While debugging this code https://github.com/Rallare/fw-nrfconnect-nrf/blob/nrf9160_samples/samples/nrf9160/adc/src/main.c using nrf9160dk getting error "device_get_binding ADC_0 failed"
Compiling successfully.
Can anyone please suggest a solution?
NCS version v1.5.1
overlay file
&led0 {
gpios = <&gpio0 12 GPIO_INT_ACTIVE_LOW>;
status = "enabled";
&adc {
status = "ok";
conf file
CONFIG_BSD_LIBRARY=y
CONFIG_GPIO=y
CONFIG_SERIAL=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_TEST_RANDOM_GENERATOR=y
CONFIG_NETWORKING=y
CONFIG_NET_BUF_USER_DATA_SIZE=1
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_RAW_MODE=y
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
CONFIG_LOG=n
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_HEAP_MEM_POOL_SIZE=1024
# LTE link control
CONFIG_LTE_LINK_CONTROL=n
CONFIG_ADC=y
CONFIG_ADC_0=y
CONFIG_ADC_NRFX_SAADC=y
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_COMPILER_OPT="-DNRFX_SAADC_ENABLED=1"I see you're using the macro GPIO_INT_ACTIVE_LOW in the overlay file, which is deprecated and should give you an error while building so I suspect the overlay file isn't being included in the build for some reason.
Have you checked that the ADC node is enabled in the resulting DeviceTree? You can see this in the file build/zephyr/zephyr.dts.
HI,
The issue is solved by selecting ADC driver from the below location
Project > config nRF SDK project > menuconfig - then search ADC then check "ADC driver" checkbox
