How to change Frequency of Notification(Subscription) of read value in BLE Central Example Code?
In BLE Central Example like HRS and RSCS,
Central has Enabled the notification  when event handler find Case : BLE_RSCS/HRS_C_EVT_DISCOVERY_COMPLETE.
But what if we want to read the value in fixed timed interval. Which function we need to use?
Also I found that Enable notification function reads value only if that value changes.
What changes will be require if we want to read/notify that value also if it is not changing ?
I am using nRF5_SDK_17.0.2 with nRF52840-DK Board
    I have tried above example in peripheral, which is working fine but when I am trying to implement on SDK 17.0.2--> examples-->ble_central --> ble_app_hrs_c
    In which I have removed battery Services. and related event handler
    I am getting below Error:--
    <info> app_timer: RTC: initialized.
    <info> app: Heart Rate collector example started.
    <info> app: Starting scan.
    <info> app: Connected.
    <error> app: ERROR 8 [NRF_ERROR_INVALID_STATE] at C:\Nordic_Semi\nRF5_SDK_17.0.2_d674dde\examples\ble_central\ble_app_hrs_c\main.c:281
    PC at: 0x00033613
    <error> app: End of error report
    It says error at :
    // Discover peer's services.
    err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
     * @brief BLE Heart Rate Collector application main file.
     * This file contains the source code for a sample heart rate collector.
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf_sdm.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_db_discovery.h"
    #include "ble_srv_common.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_pwr_mgmt.h"
    #include "app_util.h"
    #include "app_error.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "ble_hrs_c.h"
    #include "app_timer.h"
    #include "bsp_btn_ble.h"
    #include "fds.h"
    #include "nrf_fstorage.h"
    #include "ble_conn_state.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_lesc.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_ble_scan.h"
    #include "nrf_drv_clock.h"
    #define APP_BLE_CONN_CFG_TAG        1                                   /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_BLE_OBSERVER_PRIO       3                                   /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_SOC_OBSERVER_PRIO       1                                   /**< Applications' SoC observer priority. You shouldn't need to modify this value. */
    #define LESC_DEBUG_MODE             0                                   /**< Set to 1 to use LESC debug keys, allows you to use a sniffer to inspect traffic. */
    #define SEC_PARAM_BOND              1                                   /**< Perform bonding. */
    #define SEC_PARAM_MITM              0                                   /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC              1                                   /**< LE Secure Connections enabled. */
    #define SEC_PARAM_KEYPRESS          0                                   /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES   BLE_GAP_IO_CAPS_NONE                /**< No I/O capabilities. */
    #define SEC_PARAM_OOB               0                                   /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE      7                                   /**< Minimum encryption key size in octets. */
    #define SEC_PARAM_MAX_KEY_SIZE      16                                  /**< Maximum encryption key size in octets. */
    #define SCAN_DURATION_WITELIST      3000                                /**< Duration of the scanning in units of 10 milliseconds. */
    #define TARGET_UUID                 BLE_UUID_HEART_RATE_SERVICE         /**< Target device uuid that application is looking for. */
    /**@brief Macro to unpack 16bit unsigned UUID from octet stream. */
    #define UUID16_EXTRACT(DST, SRC) \
        do                           \
            (*(DST))   = (SRC)[1];   \
            (*(DST)) <<= 8;          \
            (*(DST))  |= (SRC)[0];   \
        } while (0)
    NRF_BLE_GQ_DEF(m_ble_gatt_queue,                                    /**< BLE GATT Queue instance. */
                   NRF_SDH_BLE_CENTRAL_LINK_COUNT,
                   NRF_BLE_GQ_QUEUE_SIZE);
    BLE_HRS_C_DEF(m_hrs_c);                                             /**< Structure used to identify the heart rate client module. */
    NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc);                                    /**< DB discovery module instance. */
    NRF_BLE_SCAN_DEF(m_scan);                                           /**< Scanning module instance. */
    APP_TIMER_DEF(m_repeated_timer_id);   /**< Handler for repeated timer used to blink LED 1. */
    static uint16_t m_conn_handle;                                      /**< Current connection handle. */
    static bool     m_whitelist_disabled;                               /**< True if whitelist has been temporarily disabled. */
