crashing from _start without even entering into main() function
I am using nrf52832 custom board and sdk17.2.0.
My application is a Freertos application. I see that my application is going to hardfault from _start without entering into the main() function.
Attached sdk_config.h , FreeRTOSConfig.h and the screenshot of the hardfault for reference.
Can someone please help me to resolve the issue?
 8358.FreeRTOSConfig.h6215.sdk_config.h
  • If increasing the task stack sizes did not help, then I am not sure what is causing this hardfault. if the hardfault_c_handler is not able to give any meaningful address and cause for this hardfault, then it must be a memory corruption that happened that during somewhere in the backend of nrf_log. Try to step through the debugger and try to pin point the exact line where the hardfault is happening. When you understand the context of this hardfault, we might get more hints on how to fix it.
  • but it is not entering into main function itself to step in and debug
  • I see, seeing "Thread #2" in your snapshot made me assume that your device has started into main normally.
    Then something is entirely wrong in your setup. I can see that you have eclipse project. Which startupup files did you add to that project? Is the configuration of the project correct with all the correct preprocessor defines and device files matching nrf52832 device you are using? I do not use eclipse so it is hard for me to understand why your device does not boot properly into main. Seems like a startup issue which mostly point to configuration then.
  • i think i found the issue.
    On calling the below rtc function, that issue is coming.
    The issue is coming from return (mktime(&t1));. If i comment this then i dont see the issue.
    But that is needed. Can you please help?
    uint32_t get_current_time(void)
    rtc_t nowTime;
    get_time(&nowTime);
    struct tm t1 = {.tm_year = RTC_Bcd2ToByte(nowTime.year) + BASE_YEAR,
    .tm_mon = RTC_Bcd2ToByte(nowTime.month) - 1, /* In C, Jan = 0 */
    .tm_mday = RTC_Bcd2ToByte(nowTime.days),
    .tm_wday = RTC_Bcd2ToByte(nowTime.weekDay),
    .tm_hour = RTC_Bcd2ToByte(nowTime.hour),
    .tm_min = RTC_Bcd2ToByte(nowTime.min),
    .tm_sec = RTC_Bcd2ToByte(nowTime.sec)};
  • you are returning the address of t1 which is allocated from stack and the address is invalid outside the get_current_time scope. Either make t1 static by declaring as below (so that it its memory pointer remains valid outside the get_current_time scope
    static struct tm t1 = {.tm_year = RTC_Bcd2ToByte(nowTime.year) + BASE_YEAR,
    or declare this struct as global variable so it is allocated in the different section of the memory with memory pointer address valid through the runtime of your application.
