
    I will ask our openthread experts if there are any cleaner way to do this, and post it as a respond here if there is.
    Does this workaround solve your problem?
    Sigurd Hellesvik
  • Hi Sigurd,
    Thank you for the response.
    But it didn't work me. Here is my attached main file. Let me know declaration is correct.
    After connecting to leader board, when I tried to re-power my cli_mtd child code it is not connecting.
    I can not see LED1 turning ON. After re power it stays OFF only.
    And I am able to connect to leader or router device only when I flash the code again with erase and other steps. But not with this API.
     * Copyright (c) 2017 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup cli_example_main main.c
     * @ingroup cli_example
     * @brief An example presenting OpenThread CLI.
    #include "app_scheduler.h"
    #include "app_timer.h"
    #include "bsp_thread.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_log.h"
    #include "nrf_delay.h"
    #include "thread_utils.h"
    #include <openthread/thread.h>
    #include <openthread/joiner.h>
    #include <openthread/instance.h>
    #define SCHED_QUEUE_SIZE      32                              /**< Maximum number of events in the scheduler queue. */
    #define SCHED_EVENT_DATA_SIZE APP_TIMER_SCHED_EVENT_DATA_SIZE /**< Maximum app_scheduler event size. */
    otExtAddress ieeeEUI64; //Edit by Rohit August 17,2021
     * @section State
    static void thread_state_changed_callback(uint32_t flags, void * p_context)
        NRF_LOG_INFO("State changed! Flags: 0x%08x Current role: %d\r\n",
                     flags, otThreadGetDeviceRole(p_context));
     * @section Initialization
    /**@brief Function for initializing the Application Timer Module.
    static void timer_init(void)
        uint32_t err_code = app_timer_init();
    /**@brief Function for initializing the LEDs.
    static void leds_init(void)
        LEDS_CONFIGURE(LEDS_MASK);
        LEDS_OFF(LEDS_MASK);
    static void log_init(void)
    //Edit by Rohit August 17,2021****************************
    static void Read_EUi64Address (void)
        otInstance * p_instance = thread_ot_instance_get();
        otLinkGetFactoryAssignedIeeeEui64(p_instance, &ieeeEUI64);
        NRF_LOG_INFO("IeeeEUi64 Id     : %x",ieeeEUI64.m8);
    //Edit by Rohit Rajapure 25 August, 2021
    // This function deletes all settings from the settings
    //store, resetting it to its initial factory state
    static void FactoryReset(void)
       otError error;
    //   otPlatSettingsWipe(p_instance);
    //   otInstanceFactoryReset(p_instance);
         error = otInstanceErasePersistentInfo(p_instance);
         APP_ERROR_CHECK(error);
    //function to execute thread start command
    static void ThreadStart (void)
      otError error;
      error = otThreadSetEnabled(p_instance, true);
      ASSERT(error == OT_ERROR_NONE);
    //function to execute joiner start callback handler
    static void Joinercallback(otError aError, void * p_context)
     NRF_LOG_INFO("joiner state: 0x%08x \r\n",aError);
         //thread start
        ThreadStart();
    //function to execute joiner start command
    static void joinerStartInit(otJoinerCallback handler)
      otError error;
      error = otJoinerStart(p_instance,"SEMENS",NULL,NULL,NULL,NULL,NULL,handler,p_instance);
    /**@brief Function for initializing the Thread Stack.
    static void thread_instance_init(void)
        thread_configuration_t thread_configuration =
            .radio_mode        = THREAD_RADIO_MODE_RX_ON_WHEN_IDLE,
            .autocommissioning = false,
            .autostart_disable = false,//Edit by Rohit Rajapure 25 August, 2021 ifconfig command
        thread_init(&thread_configuration); //
        FactoryReset();
        //joiner start
        joinerStartInit(Joinercallback);
    //    thread_cli_init();
        thread_state_changed_callback_set(thread_state_changed_callback);
        uint32_t err_code = bsp_thread_init(thread_ot_instance_get());
    /**@brief Function for deinitializing the Thread Stack.
    static void thread_instance_finalize(void)
        bsp_thread_deinit(thread_ot_instance_get());
    /**@brief Function for initializing scheduler module.
    static void scheduler_init(void)
        APP_SCHED_INIT(SCHED_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
     * @section Main
    int main(int argc, char *argv[])
        log_init();
        scheduler_init();
        timer_init();
        leds_init();
        uint32_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
        Read_EUi64Address();
        while (true)
            thread_instance_init();
            while (!thread_soft_reset_was_requested())
                thread_process();
                app_sched_execute();
                    thread_sleep();
            thread_instance_finalize();
    Thanks and Regards
    Rohit R
  • Hi
    Erase can only run if thread before start. Initializing thread with autostart before calling erasePersistentStorage() will therefore not work.
    To fix this, use an separate initialization configuration without autostart for the temporary initialization.
       otError error;
       thread_configuration_t thread_configuration_for_erase =
            .autostart_disable = true,
         thread_init(&thread_configuration_for_erase);
         error = otInstanceErasePersistentInfo( thread_ot_instance_get());
    Sigurd Hellesvik
    Okay thank you for the response.
    I will try this suggestion and let you know the result.
    So, with work around and your explanation i understood that,
    1. Auto start should disable first then auto start the configuration and init
    2. Factory reset should be called before thread_instant_init.
    3. With this If I keep by leader or router board On and re power already connect child board it automatically connects to router or leader board.
    4. Similarly if I power down both router/leader and child board and power up again then auto connection happens.
    Am i correct?
    Correct me If i understood anything wrong here.
    So, I will test this suggestion and share you the result.
    Thanks and Regards
    Rohit R