    static bool     m_memory_access_in_progress;                        /**< Flag to keep track of ongoing operations on persistent memory. */
    /**< Scan parameters requested for scanning and connection. */
    static ble_gap_scan_params_t const m_scan_param =
        .active        = 0x01,
    #if (NRF_SD_BLE_API_VERSION > 7)
        .interval_us   = NRF_BLE_SCAN_SCAN_INTERVAL * UNIT_0_625_MS,
        .window_us     = NRF_BLE_SCAN_SCAN_WINDOW * UNIT_0_625_MS,
    #else
        .interval      = NRF_BLE_SCAN_SCAN_INTERVAL,
        .window        = NRF_BLE_SCAN_SCAN_WINDOW,
    #endif // (NRF_SD_BLE_API_VERSION > 7)
        .filter_policy = BLE_GAP_SCAN_FP_WHITELIST,
        .timeout       = SCAN_DURATION_WITELIST,
        .scan_phys     = BLE_GAP_PHY_1MBPS,
    /**@brief Names which the central applications will scan for, and which will be advertised by the peripherals.
     *  if these are set to empty strings, the UUIDs defined below will be used
    static char const m_target_periph_name[] = "";      /**< If you want to connect to a peripheral using a given advertising name, type its name here. */
    static bool is_connect_per_addr = false;            /**< If you want to connect to a peripheral with a given address, set this to true and put the correct address in the variable below. */
    static ble_gap_addr_t const m_target_periph_addr =
        /* Possible values for addr_type:
           BLE_GAP_ADDR_TYPE_PUBLIC,
           BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
           BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE,
           BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_NON_RESOLVABLE. */
        .addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
        .addr      = {0x8D, 0xFE, 0x23, 0x86, 0x77, 0xD9}
    static void scan_start(void);
    /**@brief Function for asserts in the SoftDevice.
     * @param[in] line_num     Line number of the failing ASSERT call.
     * @param[in] p_file_name  File name of the failing ASSERT call.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for handling the Heart Rate Service Client and Battery Service Client errors.
    static void service_error_handler(uint32_t nrf_error)
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling database discovery events.
     * @details This function is callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function should forward the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        ble_hrs_on_db_disc_evt(&m_hrs_c, p_evt);
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        pm_handler_on_pm_evt(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
                // Bonds are deleted. Start scanning.
                scan_start();
     * @brief Function for shutdown events.
     * @param[in]   event       Shutdown type.
    static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
        ret_code_t err_code;
        switch (event)
            case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
                // Prepare wakeup buttons.
        return true;
    NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected.");
                //err_code = app_timer_start(m_repeated_timer_id, APP_TIMER_TICKS(1000), NULL); //vipul
                if (ble_conn_state_central_conn_count() < NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                    scan_start();
            } break;
                NRF_LOG_INFO("Disconnected, reason 0x%x.",
                             p_gap_evt->params.disconnected.reason);
                err_code = app_timer_stop(m_repeated_timer_id);
                    scan_start();
            } break;
            case BLE_GAP_EVT_TIMEOUT:
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    NRF_LOG_INFO("Connection Request timed out.");
            } break;
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accepting parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                        &p_gap_evt->params.conn_param_update_request.conn_params);
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                NRF_LOG_DEBUG("BLE_GAP_EVT_SEC_PARAMS_REQUEST");
            case BLE_GAP_EVT_AUTH_KEY_REQUEST:
                NRF_LOG_INFO("BLE_GAP_EVT_AUTH_KEY_REQUEST");
            case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
                NRF_LOG_INFO("BLE_GAP_EVT_LESC_DHKEY_REQUEST");
             case BLE_GAP_EVT_AUTH_STATUS:
                 NRF_LOG_INFO("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
                              p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
                              p_ble_evt->evt.gap_evt.params.auth_status.bonded,
                              p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
                              *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
                              *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
    /**@brief SoftDevice SoC event handler.
