FATAL ERROR: command exited with status 1: /usr/bin/cmake --build /home/machinehum/projects/bike_tracker/ncs/nrf/applications/asset_tracker/build
I'm just trying to build the asset tracker firmware...
[machinehum@whitebox asset_tracker]$ ls
build        CMakeLists.txt  lwm2m_carrier_overlay.conf  overlay-pgps.conf  prj_qemu_x86.conf             README.rst   src
child_image  Kconfig         overlay-agps-pgps.conf      prj.conf           prj_thingy91_nrf9160_ns.conf  sample.yaml
[machinehum@whitebox asset_tracker]$ rm -r build/ ; west build -b thingy91_nrf52840
Including boilerplate (Zephyr base): /home/machinehum/projects/bike_tracker/ncs/zephyr/cmake/app/boilerplate.cmake
CMake Deprecation Warning at /home/machinehum/projects/bike_tracker/ncs/zephyr/cmake/app/boilerplate.cmake:37 (cmake_policy):
  The OLD behavior for policy CMP0079 will be removed from a future version
  of CMake.
  The cmake-policies(7) manual explains that the OLD behaviors of all
  policies are deprecated and that a policy should be set to OLD only under
  specific short-term circumstances.  Projects should be ported to the NEW
  behavior and not rely on setting a policy to OLD.
  /home/machinehum/projects/bike_tracker/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
  /home/machinehum/projects/bike_tracker/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
  CMakeLists.txt:9 (find_package)
-- Application: /home/machinehum/projects/bike_tracker/ncs/nrf/applications/asset_tracker
-- Zephyr version: 2.6.99 (/home/machinehum/projects/bike_tracker/ncs/zephyr), build: v2.6.0-rc1-ncs1-2242-g975e3710736e
-- Found Python3: /usr/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter
-- Found west (found suitable version "0.11.0", minimum required is "0.7.1")
-- Board: thingy91_nrf52840
-- Cache files will be written to: /home/machinehum/.cache/zephyr
-- ZEPHYR_TOOLCHAIN_VARIANT not set, trying to locate Zephyr SDK
-- Using toolchain: zephyr 0.12.4 (/home/machinehum/.local/zephyr-sdk-0.12.4)
-- Found dtc: /home/machinehum/.local/zephyr-sdk-0.12.4/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
-- Found BOARD.dts: /home/machinehum/projects/bike_tracker/ncs/nrf/boards/arm/thingy91_nrf52840/thingy91_nrf52840.dts
-- Generated zephyr.dts: /home/machinehum/projects/bike_tracker/ncs/nrf/applications/asset_tracker/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/machinehum/projects/bike_tracker/ncs/nrf/applications/asset_tracker/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /home/machinehum/projects/bike_tracker/ncs/nrf/applications/asset_tracker/build/zephyr/include/generated/device_extern.h
warning: CONSOLE_HANDLER (defined at drivers/console/Kconfig:39) was assigned the value 'y' but got
the value 'n'. Check these unsatisfied dependencies: UART_CONSOLE (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_CONSOLE_HANDLER.html and/or look up
CONSOLE_HANDLER in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: The choice symbol CONSOLE_GETCHAR (defined at subsys/console/Kconfig:16) was selected (set
=y), but no symbol ended up as the choice selection. See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_CONSOLE_GETCHAR.html and/or look up
CONSOLE_GETCHAR in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
Parsing /home/machinehum/projects/bike_tracker/ncs/nrf/applications/asset_tracker/Kconfig
Loaded configuration '/home/machinehum/projects/bike_tracker/ncs/nrf/boards/arm/thingy91_nrf52840/thingy91_nrf52840_defconfig'
Merged configuration '/home/machinehum/projects/bike_tracker/ncs/nrf/applications/asset_tracker/prj.conf'
Configuration saved to '/home/machinehum/projects/bike_tracker/ncs/nrf/applications/asset_tracker/build/zephyr/.config'
Kconfig header saved to '/home/machinehum/projects/bike_tracker/ncs/nrf/applications/asset_tracker/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 10.2.0
-- The CXX compiler identification is GNU 10.2.0
-- Found assembler: /home/machinehum/.local/zephyr-sdk-0.12.4/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
=== child image mcuboot -  begin ===
  of CMake.
