Custom Bootloader CRC check failed because of pair manag
Hello Nordic team!
We are developing system on nrf52832 chip. Let me describe our system a little bit.
It is constructed out of the soft device 332, main application and custom bootloader. We are preforming update over CAN in custom bootloader.
Everything was working perfectly, until client asked us if we can add passcode secure connection. We are checking CRC every time application starts. If we preform full erase and put new software it goes through CRC with no problem. But "then pair" manager preform write on internal flash and there is problem.
There are some suggestions that we think trough.
  • we leave out a specific area during crc calculation that might be manipulated by the sd
    • but this would also mean that we would need that flash area to remain constant over the life-time of the SD and it's updates
    • we could leave out the complete SD for CRC checking (does the SD has its own mechanisms for ensuring it is valid?)
    • this also means we are not backward compatible and need to replace the bootloader
  • you re-calculate the crc once the flash has been manipulated
    • that would include erasing of the flash area the crc sits in. So we would need to make sure that no other code is deleted with that (f.e. reserving a flash page for the crc)
    • also if there is a power loss or anything goes wrong before you recalculate the BL will also be stuck not starting the app
    • we would not need to replace the bootloader in this scenario
  • for the before mentioned solution we could switch to store the crc in one of the non volatile backup registers
    • but we then needed to replace the bootloader again
Soft device probably does not handle its own CRC mechanism on start-up right?
Can you help us what will be best approach, we do not want to dig inside SD and "pair manager"  and changing passcode destination write because we do not want to mess something in SD.
Regards.
Seba
Seba