     * @param[in]   evt_id      SoC event.
     * @param[in]   p_context   Context.
    static void soc_evt_handler(uint32_t evt_id, void * p_context)
        switch (evt_id)
            case NRF_EVT_FLASH_OPERATION_SUCCESS:
                /* fall through */
            case NRF_EVT_FLASH_OPERATION_ERROR:
                if (m_memory_access_in_progress)
                    m_memory_access_in_progress = false;
                    scan_start();
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
        // Register handlers for BLE and SoC events.
        NRF_SDH_SOC_OBSERVER(m_soc_observer, APP_SOC_OBSERVER_PRIO, soc_evt_handler, NULL);
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /** @brief Clear bonding information from persistent storage
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
    /**@brief Function for disabling the use of whitelist for scanning.
    static void whitelist_disable(void)
        if (!m_whitelist_disabled)
            NRF_LOG_INFO("Whitelist temporarily disabled.");
            m_whitelist_disabled = true;
            nrf_ble_scan_stop();
            scan_start();
     * @param[in]   event   Event generated by button press.
        switch (event)
            case BSP_EVENT_SLEEP:
                nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
                whitelist_disable();
    /**@brief Heart Rate Collector Handler.
    static void hrs_c_evt_handler(ble_hrs_c_t * p_hrs_c, ble_hrs_c_evt_t * p_hrs_c_evt)
        switch (p_hrs_c_evt->evt_type)
            case BLE_HRS_C_EVT_DISCOVERY_COMPLETE:
                NRF_LOG_DEBUG("Heart rate service discovered.");
                err_code = ble_hrs_c_handles_assign(p_hrs_c,
                                                    p_hrs_c_evt->conn_handle,
                                                    &p_hrs_c_evt->params.peer_db);
                // Initiate bonding.
                err_code = pm_conn_secure(p_hrs_c_evt->conn_handle, false);
                if (err_code != NRF_ERROR_BUSY)
                // Heart rate service discovered. Enable notification of Heart Rate Measurement.
                err_code = ble_hrs_c_hrm_notif_enable(p_hrs_c);
            } break;
            case BLE_HRS_C_EVT_HRM_NOTIFICATION:
                NRF_LOG_INFO("Heart Rate = %d.", p_hrs_c_evt->params.hrm.hr_value);
                if (p_hrs_c_evt->params.hrm.rr_intervals_cnt != 0)
                    uint32_t rr_avg = 0;
                    for (uint32_t i = 0; i < p_hrs_c_evt->params.hrm.rr_intervals_cnt; i++)
                        rr_avg += p_hrs_c_evt->params.hrm.rr_intervals[i];
                    rr_avg = rr_avg / p_hrs_c_evt->params.hrm.rr_intervals_cnt;
                    NRF_LOG_DEBUG("rr_interval (avg) = %d.", rr_avg);
            } break;
    /**@brief Timeout handler for the repeated timer.
    static void repeated_timer_handler(void * p_context)
    //  hrs_c_init();
        ble_hrs_c_init_t hrs_c_init_obj;
        hrs_c_init_obj.evt_handler   = hrs_c_evt_handler;
        hrs_c_init_obj.error_handler = service_error_handler;
        hrs_c_init_obj.p_gatt_queue  = &m_ble_gatt_queue;
        ret_code_t err_code = ble_hrs_c_init(&m_hrs_c, &hrs_c_init_obj);
    /**@brief Create timers.
    static void create_timers()
        // Create timers
        err_code = app_timer_create(&m_repeated_timer_id,
                                    APP_TIMER_MODE_REPEATED,
                                    repeated_timer_handler);
     * @brief Battery level collector initialization.