  CMakeLists.txt:44 (find_package)
-- Application: /home/machinehum/projects/bike_tracker/ncs/bootloader/mcuboot/boot/zephyr
-- Found devicetree overlay: /home/machinehum/projects/bike_tracker/ncs/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: /home/machinehum/projects/bike_tracker/ncs/nrf/applications/asset_tracker/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/machinehum/projects/bike_tracker/ncs/nrf/applications/asset_tracker/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /home/machinehum/projects/bike_tracker/ncs/nrf/applications/asset_tracker/build/mcuboot/zephyr/include/generated/device_extern.h
warning: LOG_DEFAULT_LEVEL (defined at
/home/machinehum/projects/bike_tracker/ncs/nrf/samples/Kconfig:34,
subsys/logging/Kconfig.filtering:13) was assigned the value '0' but got the value ''. Check these
unsatisfied dependencies: (LOG || LOG) (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_LOG_DEFAULT_LEVEL.html and/or look up
LOG_DEFAULT_LEVEL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
warning: BOOTLOADER_MCUBOOT (defined at Kconfig.zephyr:495) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: (!MCUBOOT) (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_BOOTLOADER_MCUBOOT.html and/or look up
BOOTLOADER_MCUBOOT in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: The choice symbol LOG_MODE_MINIMAL (defined at subsys/logging/Kconfig.mode:45) was selected
(set =y), but no symbol ended up as the choice selection. See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_LOG_MODE_MINIMAL.html and/or look up
LOG_MODE_MINIMAL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
Parsing /home/machinehum/projects/bike_tracker/ncs/bootloader/mcuboot/boot/zephyr/Kconfig
Merged configuration '/home/machinehum/projects/bike_tracker/ncs/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration '/home/machinehum/projects/bike_tracker/ncs/bootloader/mcuboot/boot/zephyr/boards/thingy91_nrf52840.conf'
Merged configuration '/home/machinehum/projects/bike_tracker/ncs/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Configuration saved to '/home/machinehum/projects/bike_tracker/ncs/nrf/applications/asset_tracker/build/mcuboot/zephyr/.config'
Kconfig header saved to '/home/machinehum/projects/bike_tracker/ncs/nrf/applications/asset_tracker/build/mcuboot/zephyr/include/generated/autoconf.h'
CMake Warning at /home/machinehum/projects/bike_tracker/ncs/nrf/lib/flash_patch/CMakeLists.txt:9 (message):
        --- WARNING: To maintain the integrity of secure boot, ---
        --- enable CONFIG_DISABLE_FLASH_PATCH in production.   ---
MCUBoot bootloader key file: /home/machinehum/projects/bike_tracker/ncs/bootloader/mcuboot/root-rsa-2048.pem
-- Configuring done
-- Generating done
-- Build files have been written to: /home/machinehum/projects/bike_tracker/ncs/nrf/applications/asset_tracker/build/mcuboot
=== child image mcuboot -  end ===
CMake Warning at /home/machinehum/projects/bike_tracker/ncs/nrf/modules/mcuboot/CMakeLists.txt:151 (message):
        --- WARNING: Using default MCUBoot key, it should not ---
        --- be used for production.                           ---
ERROR This combination of SoC and floating point ABI is not supported by libmodem (/home/machinehum/projects/bike_tracker/ncs/nrfxlib/nrf_modem/lib/cortex-m4/soft-float doesn't exist.)
CMake Warning at /home/machinehum/projects/bike_tracker/ncs/zephyr/CMakeLists.txt:1612 (message):
Dropping partition 'nrf_modem_lib_trace' since its size is 0.
-- Configuring done
-- Generating done
ninja: error: '/home/machinehum/projects/bike_tracker/ncs/nrfxlib/nrf_modem/lib/cortex-m4/soft-float/libmodem.a', needed by 'zephyr/zephyr_prebuilt.elf', missing and no known rule to make it
