Hi everyone,
I have a fairly simple use for ADC: sample 4 channels (scan mode) every 10ms and store in RAM.
Every now and then (asynchronously) there will be a function or a task (not in ISR context) that will want to read the latest values of the 4 channels.
I've been struggling to implement that without a potential for getting a race condition (where the task might read the values as they are written), and I wanted to ask for your advice on that.
My (simplified) code for configuring the ADC is as follows:
#define NUM_SAADC_CHANNELS 4
#define ADC_NUM_SAMPLES_IN_BUFFER NUM_SAADC_CHANNELS
static nrf_saadc_value_t m_buffer_pool[2][ADC_NUM_SAMPLES_IN_BUFFER];
static volatile uint32_t m_buffer_index = 0; // current buffer idx the DMA will be using to copy the ADC samples to (alternates between 0 and 1)
static void saadc_callback(nrfx_saadc_evt_t const * p_event)
if (p_event->type == NRFX_SAADC_EVT_DONE)
// p_buffer is a pointer to the buffer with converted samples.
/* set buffers for the next ADC event */
APP_ERROR_CHECK(nrfx_saadc_buffer_convert(p_event->data.done.p_buffer, ADC_NUM_SAMPLES_IN_BUFFER));
m_buffer_index ^= 1; // 0 becomes 1, 1 becomes 0
ret_code_t adc_init(void)
ret_code_t err_code = NRF_SUCCESS;
// Initialize SAADC
nrfx_saadc_init(...);
// Initialize ADC channels
for (int i=0; i<NUM_SAADC_CHANNELS; i++) {
nrf_saadc_channel_config_t channel_config = NRFX_SAADC_DEFAULT_CHANNEL_CONFIG_SE(...);
err_code = nrfx_saadc_channel_init(...);
// Configure buffers to ensure double buffering of samples, to avoid data loss when the sampling frequency is high
err_code = nrfx_saadc_buffer_convert(m_buffer_pool[0],ADC_NUM_SAMPLES_IN_BUFFER);
err_code = nrfx_saadc_buffer_convert(m_buffer_pool[1],ADC_NUM_SAMPLES_IN_BUFFER);
// Initialize PPI and Timer, as in the ADC example
return err_code;
In a nutshell it's identical to the example ADC code, where we have a double buffer, and PPI+Timer to sample every 10ms.
As for the asynchronous function run from a task, it will occasionally need to read the latest values stored by the ADC. I was thinking about this code:
void adc_get_latest_values(int16_t* p_array)
// grab the values from the pool that is not currently being updated
memcpy(p_array, &m_buffer_pool[m_buffer_index^1], ADC_NUM_SAMPLES_IN_BUFFER*sizeof(m_buffer_pool[0][0]));
My idea is that the ADC will update the buffer index m_buffer_index (0 or 1) and the task will read from m_buffer_index^1 (1 or 0).
My concern here is that there is a potential for a race condition, where m_buffer_index would get updated by the ISR while the function above is being run.
Your advice would be greatly appreciated!