     * @brief Database discovery collector initialization.
    static void db_discovery_init(void)
        ble_db_discovery_init_t db_init;
        memset(&db_init, 0, sizeof(db_init));
        db_init.evt_handler  = db_disc_handler;
        db_init.p_gatt_queue = &m_ble_gatt_queue;
        ret_code_t err_code = ble_db_discovery_init(&db_init);
    /**@brief Retrieve a list of peer manager peer IDs.
     * @param[inout] p_peers   The buffer where to store the list of peer IDs.
     * @param[inout] p_size    In: The size of the @p p_peers buffer.
     *                         Out: The number of peers copied in the buffer.
    static void peer_list_get(pm_peer_id_t * p_peers, uint32_t * p_size)
        pm_peer_id_t peer_id;
        uint32_t     peers_to_copy;
        peers_to_copy = (*p_size < BLE_GAP_WHITELIST_ADDR_MAX_COUNT) ?
                         *p_size : BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
        peer_id = pm_next_peer_id_get(PM_PEER_ID_INVALID);
        *p_size = 0;
        while ((peer_id != PM_PEER_ID_INVALID) && (peers_to_copy--))
            p_peers[(*p_size)++] = peer_id;
            peer_id = pm_next_peer_id_get(peer_id);
    static void whitelist_load()
        ret_code_t   ret;
        pm_peer_id_t peers[8];
        uint32_t     peer_cnt;
        memset(peers, PM_PEER_ID_INVALID, sizeof(peers));
        peer_cnt = (sizeof(peers) / sizeof(pm_peer_id_t));
        // Load all peers from flash and whitelist them.
        peer_list_get(peers, &peer_cnt);
        ret = pm_whitelist_set(peers, peer_cnt);
        APP_ERROR_CHECK(ret);
        // Setup the device identies list.
        // Some SoftDevices do not support this feature.
        ret = pm_device_identities_list_set(peers, peer_cnt);
        if (ret != NRF_ERROR_NOT_SUPPORTED)
    static void on_whitelist_req(void)
        // Whitelist buffers.
        ble_gap_addr_t whitelist_addrs[8];
        ble_gap_irk_t  whitelist_irks[8];
        memset(whitelist_addrs, 0x00, sizeof(whitelist_addrs));
        memset(whitelist_irks,  0x00, sizeof(whitelist_irks));
        uint32_t addr_cnt = (sizeof(whitelist_addrs) / sizeof(ble_gap_addr_t));
        uint32_t irk_cnt  = (sizeof(whitelist_irks)  / sizeof(ble_gap_irk_t));
        // Reload the whitelist and whitelist all peers.
        whitelist_load();
        // Get the whitelist previously set using pm_whitelist_set().
        err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
                                    whitelist_irks,  &irk_cnt);
        if (((addr_cnt == 0) && (irk_cnt == 0)) ||
            (m_whitelist_disabled))
            // Don't use whitelist.
            err_code = nrf_ble_scan_params_set(&m_scan, NULL);
    /**@brief Function to start scanning.
        if (nrf_fstorage_is_busy(NULL))
            m_memory_access_in_progress = true;
            return;
        NRF_LOG_INFO("Starting scan.");
        err_code = nrf_ble_scan_start(&m_scan);
        err_code = bsp_indication_set(BSP_INDICATE_SCANNING);
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
    /**@brief Function for initializing the power management module. */
    /**@brief GATT module event handler.
    static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
            case NRF_BLE_GATT_EVT_ATT_MTU_UPDATED:
                NRF_LOG_INFO("GATT ATT MTU on connection 0x%x changed to %d.",
                             p_evt->conn_handle,
                             p_evt->params.att_mtu_effective);
            } break;
            case NRF_BLE_GATT_EVT_DATA_LENGTH_UPDATED:
                NRF_LOG_INFO("Data length for connection 0x%x updated to %d.",
                             p_evt->conn_handle,
                             p_evt->params.data_length);
            } break;
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
        switch(p_scan_evt->scan_evt_id)
            case NRF_BLE_SCAN_EVT_WHITELIST_REQUEST:
                on_whitelist_req();
                m_whitelist_disabled = false;
            } break;
            case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
                err_code = p_scan_evt->params.connecting_err.err_code;
            } break;
            case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
                NRF_LOG_INFO("Scan timed out.");
                scan_start();
            } break;
            case NRF_BLE_SCAN_EVT_FILTER_MATCH:
            case NRF_BLE_SCAN_EVT_WHITELIST_ADV_REPORT:
    /**@brief Function for initializing the timer.
    static void timer_init(void)
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    /**@brief Function for initialization scanning and setting filters.
    static void scan_init(void)
        nrf_ble_scan_init_t init_scan;
        memset(&init_scan, 0, sizeof(init_scan));
        init_scan.p_scan_param     = &m_scan_param;
        init_scan.connect_if_match = true;
        init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
        err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
        ble_uuid_t uuid =
            .uuid = TARGET_UUID,
            .type = BLE_UUID_TYPE_BLE,
        err_code = nrf_ble_scan_filter_set(&m_scan,
                                           SCAN_UUID_FILTER,
                                           &uuid);
        if (strlen(m_target_periph_name) != 0)
                                               SCAN_NAME_FILTER,
                                               m_target_periph_name);
        if (is_connect_per_addr)
                                              SCAN_ADDR_FILTER,
                                              m_target_periph_addr.addr);
        err_code = nrf_ble_scan_filters_enable(&m_scan,
                                               NRF_BLE_SCAN_ALL_FILTER,
                                               false);
     * @details Handle any pending log operation(s), then sleep until the next event occurs.
        err_code = nrf_ble_lesc_request_handler();
        NRF_LOG_FLUSH();
        nrf_pwr_mgmt_run();
    /**@brief Function for starting a scan, or instead trigger it from peer manager (after
     *        deleting bonds).
     * @param[in] p_erase_bonds Pointer to a bool to determine if bonds will be deleted before scanning.
    void scanning_start(bool * p_erase_bonds)
        // Start scanning for peripherals and initiate connection
        // with devices that advertise GATT Service UUID.
        if (*p_erase_bonds == true)
            // Scan is started by the PM_EVT_PEERS_DELETE_SUCCEEDED event.
            delete_bonds();
            scan_start();
    /**@brief Function starting the internal LFCLK oscillator.
     * @details This is needed by RTC1 which is used by the Application Timer
     *          (When SoftDevice is enabled the LFCLK is always running and this is not needed).
    static void lfclk_request(void)
        ret_code_t err_code = nrf_drv_clock_init();
        bool erase_bonds;
        // Initialize.
        log_init();
        timer_init();
        lfclk_request();
        power_management_init();
        ble_stack_init();
        gatt_init();
        peer_manager_init();
        db_discovery_init();
     // bas_c_init();
        create_timers();
        scan_init();
        // Start execution.
        NRF_LOG_INFO("Heart Rate collector example started.");
        scanning_start(&erase_bonds);
        // Enter main loop.
        for (;;)
            idle_state_handle();
    Please Find Modified Main.c File
  • Hi
    Why have you moved the HRS client init code into the repeated_timer_handler?
    This code should be run during initialization, after you have initialized the BLE stack and the GAP settings, and before you start advertising or scanning.
    Best regards
    Torbjørn
  • Thank you for your reply.
    Then how we can separate Notification case out of hrs_c_evt_handler?
  • Hi
    Not sure what you mean by this. Why do you need to separate the notification case out of the handler?
    If you want to run some code on the client side at a fixed timer interval, whether or not you get a notification from the peripheral, there is nothing stopping you from doing this.
    Just run the repeated_timer_handler at the rate you wish, and use the old data value if no new data has been sent.
    Every time the BLE_HRS_C_EVT_HRM_NOTIFICATION event occurs you simply update the local variable, and then the next time the repeated_timer_handler runs it will use the new value.
    Best regards
    Torbjørn
    I have concern about battery life of the central device, peripheral is sending a notification let say 1 second interval. but I want to be notified in the interval of 5 minutes. And I can not modify the code of peripheral what should we have to do in this case.
